June 5, 200718 yr Oh joy...No biggie I'll be up an running soon... http://forums.nasioc.com/forums/showthread.php?p=18299230&posted=1#post18299230
June 5, 200718 yr You dont know him very well, do you? Look at his pics in the gallery, you will see what he does to that poor car:-p
June 6, 200718 yr Author time for a d/r.......... That would be great! I'll be up a running this weekend...
June 7, 200718 yr I didnt open up my EA82 4wd 5spd after I grenaded it, but I bet I had a bunch of those little guys running around in the case:rolleyes:
June 8, 200718 yr hey, i have one of those.we should all make them into a neckalace.and hang it from the rear view.
June 10, 200718 yr Author here's some update on my progress...I pulled the 4EAT out and dissasembled the f. diff and replaced the pinion gear/bearing (wasted). Also the ring gear...I didn't like the pitting I found on the spider gears so I'm replacing those too. I went down to Rallitek's new shop(nice facility) and met Marc....kewl guy. Picked up a trans mount bushing insert. for $29.00 ...might as well upgrade while it's out. Here's few pics before the camera batt. died. Note: the wasted pinon gear!
June 10, 200718 yr nice shots, and thanks for the update I need to repl. the VSS #2 nylon drive gear in my 97 OB 4EAT Did you have any trouble getting it out?
June 15, 200718 yr Author Yeppers! I'm back on the road....Wahoo! she drives like new... I did a complete rebuild of the front differential and dialed it in. I could only work on it after work for a few hours here and there. It was actually a fairly easy job...just time consuming...(getting parts....I purchased the only carrier(spider) gears in town....no one had them...). I'll post more pics of the teardown and aftermath.....
