EA-82 Sinking brake pedal
Hi. The pedal will sink to the floor, but only under steady, LIGHT, pressure, a firm push gives a firm pedal and no braking issues. This with the car running (92 Loyale 4wd/5sp/wagon) No fluid loss evident. I changed out the right rear axle bearing last summer and bled the brakes as per the instructions given elsewhere in the site. The sinking pedal remains unchanged. I would rather chase down the problem before it becomes a safety issue, not later. I have gone through this post : http://ultimatesubaru.org/forum/showthread.php?t=39459&highlight=sinking+brake+pedal but the conclusions are kinda inconclusive :-\ and the o.p.'s problem was not quite the same (Pedal sank under firm pressure) Any ideas out there?
I had that happen one time. It never happened again, so unfortunatly, I don't know specifically what it was. Everyting looked & worked fine after that. I drove that car for years after the incident.
This just happened to me it went away after replacing the master cyl. and the rear pistons. Since I did both im not sure which one it was but start with that :) If no fluid loss is evident at the wheels but you are losing fluid from the res I would suspect the rear . If no fluid is lost at all over time from the res then I think the master cyl. is to blame.
Edited by Caramanos2000
Your Master Cylinder is worn, time to replace it before a piston cup goes out totally.
Thanks to all - I was pretty sure it was the m/c. Just need to find a warm place to work on it now. :-\
Thanks, John. Switched my old Dodge cruiser over to DOT5 a couple of years ago, rebuilt the Mopar aluminum m/c, and learned all about bench bleeding a master before installing.:) Very good point for those of you doing a m/c for the first time.
