Documented: The 1970 FF-1 Project car...
It didn't sell in terms of the auction (reserve not met) and I don't know if he sold it to that bidder either.
  • Replies 1.6k
  • Views 331k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • OMG! FINALLY! She will live again!  THE HOLE.... IS GONE! (more photos to come soon - i just opened the box, crappy phone pix!)       Now the fun begins.
  • SEAT PHOTOS!   Again, seats are from a 1982 Mazda GLC. They were from the original owner, who'd removed them from his car when new to install Sparco seats. Sat in his basement for 30 years waiting
  • Horns work!  (BEEP BEEP you've been warned!)   click here for video       Engine will be back inside of the car TODAY
Posted Images
oh, gotcha ;)
  • 2 weeks later...
I need longer front studs soon.
Anyone got any leads?
I have no idea if this would actually work, but if the FF-1 studs are similar to EA82 wheel studs, we might be in business.
I think original credit for this goes to WJM, but anyway, Nissan and Fuji have been pretty close bedfellows in the past. Nissan has Nismo, which makes nifty little doo-dads like extended wheel studs for running high offset wheels and wheel spacers.
I think WJM was able to use these Nismo studs in his RX, but really, I'm trying to remember this from an internet tidbit almost a decade old. :lol:
What do the studs look like? Pics?
The stud removed or on the hub? I don't have them with me, they are at the painter with the rest of the car, so I can't get them off the hub (which is another concern I have)
I read something about Nissan studs. I need to check the part numbers of the studs to see if they are simular to the other part numbers.
Are these the studs?
They appear to be rather inexpensive too. I'll have to ring up the sister dealership (Nissan) and see if they are a dealer-offered part I can get an employee discount on :)
That is if they work or not...
Here is a photo of the original hub:
OEM part number of my hub bolt is 623603001
That supersedes to
623603002
Which there are 2000+ in stock around the country, which means it supersedes to another car... Now its time to figure out which one :)
Alright, the part numbers for the NISMO studs are:
40222-RS025 60mm
40222-RS035 50mm
I've got the Subaru stud on order, so what I'm going to do is take that to Nissan and figure out which stud its like and if its like the studs that come in "extended length" then I'll order them and be set :)
Courtesy Nissan tends to do a large portion of the California Hi-Po Nissan stuff and have pretty reasonable prices from what I've heard.
Glad I could point you in what seems like the right direction and on a side note, isn't it neat how the lug nuts and wheel studs are basically identical from the 1960s to today?!?!?! Soooo cool to me at least.
Wheel bearings haven't changed much either :P
Go with what works I guess.
So they are just standard studs? ARP and Moroso also make extended studs that might work, just need to know the hole diameter and thread size.
OK, here is a photo of the bolt as requested.
Its the same tap-in diameter as the current hub bolts, and the same thread.
However, it doesn't have a lip, is quite a bit shorter, and the tap-in area is shorter too which has me concerned.
I just ordered an 80's model bolt to see if its different.
I ordered a 699900981 hub bolt kit from the 80's models to see what that stud looked like.
Indeed, the 80's studs, even brats, are the SAME as my FF-1 hub bolt.
Now I need to know exactly what the 80's guys are using for extended length bolts, and if the Impreza/Legacy bolts will work or if I should use something else.
3" is a bit of overkill.
So are you saying that Impreza studs DO work???
Visited the car today:
All of the Lead was removed from the roof connections and welded. Lead leaches through body filler and ruins the paint, so it had to go. The roof is going to be done early next week, the rest of the car will be worked on next week. The week after, probably some priming.
Saw this while I was there too:
Oh, and this mustang gives you an idea of the quality of paint job they do, :
  • 2 weeks later...
2010 STI muffler. I may or may not (probably not) use it for the FF-1. Its awfully large, and the quad tips will probably look stupid :lol:
But hey, it was free! Unlike the paintjob, which BTW it was primed today :grin:
Small, little update... The exterior is primered, next up is the interior and painting and then color sanding/buffing :D
It looks ABSOLUTELY fantastic so far, especially how well the hood has been fixed (doesn't flex anymore, and ALL the dents are gone!) Everything is amazingly silky smooth, its going to look like a new car when its done!
