loyale performance?
Check the archives, but not much is available without getting into the engine, drilling the airbox, or remiving the bottom entirely only adds 2 cfm of flow to the intake track, so realistically adds .66 hp. the exhaust on the subies is tuned for low end torque so i would leave it that way for good round town traveling. unless you go into the engine you can't really get much more hp
I did the following performance mods to my 92 Loyale, 4WD, auto:
* NGK spark plugs
* Bosh high capacity wires
* Drilled Air box bottom
* K&N air filter
* removed 2nd cat-converter
It runs a little better now. But it's only a 90 HP engine and with the automatic it's slow. But it still handles great, has awsome 4WD, and is a blast to drive.
:D
T.J.
I would cut the whole bottom from the intake box, or adapt a K&N cone filter to the MAF.
You can advance the timing a few deg and run 93 octance fuel for a few more ponies. Then a glasspack would complement that well. New plugs (NGK), wires, coil, dist cap and rotor would clear things up a free up some lost power...
What kind of millage should I be getting with my 92 Loyale, 4WD, auto?
It is only between 12 and 19 Mpg.
I did a lot of "tune up" work (see previous post) but still have a 35 (Purge Control Valve) so I gotta go to the junk yard in Wayland tomorrow to scrouge for a new one, because the dealer wants $102 for a new one.
Do all Auto, Loyales get lousy gas millage?
What else should I check?!
:confused:
T.J.
