ericem Posted July 23, 2007 Share Posted July 23, 2007 I ordered new rotors and pads all around. Now I remember reading somewhere that I need to break in new rotors? How is that done really, thats if it needs to be done. Thanks. Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 I just always drove the car nipper Link to comment Share on other sites More sharing options...
Reveeen Posted July 23, 2007 Share Posted July 23, 2007 I remember reading somewhere that I need to break in new rotors? At one time this was true, rotors came "new" perfectly smooth, and we were using asbestos for brake material, you avoided "panic stops" (if you could for 500 miles). Now, rotors ship with a swirl pattern machined in the metal, and we are no longer using asbestos, go ahead and drive it. Link to comment Share on other sites More sharing options...
ericem Posted July 23, 2007 Author Share Posted July 23, 2007 Thanks guys. Yes I noticed the swirl marks. If there not there, do I stil need to do break in? They are just plain brembo rotors. Link to comment Share on other sites More sharing options...
TheYeti Posted July 23, 2007 Share Posted July 23, 2007 Thanks guys. Yes I noticed the swirl marks. If there not there, do I stil need to do break in? They are just plain brembo rotors. You should be just fine Link to comment Share on other sites More sharing options...
jamal Posted July 23, 2007 Share Posted July 23, 2007 The pads are what need to be bedded in. If they're stockish, it doesn't take much more than driving around normally. All you would ever want to know on the subject: http://www.stoptech.com/tech_info/wp_bedincontents.shtml Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 i still think its alot of bunk, otherwise anyone who lives in a high density area could go after a shop for not properly breaking in a set of pads. For instance, where i live you have travel a good 5-9 miles to get to anywhere where you can do 60 mph (and i dont mean legally), let alone do hard stops without getting rear ended. What are most people supposed to do? Also I have yet to see an SAE paper on this (please feel free to show me is someone has one). Just make sure you have a good brake pedal, be cautious on the first stop to make sure things work, then go ahead and drive. http://www.se-r.net/brakes/breakin.html http://www.cartalk.com/content/columns/Archive/2003/June/05.html Tire rack recomendations for specific brands http://www.tirerack.com/brakes/tech/techpage.jsp?techid=85 though i do love the part about avoiding heavy braking for 400-500 miles. Unless you live in north dakota i think thats impossible. http://www.pagidusa.com/bedding_in_procedure.htm So many variations on the procedures, professionally i think a lot of it is a myth. nipper Link to comment Share on other sites More sharing options...
porcupine73 Posted July 23, 2007 Share Posted July 23, 2007 I did the stoptech bed in; seemed to work well. The way they described the bed in would go was how it went also. The stoptech bedin is probably a little agressive for the stock pads but it still worked. There was an EndWrench article that basically said bedding in was not required and is antiquated; can try to find if interested. Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 I did the stoptech bed in; seemed to work well. The way they described the bed in would go was how it went also. The stoptech bedin is probably a little agressive for the stock pads but it still worked. There was an EndWrench article that basically said bedding in was not required and is antiquated; can try to find if interested. WOHOO i feel better :0 http://endwrench.com/images/pdfs/FrictionFeb06EW.pdf page 10 :-p nipper Link to comment Share on other sites More sharing options...
ericem Posted July 23, 2007 Author Share Posted July 23, 2007 yay!!!!!!!!!!!! I got some ACT ceramic pads BTW and plain brembo rotors. I can stop on a dime now with my crappy worn pads and worn discs. Imagine with nice new rotors and ceramic pads Link to comment Share on other sites More sharing options...
porcupine73 Posted July 23, 2007 Share Posted July 23, 2007 Yep that was the article nipper. Excerpt: Break-InNoise and a hard pedal will be likely if proper lining break in procedures aren’t observed with modern friction materials. In fact, several experts we’ve talked to say that overlooking this procedure is the #1 cause of those complaints. As one puts it, “It’s not unusual to see a perfectly good brake job ruined in the first five minutes by improper break in.” We know people who still believe that the right way to seat linings is to really stand on the brakes a few times. That’s an anachronistic idea left over from the days when linings were supplied “green.” Panic stops would indeed get that friction material hot enough to cure it. But you don’t get uncooked pads and shoes from Subaru, or from any other manufacturer these days, for that matter, so this whole idea belongs to a bygone era, a time of ignition points and bias ply tires. It’s only of historical interest today, certainly not anything you’d want to actually do. The ideal way to start new linings off is to make 30 slow stops (spaced two minutes apart) from about 30 mph using light to moderate pressure. But nobody who works in a typical bustling shop is going to take that much time. A more practical policy here is at least 10 moderate stops at 30-second intervals (you should be able to feel the action smooth out). Then avoid heavy braking for the first 200 miles. Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 Yep that was the article nipper. Excerpt: I call that driving in a neighboorhood with stop signs. nipper Link to comment Share on other sites More sharing options...
Reveeen Posted July 23, 2007 Share Posted July 23, 2007 I *think* you will find that a fella living in Maple Ontario Canada: http://www.mapquest.com/maps/map.adp?searchtype=address&country=US&addtohistory=&searchtab=home&formtype=address&popflag=0&latitude=&longitude=&name=&phone=&level=&cat=&address=&city=Maple&state=on&zipcode= Will get in the recommended "break-in" (brake-in?) about 2 minutes after leaving his yard (and before he can get to the 400 series parking lots found in that part of the world). Link to comment Share on other sites More sharing options...
ericem Posted July 24, 2007 Author Share Posted July 24, 2007 Thats what I figure Link to comment Share on other sites More sharing options...
