took my 96 imp to advanced auto
96 Imprezas are OBD I, which is why I get the old style emissions check instead of getting my car hooked up to their computer through an OBD II port. That is a good thing since I'm not running the stock engine, an OBD II check would tell them that.
there are two sets of connectors up inside the dash one set green and the other black if i remember correctly. you need to connect them and it will flash the codes through the cel. get a manual before doing this, they tell you where the connectors are located and which ones to plug in. advance will have the manual, its a haynes titled computer trouble codes.
