January 17, 200917 yr I currently have a Hitachi carb on my 86' Brat EA81. I was wondering Which is considered better...a Hitachi carb upgrade or a Weber carb Replacement? Which has more bang for the buck?
January 17, 200917 yr Weber. I hear the SPFI conversion really kicks rump roast! Never done the SPFI myself but have thought about it.
January 17, 200917 yr On the stock subaru carbs, don't they respond to the ecu preferentially? Like they need the ecu for that type of carb? If you did the stock carb swap would you need to swap the ecu for best gain? Pins are different arent they as well? Or, do they all work with the carb style ECUs?
January 18, 200917 yr On the stock subaru carbs' date=' don't they respond to the ecu preferentially? Like they need the ecu for that type of carb? If you did the stock carb swap would you need to swap the ecu for best gain? Pins are different arent they as well? Or, do they all work with the carb style ECUs?[/quote'] Don't know about matching ECU's with the carb, but you can definitely eliminate all that crap with a non-feedback hitachi or weber. My soob now has a weber 32/36, and when the ECS light comes on...NOTHING happens!
January 18, 200917 yr Go Weber! ... I Really Suggest you to Swap there a Weber Carb as long as you Can, but Check Emmissions` Laws too. My EA82 Subie Feels Soo Good with the Weber 32/36 Carb, and it has More Power while keep things Simple. I Have a Writeup with pics about how to do the Weber Swap in EA82 Engines, see my "Public Profile" Page Here (Click on my Avatar) to reach a Brief List of my Writeups... Maybe it can Help you. Kind Regards! ... Good Luck!
January 18, 200917 yr I'm Weberized, personally, I wouldn't ever go back, but I was just wondering about the feedback vs. non-feedback, hitachi vs carter weber designs.
January 19, 200917 yr Author Thanks for the replys! I'll be going by way of the Weber. Probably electric choke Model. Just a little apprehension because of emissions here in Texas...the thought of Unplugging hoses and cleaning up the engine bay sounds nice but not if I have to Put my tail between my legs from not passing inspection. Later yall!
