April 22, 200719 yr So today was the 1st autox for my RX since late 2005. I won SM (Street Mod...highly modified/prepped cars of all kinds...civics, A4's, STi/WRX, M3's...etc etc.). Things learned: 1. We need center diffs BEFORE front diffs. 2. We need front diffs! 3. No more 17's for me...the setup to run 17's on the street make the car way too loose on the autox course...so its time for 15x6's for the street. 4. Locking the center diff with the current setup=STi like power on oversteer AND WRC drift action....even on 225/50/15 Kumho V710 race tires at full temp. 5. Need EJ power steering pump. 6. Need forged pistons. 7. IC pipes blow off...but only once when fixed in a hurry in the grid. Moday I'll be calling JE about the pistons, as the current rings are starting to fade...filled the catch can with oil. I'll also be getting out the WRX PS pump and start fabrication on that.
April 23, 200719 yr Author 41st raw time out of 179, and 51st in pax out of 179. Not too bad for its first time out with this new stuff on it....
April 23, 200719 yr 3. No more 17's for me...the setup to run 17's on the street make the car way too loose on the autox course...so its time for 15x6's for the street. I'll also be getting out the WRX PS pump and start fabrication on that. first off congrats.... second what are you changing to run 17's on the street. that makes it so you cant run 15's on the same setup? and what is the EJ PS pump going to do for you? if you car handles anything like mine you need a EJ rack with a better ratio... -=Suberdave=- http://www.suberdave.com
April 23, 200719 yr Author Well done. What are the specs of what you are running now? An old rump roast run down EA82T TD04L-13G turbo EVO 550cc injectors eBay special 'WRX/STi' big TMIC 2004~2005 STi hood scoop a bunch of piping to make it work...with a T-XS knock off RFL BOV MegaSquirt-2 EMS SMC Water injection kit D2 front coilovers w/450lb springs Tein for Legacy (2000+) rears with 500 lb springs Super Pro bushings in the back and the front leading rod Leading rod has 10MM offset bushing for added caster Corner balanced to 50.1% cross weight (total weight is 2582 currently) T-XS standard MBC (set to 14psi) US 2.5 RS front brakes with Carbotech XP10 front pads (full race pads indended for road course) 5 lug conversion, 2005 Legacy bolt in hubs in the front with RS brakes, all XT6 stuff in the back 20MM swaybars front and rear (XT6) Sparco tube frame race seat and (I forget brand name) 5 point harness DEFI gauges (EGT, Oil temp, oil pres, water temp) AEM UEGO gauge (communicates with MS for AFR) MSD Knock alert system "JDM STi" 350MM steering wheel ($25 on eBay) w/MOMO adapter for Impreza I think thats all the important stuff... I was running Rota Tarmac 1's in 17x8 with 225/45/17 RE070's for the street...but...explanation below. first off congrats.... second what are you changing to run 17's on the street. that makes it so you cant run 15's on the same setup? and what is the EJ PS pump going to do for you? if you car handles anything like mine you need a EJ rack with a better ratio... -=Suberdave=- http://www.suberdave.com I have had to raise the front of the car about 4 inches from where it WAS at in order to make the 17x8's not rub in the front, and 4.5 inches in the back to do the same, as well as rolling the back lip up 90*. With it set like that, I ge nearly zero rub, and I have 1/4" wheel gap in the front and about 2/3" in the back. However, when I put the race tires on (15x7, 45MM offset, 225/50/15) I have about 1.25" gap in the back and 1" in the front...so I can definatly lower it more for race... The problem is also two fold. With it so high in the back the geometry puts the alignment at +0.5 camber, and -.2 toe out. That makes the car SUPER loose on transitions and turn in. While its really good for rotation, I lost about 2 seconds overall just going slower to make the car go around the course and not spin...thats why I locked the diff and drove it like a rally car on the last 2 runs. Had the car been more stable, I would have picked up time regardless....as its just plain loose. So, I'll go with 205/50/15 tires on 15x6 Legacy turbo alloys and lower it back down. I'll set it up for the race tires...and then with the street tires on it I'll be set. I dont want the better ratio of the EJ rack....YET. I like my tight turning radious. The EA82 pump I have on now starts cavitating really bad and does not put up to the heat under the stress of autox. I know that the WRX pump does. So I'm going to retro all that on it, uncluding the remote reserve and add in a cooler. That way I dont have to worry about. In the future I *WILL* be finding an 04 STi rack.
April 26, 200718 yr Let me know how that steering rack stuff works out, I have been fantisizing about that for ages! Why an 04 STi rack? Different from 05 etc? Won't a WRX rack be better than the RX one?
April 26, 200718 yr Author I want the fast 04+ sti ratio...BUT...the 05+ WRX and STi racks attach different on the drivers side with 4 bolt locations. Since I have an 05 STi rack...I can play with it and see if I can make the rack work in an 04- subframe. WJM
April 27, 200718 yr hey will, couldnt you get a steering cooler to help the heat issue? i have seen em in a few different cars, i think that some nissans come with em. i think. now that i posted and then reread your post, i see that youve already though of that.
April 30, 200718 yr Author yeah but stock pistons will not put up with what I am going to subject them too....endurance road course events.
May 5, 200718 yr Author Cuz I have an 05 STi rack and a complete EJ253/257 hybrid thats going in with an STi PS pump.
May 5, 200718 yr Cuz I have an 05 STi rack and a complete EJ253/257 hybrid thats going in with an STi PS pump. ok HEH! ninja edit
