August 16, 200619 yr ive got everything disconnected, and two bolts from the top of the tranny, and two nuts from the bottom. but still i cant get it to come free. Ive tried raising and lowering the trans to different angles, but nothing. I can see a bit of space form (like 1/64th inch), but thats it.. could use any advice from you whove done this before...
August 16, 200619 yr Make sure you got the right nuts on the right side of the motor (right as in if your standing at the front bumper its on the right side) I thought I had all 4 off but I had undone an unnecessary one that I thought was the right one.
August 16, 200619 yr make sure the motor mount bolts clear the cross member. The cases stick tight together sometimes. I have to use an old wood chisel to get between the housing, just work the crack around the case about a sixteenth at a time.
August 16, 200619 yr Author ok thanks for the tips. will check right now. prolly be usin the wood chisel soon..
August 16, 200619 yr You'll need to pry it apart with either a chisel or a screwdriver - just give it a good pry to bust loose the locator pins. GD
August 16, 200619 yr Yeah after 20 some-odd-years the output shaft likes to get stuck in the flywheel. Just lift, tug, pull, kick, jerk and pry until it pops loose. -Brian
August 16, 200619 yr I used a comalong. left the tranny attached to the car, lifted the engine up with the hoist, then pulled the engine forward with the comealong....worked great.
August 16, 200619 yr Author ok tranny is out and pressure plate and flywheel off. total time, roughly 22 working hours.i hereby apply for the worlds slowest mechanic award:dead: oh well it'll go together a lot faster now. definitely going to build a cradle for my floor jack, i was a retard to not use one. instead i had an engine hoist w a chain over the top tied to the trans front, and the jack underneath. IT IS A BULL************ way of getting the tranny out, do not try it. clutch disc was down to the rivets, pressure plate and flywheel scored a little bit, but not outrageous. also got two reman driveaxles at the dealership, besides OEM pr.plate, c.d., and throwout bearing- total cost, 950 bux cdn. I still have to get my core fee back for the axles though. i wanted to ask a few q's, but i cant remember ************ right now, so i'm goin to bed.
August 16, 200619 yr ...also got two reman driveaxles at the dealership, besides OEM pr.plate, c.d., and throwout bearing- total cost, 950 bux cdn. :eek: Clutch set US$180-ish from NAPA reman axles US$130-ish (core 130-ish) from NAPA Not buying stuff from the dealer... priceless!!!
August 16, 200619 yr Author i know i know! but i wanted the OEM clutch from some of the stuff i've read on here, and the axles..well i wasnt thinkin clearly, but i hope the quality will be a step higher as well.. plus im in canada and from what i see you gotta pay more cdn for everything, and 14% sales tax to boot in bc. also i think i could have got away without buying a new pressure plate - buddy may have upsold me on that. but yeah total for just the 3 clutch parts - 550$. and the subaru parts boxes.. they were so pretty... sniff...
