January 15, 200422 yr on my 87 GL-10 I'm trying to put a mech temp gauge in it, but the stock place is too small for the sender thingy. so where else can I put it?
January 16, 200422 yr find a shop that has "metric" adapters and there you will find a setup of pieces (like sun tune has a packet that i bought thru pep boy's a while back for the boost gauge... sooo maybe this will help with it. my wagon had a small (1 inch long) pipe extending the sending unit away from the pump's threaded hole sooo (shrugs shoulders at this one) did that make sense?
January 17, 200422 yr I installed an electric gauge in my Loyal after the EJ22 swap becouse the Loyal temp gauge wouldn't shag with the EJ sender. I just cut it into the heater hose comming of the manifold, you will still need some brass fittings to put it together but you'll have no probs fitting it in.
January 17, 200422 yr i don't know where the temp sensor sits on my ea82, but i was wondering if the sensor needs to be submersed in fluid to function. where exactly does it sit in the stock position¿
January 17, 200422 yr passenger side of the radiator on the side wall. on turbo models there is a similar item on the plate the thermostat is located on. submerssed as in radiator needs proper fluid levels... even though its about midway down the radiator tank it still reads temp from the humid air in the system if its really low and steam is filling the system hence why its still technically immersed i dare suggest.
January 17, 200422 yr Heater hose is where I put one on the Turbo Coupe. Brass fittings were used. Rob
January 17, 200422 yr on spfi, the temp gauge sensor is on the bottom front of the thermostat housing, one single blade terminal, use that hole the other one is for the ecu, leave it there on carbs, ots near the thermostat, its the only sensor, that hole works the fittongs with the hit will work, the threas is pitched *slightly* different, but it will thread, use teflon tape or pipe putty
January 17, 200422 yr The '87 GL-10 will have a MPFI turbo so the fitting on the goose neck (upper rad hose fitting) is too small. I used a 1/2" galvenized pipe Tee. The temp gage fitting I had screwed directly (read no thread issues) into the leg of the Tee. I put two short nipples in the ends of the Tee. The heater hose is 5/8". I used the one coming from the goose neck and spliced it in under the spare. This also affords one with a place for backflushing should the need arise. Hope this is easier to read and helps somewhat
January 17, 200422 yr Author Skip, did you mean mine was a turbo? cause its not, I wish it was but alas its not. it SPFI. and miles on mine I can't find the flat blade one just the round one. and can somebody tell me more about splicing in to the heater hose? edit Skip I re-read your post and saw what the splicing into the heater hose is about (still not clear on the whole turbo thing) but I have a question for you. where did you get the tee at?
