Legacy LSD in Leone. Is it possible?
Hi,
I have an 1982 leone 5 speed manual 23 count splines. I have read about people swaping the inside gearing in a Leone RXII LSD to maintain correct ratio and using them in this model of leone.
I have found a Legacy LSD, could the same be done with this?
Thankx
Hayden
The Leg LSD is a Vicous (sp?) LSD and I believe 3.9 (mine was any ways) It will bolt right in. Great on snowy/icy roads, not so great for off road.
PS, I just noticed where you are located. You'd have to check the ratios to be sure they're the same. Tim
If its from a turbo legacy, I'm pretty sure its a 3.900 ratio. I have no idea about the international cars however...
I beleive my old school leone is 3.7 ratio. is this correct?
Can I change crown and pinon in legacy LSD to maintain 3.7 ratio???
Also, what about the stub axles they will have the wrong spline count. My spline count is 23 and I think the legacy is 25. Can I change the stub axles? how is this done?
I ran a USDM Turbo Legacy VLSD (3.90) in my 86 GL-10 Turbo Sedan for years. I also have a 3.90 D/R tranny in the car.
