CV Axles?
Are they the same on a 1986 GL10 as they are on any other EA82 GL Wagons?
Are they the same as the Loyale's?
I'm pretty sure there the same.. Dipending if it's FWD or 4WD but i think a 4WD 86 GL-10 wagon is the same as any other EA82 wagon.....
three different style depending on turbo, automatic, fwd or awd. Do a search, I know it's been posted a number of times.
If your GL10 is a turbo (which it most likely is) then they will be different than the GL, if the GL is non-turbo (which it most likely is).
-Brian
Thanks. I needed to know that SubaruJunkie.
Mine is a turbo.
Yeah i guess it would make a difrence if it's a turbo or not...
Learning something new everyday!:banana:
That's why I couldn't find it. Thanks for re-posting. And yes, it belongs in the USRM.
Though axles are technically "interchangeble" {within spline counts}, I would use Turbone's chart to select the correct one.
I am convinced that a lot of the mysterious "premature bearing failures" that people complain about are a direct result of using the wrong axle. People often grab the first decent axle they see at the yards, without really identifying if it's correct. Discount Part stores have not helped matters, 'cause a lot of them carry a single item# for each spline count. As a result, there are mixed up axles all over the place - whether in the car you are driving, or on the one in the JY.
The legnths of the axles vary, as the chart shows, and I suspect that the additional strain of an incorrect axle lead to the additional bearing wear. I have never seen the kind of bearing failures as with the EA's in any other make I've ever been involved with. This is just not normal.
Of course, you can use any axle with the correct spline count in a pinch. But be prepared to pay the price of additional bearings, seals, and anything else you happen to damage when swapping axles out constantly
good luck, John
Ed asked me to repost this. It was in my photo album.
Could we get a Mod to put this in the USRM?
we have to "submit" it.
DOne and done.
