December 22, 200817 yr Finally had enough spare change to get some new tires and have them mounted to the rims Ive been holding onto. Edrach, these may look familiar to you I went with Sumitomo HTR200's. Size 185/60R13. I knew they would be small, but didn't know they would be THAT small. Its okay, I kind of like it. And im hoping I can get it alittle lower to remove some of that fender gap. Regardless... it sure looks alot better than the rusty old wagon wheels it used to have on it.
December 22, 200817 yr Drop it onto its balls! You need it so low, you can barely fit a soda can under the rear diff
December 22, 200817 yr Author Yup, its my GL10 Brat i just got. Im not sure how easy it will be to lower the front end. Im sure the front struts are already adjusted all the way down. I can probably get alittle out of the rear torsion bar, i'll have to find out later.
December 23, 200817 yr Author Nothing new really, except a stereo. I have to find all the plastic inserts so I can re-install the bed chrome. I dont have a picture of the tread.. but here is a link to the tire-rack page with some detailed pictures of the tires: http://www.tirerack.com/tires/tires.jsp?tireMake=Sumitomo&tireModel=HTR+200
December 23, 200817 yr I Really Like your Brat! ... Those Rims Looks so Clean, Like Brand New! Smaller Tires Makes your Subie stand Lower, so in Pavament, they can make your Subie to use a Li`l Bit less Gasoline, due to Aerodynamics...
December 23, 200817 yr Low pro 13's I never thought the day would come. It does look nice though!! Jeff
December 24, 200817 yr Lookin' good Brian. So THAT's where Ed's rims landed. Sweet! And you know where I am about lowering...
