November 16, 200322 yr wooooooohooooooooooo!!!! tried the spacer idea (from the other thread) and it works great! (although i still had to get out the air chizel and zap it a few times to pound the tunnel out.... but now it doesnt rub at all, and it runs great! It runs much better on the freeway with the different gear ratios, and the linkage is not as sloppy as the 4spd either thanks Jerry, despite the weird issues some of us have had, your kit works just fine! (just some of our cars that are different than the brat need some special add-ons) now if i can just figure out the clutch cable thing.....
November 17, 200322 yr Hey Austin This is Jerry, now are you glad that you done this swap? The 5 speed makes your car alot more fun to drive. Let me know when you and Dave are comming over to drop the EA81 motor off for me i am ready for it. Thanks Jerry
November 17, 200322 yr My subaru is driving... Its so fast its hilarious! Little green wagon just SMASHIN down the block hee hee. Is it normal to whine in 1st gear? And it kinda is hard to shift the gears like the synchros are bad maybe? Other then that the car is awesome. Very pleased! I just gotta hook up the 4wd linkage and take emissions maybe tomorrow.
November 17, 200322 yr Matt, some gearboxes whine in first; not exactly normal, but nothing to worry about. Hard shifting could be due to a mis-adjusted clutch; if you don't dis-engage the tranny completely the shifting can be mighty difficult. Check for clutch pedal play before you do anything drastic.
November 17, 200322 yr I still gotta bany my tunnel a little tinsy bit and paint some surface rust. Oh and install some new exhaust gaskets. then Ive gotta get the glove box light to work and the cargo light too. and also a 4WD low light and switch. Yo Matt, the boost controller is almost done... hehehehe :bday:
November 17, 200322 yr glad to see the washer idea works on a 2nd application! i have never tried it myself:D
November 18, 200322 yr Matt..how fast are we talkin here...ludicrous speed? I've been debating this upgrade....cmon, talk me into it!
November 18, 200322 yr Hey Stupidru This is Jerry, i will put it to you this way. That auto has no chance of keeping up with the 5 speed. It will feel like you put a big block in your car. Thanks Jerry
November 18, 200322 yr In the rain when I get on it, it will spin the tires in 2nd no problem at like 30mph. And in the dry it will suck u in ur seat when ur really smashing on it. I wouldn't call it stupid fast, but its not boring to drive thats 4 sure.
November 21, 200322 yr Did you use the drive shaft & axle from you twagon? Did you use a single range push button 5speed? Miles...will a 1 inch lift be enough....so I won't have to modify the tunnel?
November 21, 200322 yr No I had to get a special shaft made it cost me 165$. And Its a 5spd D/R, but the 4wd linkage is yet to be hooked up. Its cold wet and the attaching point wasn't put on automatic cars!!!:madder:
November 21, 200322 yr stupidru: a 1 inch would mostly be enough. but the good thing about 1 inc of lift, all you would have to lift is the trans crossmember and the swaybar mounts. the front crossmember and struts can be left alone, if your goal is to fit a 5spd in there. the washers alone can get you a good inch, as long as your bolts are long enough. if some of the bolts are too short, go find some that go to a MT crossmember, and use them where they may be needed for lift! matt: even though 4wd is not hooked up, you can still engage 4wd either by the linkage off the trans(from under the car) or from the side of the trans from under the hood. all the way in is 2wd, all the way out is 4wd lo
November 22, 200322 yr Miles, so what your saying is I don't need to lift the whole car as long as I'm lifting trans crossmember and the swaybar mounts with washers. Matt, I was just going to swap in a single range 5speed cause I never go 4 wheelin. I think I can use my old drive shaft & axle's for this swap...correct?
November 22, 200322 yr I don't know, but I doubt it... I'm not gonna go wheeling either, but it will be nice to have a D/R when i'm in the snow or thick mud ya know, trying to go up big hills and such.
November 23, 200322 yr if the single range is from a NA, it will work with the axles. if its from a turbo, you will need turbo axles, wont fit on an ea81. but the doj(at least from mine) will fit ona 2wd axle, so the doj will most likely fit an ea81 axle(if the doj is same diameter) i am under the impression that the single range trans used the same driveshaft as dual range, and rx trans. so the driveshaft mod would apply. the turbo 5spd is 3.7 final gear. i would assume the na is also, but i know that 3.7 is turbo specific oh, i meant turbo axles as in ea82, 27(or is it 29) splines (the bigger one) the auto in the ea81t has the same spline as normal trannies, axles will fit a 5spd d/r. wed 5spd, auto, and 4wd auto, and i believe non turbo 5spd single range. do you have a 5spd single range? once i get my xt6 trans, i will; come off my 5spd, with the DOJ to them. but i need my driveshaft. we can deal as long as we an figue a way to get it there, or get you here!
November 23, 200322 yr Your not lifting the thing so much as you are DROPPING the trans 1". Hard to tell if this will be enough or not. You may still need to do some minimal beating. Austins idea to use an air chisel is a good one. That ought to teach it a lesson I would think. Also - I wouldn't personally use a whole 1" of washers as a long term soloution to the problem. Yes - it worked for me, and I did drive it some, but I am not comfortable reccomending you do this for a long term solution. Maybe it would work - maybe it wouldn't. I did it knowing that it would come back out shortly when the lift went in. The problem I see with the washers is there is no shear strength to them. They have no sideways rigidity, and you could potentially shear off one of those bolts pretty easy. Also - DO NOT use the stock bolts if you go a whole inch with washers on the radius plates - there not long enough, and you won't engage enough thread. If you want it for long term use, I say get some 1" square iron, and drill some holes in 1"x1" blocks of the stuff, and get some longer bolts. Basically make yourself 6 miniature lift blocks. GD
November 23, 200322 yr yup, it worked for both these guys, per my suggestion! lets see it work a 3rd time. then list about 3 bucks in washers, and call it "Miles Fox's Kit" i should go get a patent right now
November 23, 200322 yr Somewhere along the line someone put 2wd axles instead of turbo axles on my ea81t. The only reason I know this is cause Subaru did an axle for me, they found that turbo boot wouldn't fit on 2wd axle. I'll have to put some more thought into the lift cause my daughter will also be driving the car, I want it to be safe, she doesn't want to drive the Ford....hummm another Subaru Freak. Thanks fellas.
June 17, 200421 yr wooooooohooooooooooo!!!! tried the spacer idea (from the other thread) and it works great! (although i still had to get out the air chizel and zap it a few times to pound the tunnel out.... but now it doesnt rub at all, and it runs great! It runs much better on the freeway with the different gear ratios, and the linkage is not as sloppy as the 4spd either thanks Jerry, despite the weird issues some of us have had, your kit works just fine! (just some of our cars that are different than the brat need some special add-ons) now if i can just figure out the clutch cable thing..... What clutch setup did you use?
June 18, 200421 yr What clutch setup did you use? Hey desertsubaru This is Jerry, i use the EA81 flywheel the EA82 disc the EA81 puresser plate and the EA82 release bearing and fork. When you use this set up you will have to space your starter out a lock washer distance so it won't stay engage with the flywheel. The clutch cable is the stock 1 but sometimes you need to cut the bracket that holds the cable next to the bellhouseing. Move the cut bracket closer to the clutch fork and reweld it. Thanks Jerry
June 18, 200421 yr I found that I had to find an '88 clutch cable to go with my '88 5 speed D/R; the original 4 speed cable wouldn't adjust the clutch properly. Jerry, I have the EA82 flywheel and clutch assembly; seems to work just fine. I didn't notice if you put the lock washers under the starter motor.
June 18, 200421 yr Hey desertsubaru This is Jerry, i use the EA81 flywheel the EA82 disc the EA81 puresser plate and the EA82 release bearing and fork. When you use this set up you will have to space your starter out a lock washer distance so it won't stay engage with the flywheel. The clutch cable is the stock 1 but sometimes you need to cut the bracket that holds the cable next to the bellhouseing. Move the cut bracket closer to the clutch fork and reweld it. Thanks Jerry Thank you Jerry for the info! what im doing is putting 1982 EA81 into my 1986 Ea82 car. do i still have to move the clutch cable mount?
June 19, 200421 yr I found that I had to find an '88 clutch cable to go with my '88 5 speed D/R; the original 4 speed cable wouldn't adjust the clutch properly. Jerry, I have the EA82 flywheel and clutch assembly; seems to work just fine. I didn't notice if you put the lock washers under the starter motor. Hi Ed This is Jerry, you used the EA82 set up and it don't need any spacers but the EA81 dose because the flywheel sticks out farther by 0.90 of an inch than the EA82 flywheel. Thanks Jerry
