subieman Posted July 7, 2005 Share Posted July 7, 2005 Has anyone tried this? My DL (ea82) is overheating on the freeway so it needs a radiator bad. I have a spare Legacy radiator sitting in the shed. Looks like it would fit. The Legacy radiator has no hole for the fan switch though. Any suggestions? Thanks, Quote Link to comment Share on other sites More sharing options...
edrach Posted July 7, 2005 Share Posted July 7, 2005 Odd, my '91 Legacy's rad would never have fit into my '86 wagon....well it might fit, but the mounting holes wouldn't match up. Has anyone tried this? My DL (ea82) is overheating on the freeway so it needs a radiator bad. I have a spare Legacy radiator sitting in the shed. Looks like it would fit. The Legacy radiator has no hole for the fan switch though. Any suggestions? Thanks, Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 7, 2005 Share Posted July 7, 2005 Just get a two row that drops in. Legacy radiator isnt any bigger and it's still single row. Inlet / outlet orfaces are larger and youd have to make a coupler. Quote Link to comment Share on other sites More sharing options...
subieman Posted July 7, 2005 Author Share Posted July 7, 2005 Inlet / outlet orfaces are larger and youd have to make a coupler. AH! Well that sums it up.... Thanks Quote Link to comment Share on other sites More sharing options...
subynut Posted July 7, 2005 Share Posted July 7, 2005 Just get a two row that drops in. How much thicker is the two row vs the single row? I don't have very much clearence between my water pump and electric fan, at most a half an inch. Quote Link to comment Share on other sites More sharing options...
ballitch Posted July 7, 2005 Share Posted July 7, 2005 and were do you get a two row rad anyway? ~Josh~ Quote Link to comment Share on other sites More sharing options...
subynut Posted July 7, 2005 Share Posted July 7, 2005 Is the turbo radiator two row? Quote Link to comment Share on other sites More sharing options...
archemitis Posted July 7, 2005 Share Posted July 7, 2005 i have a legacy radiator in my ea82 wagon, and in my ea81 hatch. both required pretty extensive modifications. not for stock use =] Quote Link to comment Share on other sites More sharing options...
subieman Posted July 7, 2005 Author Share Posted July 7, 2005 Is the turbo radiator two row? Yes the turbo radiator is a two row and I would recommend using one. I stuck a 2 row in my 84 Wagon and it won't even heat up anymore! haha Quote Link to comment Share on other sites More sharing options...
subynut Posted July 8, 2005 Share Posted July 8, 2005 Hummm gonna hafto check that out. Unfortunatly, I'm not goning to be able to put it in before WCSS. So, I'll hafto see how she does. That nevada desert is a killer on cooling systems. Thanks! Quote Link to comment Share on other sites More sharing options...
subieman Posted July 8, 2005 Author Share Posted July 8, 2005 Hummm gonna hafto check that out. Unfortunatly, I'm not goning to be able to put it in before WCSS. So, I'll hafto see how she does. That nevada desert is a killer on cooling systems. Thanks! What route are you taking? What day are you leaving? There is a few of us leaving from Reno Thursday morning. Quote Link to comment Share on other sites More sharing options...
subynut Posted July 8, 2005 Share Posted July 8, 2005 What route are you taking? What day are you leaving? There is a few of us leaving from Reno Thursday morning. Will be taking off tues morning. I will be zipping through reno, up 395 and stopping in Lakeview,OR late wed night. Although, with Suby being stubborn, I wonder if it would be wise to join up with your caravan. In fact, she died on me today. Started as a wandering idle, then no charge, then stumbling and dead battery. DRAT, now what??!? Almost am wondering if Suby doesn't want to goto WCSS. SUBY WHAT'S WHRONG WITH YOU!?!?!?!? ok, done venting. Quote Link to comment Share on other sites More sharing options...
subieman Posted July 8, 2005 Author Share Posted July 8, 2005 Oh no that’s not good. Make sure you bring plenty of coolant with ya. The weather men are predicting 103 here in Reno!!!! ARGH! That’s a little bit hotter then we are used to. There will only be two of us leaving Thursday morning NVZENO and I. Jibs is leaving from sac with thesubarujunkie for some reason. So you are welcome to join us. Quote Link to comment Share on other sites More sharing options...
subynut Posted July 9, 2005 Share Posted July 9, 2005 Oh no that’s not good. Make sure you bring plenty of coolant with ya. The weather men are predicting 103 here in Reno!!!! ARGH! That’s a little bit hotter then we are used to. There will only be two of us leaving Thursday morning NVZENO and I. Jibs is leaving from sac with thesubarujunkie for some reason. So you are welcome to join us. Justa fried fuse. Whew! I lost the fuse between the Alt and Batt. Wouldn'tev thought that a non charging situation would cause my fuel injection to go haywire. Oh twell. At least she's happy again. Yes, we deffinately will bring lotso coolant! Sure we'll join ya! Where will we meet you? Quote Link to comment Share on other sites More sharing options...
