subarari Posted November 3, 2007 Share Posted November 3, 2007 So I'm in the middle of changing my belts in my DL wagon with an EA82 SPFI engine, when I notice that the chiltons manual says to have both dots(holes) on the camshaft sprockets facing straight up, at the same time when reinstalling the belts. According to this post the manual I have is wrong. Also I remember that when I took off my drivers side cylinder head the hole on the sprocket was pointing outward, exactly 90 degrees, while the passenger side was straight up. All this while the car was at TDC with the distributor pointing at cylinder #1. My question is this: 1) Should I reinstall the way the belts came out? Belts never snapped, but I've always felt the car was a bit sluggish, possibly because the cams were 90 degrees out of phase instead of 180 degrees? Or 2) Install everything according to the instructions on the post and trash the chiltons manual for almost making me do the job twice:mad: Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 3, 2007 Share Posted November 3, 2007 The post you linked looks correct. You must rotate the crankshaft 360 degrees before installing the second belt. That is the key bit that those who are new to subarus often miss. Also, use the center line of the 3 lines on the flywheel, not the timing marks with degrees marked on them. If one timing mark is up the other must be down. Anything else, and the timing is wrong. And that would make it run crummy. Quote Link to comment Share on other sites More sharing options...
kamakazisubee Posted November 3, 2007 Share Posted November 3, 2007 Trash the chiltons. JT Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 3, 2007 Share Posted November 3, 2007 do the driver side belt first, then rotate the crank and do the passenger side. if you never removed the disty then you are good. if you did remove it, line up the timing after the belts are on Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 3, 2007 Share Posted November 3, 2007 Question: What is the disty? -Tom Quote Link to comment Share on other sites More sharing options...
mudduck Posted November 3, 2007 Share Posted November 3, 2007 Question: What is the disty? Distributor Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 3, 2007 Share Posted November 3, 2007 Why would anyone remove the disty to do a T-belt job? Quote Link to comment Share on other sites More sharing options...
mudduck Posted November 3, 2007 Share Posted November 3, 2007 Trash the chiltons. Thats right! F--k chiltons!!! Quote Link to comment Share on other sites More sharing options...
mudduck Posted November 3, 2007 Share Posted November 3, 2007 Why would anyone remove the disty to do a T-belt job? Might have done more than just t-belts;) Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 3, 2007 Share Posted November 3, 2007 Aaa yeah i guess your right.. And F--K Chilton too! Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 3, 2007 Share Posted November 3, 2007 And F--K Chilton too! Oh yeah, I forgot to mention that! I had one years ago, that came with one of the Subies I bought - the only thing it was good for was that it helped me figure out what years were interchangable. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 4, 2007 Share Posted November 4, 2007 Yeah i bought it at a used book store thinking it would be the best by of my life! Ha! I guess not. But it does give ya a little info on somethings. Quote Link to comment Share on other sites More sharing options...
