Seafoam injection for older subes.
I had a funny idea for when you are driving around.Rig something up so you can inject seafoam into the intake of the carb so that the car would let out a cloud of smoke at any given time.I must be crazy.:drunk:
squirt marvel mystery oil into the intake instead makes better smoke
if its an older soob... just wait for the oil to drip on the y pipe, from the valve cover :lol:
Very good point! Smelly along with the smoke.I like it.:lol:
If you're going for both Smoke & Smell....
Nothing beats some good ol' CV/DOJ lube on a hot cat....
But 80/90 gear lube is right up there too......
I think it would be way cool to have a small brass vlave plumbed between the oil pressure port to the header. Just a quick turn of the valve and poosh! Smoke screen, eat your heart out James Bond!
My uncle rebuilt his 350 in his truck once and while the engine was out and my uncle was not looking- I poured a little oil down the exhaust pipes where the exhaust manifolds hook up. Jeez man! I had no idea how much smoke it would actually make! I had him beliving that he forgot to install rings in one of the pistons! haha! It took a week to burn completely! I've never seen so much smoke from a car that wasn't on fire!
Or from the rear main seal onto the cat (this happened to me for months before i got fed up of my car smoking out the sides at stoplights).
You mean they arent supposed to smoke and stink?!?!?!?!:rolleyes::confused: ..I thought that was a standard feature with all Subarus.
Its standard on all EA-series cars. Its an option on EJ cars. :grin:
Didn't Skip have a setup with a washer-fluid bottle that squirted ATF into the exhaust manifold?
friggin awsome where can i get one of those also how well did it work
Was just thinking the same thing.. theres an underhood pic somewhere
Put some diesel in the muffler, it smokes for ages!
Deisel (or whatever the JP equiv is) is what the M1's use for thier smoke screen, injected into the exhaust plenum. If its good enough for war it must be good enough for your Suby! :)
