Numbchux Posted November 18, 2007 Share Posted November 18, 2007 did a clutch and oil pan (rusted through...) job today: and thought I'd post a few pics of my modified flywheel. I did this myself with a dremel, did not have the holes welded shut, or the wheel balanced. I've never noticed any vibration, and I've easily put 15-20k miles on it since I started driving it about a year ago. you can see the outline of where the bolts were. notice the bolt circle is a bit wider, and some of the holes are offset a bit: here's the 'nub' on the back of the engine that keeps the flywheel centered, the EA flywheel fits snug on this, so it's not possible to have it anything but perfectly centered: w00t! 'new' oil pan! Quote Link to comment Share on other sites More sharing options...
woundedbrat Posted November 18, 2007 Share Posted November 18, 2007 so basically you made the holes bigger towards the outside. was it trial and error until you got he correct pattern Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 18, 2007 Author Share Posted November 18, 2007 so basically you made the holes bigger towards the outside. was it trial and error until you got he correct pattern little bit, just take the EJ flywheel or flexplate, hold it up to the EA flywheel...and see where it doesn't line up.....and then make it line up. Quote Link to comment Share on other sites More sharing options...
monstaru Posted November 18, 2007 Share Posted November 18, 2007 you can use the thin sheet metal spacer from behind the flexplate as a pattern.i have several if anyone needs one.i have also been "on the wagon" of doing this mod yourself.and people just do not want to listen.all of the unbalanced issues that one hears of are from vehicles without the little "nub" (being the end of the crankshaft).just silly.and if i have not broken a bolt yet from torque, it will not happen.there is no jarring motion. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 19, 2007 Share Posted November 19, 2007 you can use the thin sheet metal spacer from behind the flexplate as a pattern.i have several if anyone needs one.i have also been "on the wagon" of doing this mod yourself.and people just do not want to listen.all of the unbalanced issues that one hears of are from vehicles without the little "nub" (being the end of the crankshaft).just silly.and if i have not broken a bolt yet from torque, it will not happen.there is no jarring motion. I agree that the flywheel modification can easily be done at home with basic tools. However, making the actual adaptor plate is a bit more sticky IMO because of the need to very accurately center the input shaft to the pilot bearing. Otherwise you risk causing damage to the pilot bearing, or the input shaft bearing. So far, the only adaptor plates I *know* of that properly take this into account are the ones made by rguyver as his are made by CNC with this alignment specifically addressed. Others might be accurate as well, but I don't have any knowledge on those. GD Quote Link to comment Share on other sites More sharing options...
Phizinza Posted November 19, 2007 Share Posted November 19, 2007 Good to see some photos of this. As you would know I didn't do this with my EJ conversion. Is it alright if I use those images on my site mate? Cheers, Phiz Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 19, 2007 Author Share Posted November 19, 2007 Good to see some photos of this. As you would know I didn't do this with my EJ conversion. Is it alright if I use those images on my site mate?Cheers, Phiz of course! as always I agree with GD. the flywheel mod is an easy home mechanic project....but the adapter plate is money well spent!! Quote Link to comment Share on other sites More sharing options...
