September 6, 200520 yr Here's a little printout I made to help ID the bolt pattern of wheels when you're at the yard. I had one for my Nissan and it was a lifesaver when I needed steelies. 4x140 and 6x139.7 are pretty easy to ID, but the 5-lug patterns can be less than obvious if you don't know what kind of car they came off of. Anyway, it's all set up to print, just load and print. Cut it out, punch holes, and have fun. It's got the 5 most common Subaru lug patterns on it - 4x100, 4x140, 5x100, 5x114.3, and 6x139.7 . Enjoy!
September 6, 200520 yr I had to resize it a bit to get it to print out exactly correct. Not a problem. I'm thinking Archive this Thanks, Glenn
September 6, 200520 yr Author What software did you print it in? I just realized that it's sized at 100 DPI and most software that isn't like Photoshop is going to want to print at 72 DPI. I'll resize it here in a second, then you're welcome to archive it . EDIT: There we go, it's fixed. Dimensions are now 540x720, which should be 7.5"x10" at 72 DPI.
September 6, 200520 yr What software did you print it in? I just realized that it's sized at 100 DPI and most software that isn't like Photoshop is going to want to print at 72 DPI. I'll resize it here in a second, then you're welcome to archive it . EDIT: There we go, it's fixed. Dimensions are now 540x720, which should be 7.5"x10" at 72 DPI. I used PhotoSuite @ 7.5 X 10.0 Came out perfect.
September 6, 200520 yr Great work Samo!! This could also be used a template for those looking to convert to 6 lug, or redrill rims to fit... This should definately be archived.
September 6, 200520 yr Author Thanks Tex. For those who are drilling to six lug, I'll make a better template that'll be a little more precise on where to drill. Actually, let me get right on that, I'll have it up in a second.
September 6, 200520 yr Thanks Tex. For those who are drilling to six lug, I'll make a better template that'll be a little more precise on where to drill. Actually, let me get right on that, I'll have it up in a second. Sweet job! this defintely belongs someplace permanent.
