discopotato03 Posted May 6, 2008 Share Posted May 6, 2008 Hi all , has anyone done this to their older turbo Subie ? Cheers A . Quote Link to comment Share on other sites More sharing options...
Turbone Posted May 6, 2008 Share Posted May 6, 2008 Not going to tempt fate on that one Quote Link to comment Share on other sites More sharing options...
jacobs Posted May 6, 2008 Share Posted May 6, 2008 Oldsmobile used water injection on their turbocharged high compression 1962 or maybe it was 1963 aluminum block V8 from the factory. The compression ratio was somewhere around 10:1 or 11:1...I think. I'm sure it would work IF you set it up properly AND don't forget to keep water in the reservoir. Edit: See http://auto.howstuffworks.com/1962-1963-oldsmobile-f85-jetfire.htm Quote Link to comment Share on other sites More sharing options...
Subarutex Posted May 6, 2008 Share Posted May 6, 2008 Had I been modding an EA82T now, versus 3 years ago. Yes, I would use it. Some of the setups out now have very advanced controllers, boost switches, timing retard, etc... Quote Link to comment Share on other sites More sharing options...
Rxbubaru Posted May 6, 2008 Share Posted May 6, 2008 Ive read about this in a mustang 5.0 and superfords mag. the person that got it done to his car said it ran alot cooler than with out it. its pretty much like the Cryo2 system except it is injected into the engine than run through piping to cool engine componets. i would surely use it Quote Link to comment Share on other sites More sharing options...
discopotato03 Posted May 6, 2008 Author Share Posted May 6, 2008 Subarutex yes things have come a long way in the control dept . I've read that you really need programmable management for the engine to get the most from WMI . Cheers A . Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted May 7, 2008 Share Posted May 7, 2008 Hey Adrian Have you checked out this new system on Autospeed.com There are also another Autospeed system too The H2O Way Part 1 I am curious about water injection myself, but dont have the time/resources to experiment with it Gannon (Suparoo from Ausubaru) Quote Link to comment Share on other sites More sharing options...
discopotato03 Posted May 7, 2008 Author Share Posted May 7, 2008 Gannon the big thing is the WMI's control system , the most effective versions use either manifold pressure signal or 0-5v MAF sensor output to regulate the WM switch/ramp functions . Cheers A . Quote Link to comment Share on other sites More sharing options...
JWX Posted May 7, 2008 Share Posted May 7, 2008 Gannon the big thing is the WMI's control system , the most effective versions use either manifold pressure signal or 0-5v MAF sensor output to regulate the WM switch/ramp functions . Cheers A . Actually no, the best ones use Fuel injector duty cycle to calculate the water/meth ratios Quote Link to comment Share on other sites More sharing options...
