April 4, 200917 yr I have just finished my first spfi swap on my ea81, she runs but doesnt run right seems like bogging down when you drive it. i checked and am getting code 34 which is the "EGR solenoid valve" i have an 86 GL 4x4 hatchback. the donor car was an 89 GL wagon 4x4. i pulled one off a subaru i just bought that is FI same year and everything as the donor car she has bad head gaskets so i dont know if that one worked in the first place but neither worked. any body know whats going on?? Much Thanks SS
April 4, 200917 yr might not matter, but i couldn't figure this out: . i pulled one off a subaru i just bought that is FI same year and everything as the donor car she has bad head gaskets so i dont know if that one worked in the first place but neither worked. in general you can try to clean out an EGR and make sure it's not sticking. make sure it seems to operate properly and any solenoid associated with it does as wel (clicking). having it and all the other lines/hoses hooked up in the rights spots would be a good thing to check as well. do you have an FSM? it would have a good run down of what steps to go through with that code. can you remove and forget about it? Edited April 4, 200917 yr by grossgary
April 4, 200917 yr i checked and am getting code 34 which is the "EGR solenoid valve" The only thing the ECU is checking to generate this code is that the coil of the solenoid is not open. (or possibly shorted) It has no idea if the EGR valve is working, or if it is even there. My fix for "normal" operation: http://home.comcast.net/~davidtief/solenoid.html
April 4, 200917 yr Well, they aren't necessary... Mine went bad and started dumping exhaust and crap into the intake. So I just unplugged it Runs great and makes a beautiful rumble... That's what I suggest, unplug the thing! You'll probably never miss it. Twitch
April 4, 200917 yr Author Hey thanks you all next time i go to a u pull it ill take a look for some like DaveT is talking about and probly for now yea ill just unplugg the sucker. much thanks SS
April 5, 200917 yr Author so i unplugged and took out the egr solenoid valve but the ecs light on my dash stays on and i still get a code, is that going to put my car in like limp mode? is there a way to by pass is so the computer thinks it is still there and i wont have the code?? Just wondering Thanks SS
April 5, 200917 yr so i unplugged and took out the egr solenoid valve but the ecs light on my dash stays on and i still get a code, is that going to put my car in like limp mode? is there a way to by pass is so the computer thinks it is still there and i wont have the code?? Just wondering Thanks SS Why would you think taking out hte solenoid would make the light go out? If there isn't a load device on the end of the circuit, the computer knows something is wrong. Either wire in a resistor, or find a good solenoid to plug in there, at least electrically. It doesn't need to be actually hooked intot he vac lines, just the electrical unit needs to be present on the end of the circuit. At any rate it shouldn't really effect driveability. No worries about *limp mode* with this particular code.
April 5, 200917 yr Author ok i wasnt quiet thinking when i wrote that but yeah. i just wasnt sure if it would make the car run any differnt
April 5, 200917 yr EGR solenoid does nothing but generate a code 34. You can wire in a 5 watt, 33 Ohm resistor to simulate the solenoid. Either way - code or not - your bogging problem is not related and will not be fixed by replaceing the solenoid or tricking the computer. You have other issues. Run a D-Check. GD
