eseiler Posted September 8, 2007 Share Posted September 8, 2007 I have an EJ22 engine which is now almost constantly misfiring. Especially prevalent going uphill or accelerating. I'm thinking wires and/or plugs. O2 sensor maybe? I recently had exhaust work done so I drove it for a while w/o proper backpressure. Additives don't seem to work and resetting the 'puter is to no avail. Any idears? --Damien Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 8, 2007 Share Posted September 8, 2007 Do a compression test, or to check for a burned exhaust valve, hold your finger in front of the exhaust pipe loosely and see if it tends to be sucked in when it missfires. Quote Link to comment Share on other sites More sharing options...
nipper Posted September 8, 2007 Share Posted September 8, 2007 Breaking up under load is a spark issue. I would skip the compression test for now and go right to the tune-up plugs and wires etc. nipper Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 8, 2007 Share Posted September 8, 2007 Right on, with NGK spark plugs and OEM plug wires. Are you reading misfire codes via the ODBII? Quote Link to comment Share on other sites More sharing options...
eseiler Posted September 8, 2007 Author Share Posted September 8, 2007 Right on, with NGK spark plugs and OEM plug wires. Are you reading misfire codes via the ODBII? Yeah, that happens, too...the CEL blinks about 10 or so times whenever its hesitates bad. I had a similar problem before and when I read the codes back then it said 'cylinder misfire'. Back then it turned out that a wire got a little loose on the plug. Alright, I'll check that... Thanks for the advice. --Damien Quote Link to comment Share on other sites More sharing options...
2.5GL Posted September 8, 2007 Share Posted September 8, 2007 When was the last time you changed your oil? Lewis Quote Link to comment Share on other sites More sharing options...
rigfennid Posted September 8, 2007 Share Posted September 8, 2007 I don't have a manual yet (just bought a 94) but I'm going to be putting in new plugs and don't know what the gap to use. It's a 94 Legacy L Wagon 5-speed in case that matters. Eventually I want to swap in a 2.0 WRX motor & tranny... hehehe - Josh, are you listening? I've got a new toy!! Quote Link to comment Share on other sites More sharing options...
tcspeer Posted September 8, 2007 Share Posted September 8, 2007 The chronic misfire going up hills sounds like it could also be a coil pact giving trouble, if after changing the plugs and wires the trouble is still there then I would check that. Quote Link to comment Share on other sites More sharing options...
unibrook Posted September 25, 2007 Share Posted September 25, 2007 Might be front 02 sensor also. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 25, 2007 Share Posted September 25, 2007 Definatly change your plug wires at least... and plugs are cheaper so do them both if you can. My 2.2T had a HORRIBLE misfire problem. Backfired too. I was stumped for days, so i decided to pull the plugs to see if I could tell which cylinder was the problem (by examining plugs). As soon as I pulled the plug wire from the #1 cylinder, it fell apart in my hand. Sometimes its just that easy, but other times you cant see the damage thats done. Definatly get new wires!! Quote Link to comment Share on other sites More sharing options...
montana105 Posted September 25, 2007 Share Posted September 25, 2007 Hopefully it is only plugs and wires,there are tests to check your coil pack wires and plugs,and maybe it's something as simple as a rotten boot. Just for reference did you ever notice a definite pop or loss of power while pulling a hill,and maybe a generous stream of dark smoke while pulling the hill,exactly what happened to me and discovered burnt valve. Investigate the searches and ask questions and be sure to let us know what you find. Quote Link to comment Share on other sites More sharing options...
