xoomer Posted December 2, 2009 Share Posted December 2, 2009 (edited) and all it cost me was a lifted wagon... Previous owner said Blown Head gasket, But she starts right up, and no Milkshake.... Except in the Air Cleaner. and then the passenger side Intake Manifold gasket looks blown... so I'm thinking that might be the problem... (I don't want to do Head Gaskets but will if I have too.) Edited December 2, 2009 by xoomer Quote Link to comment Share on other sites More sharing options...
rainman19154 Posted December 2, 2009 Share Posted December 2, 2009 oooh pretty!! a little acne and some table manners to iron out but what a gem!! Quote Link to comment Share on other sites More sharing options...
Breeke Posted December 2, 2009 Share Posted December 2, 2009 You did well my friend. must better than that beat-rump roast wagon you had, no offence. Guess you should get to wrenching, cause the tree run is sunday. -Caleb Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 2, 2009 Share Posted December 2, 2009 Nice!! Looks pretty solid. Head gaskets are EASY to do on the EA81's, so even if you gotta, it ain't that bad. Nice trade! Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 2, 2009 Author Share Posted December 2, 2009 (unfortunately) The tree run has been postponed for me this year.. But, This is definitely a clean rig. Compared to the Wagon, she has some rust... but nothing too bad... and at least she has the Jump Seats... Quote Link to comment Share on other sites More sharing options...
Durania Posted December 2, 2009 Share Posted December 2, 2009 Looks like someone did the "gasket in a tube" fix for your intake gaskets. I been there, it sucks. Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 3, 2009 Author Share Posted December 3, 2009 So what are the chances that this is a Intake Gasket issue? or should I not even waste my time? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 3, 2009 Share Posted December 3, 2009 Probably not an intake gasket with all that milkshake. Intake gasket would cause it to burn coolant, possibly leak it out on top of the motor and overheat once it gets low - won't mix coolant and oil like that though. Make sure all the freeze plugs are in. Pull the oil pan as you need to clean it out anyway and check for freeze plugs in the pan. Otherwise - almost a for-sure headgasket there - I've seen milkshake to that level before and that's almost a sure sign of HG's or freeze plugs. Don't run it much or you will score the bearings and it will be junk. Might already have comprimised the rod bearings - I would be very tempted to drop in a replacement/EJ22 or do a rebuild and Delta Cam, etc. GD Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 3, 2009 Author Share Posted December 3, 2009 Thing is its not milk shaked. Oil is a nice Brown color, Smells like oil. And seems to be ok. the only Milkshake is in the Air Cleaner... that's it, Thats why I'm confused, Quote Link to comment Share on other sites More sharing options...
joostvdw Posted December 3, 2009 Share Posted December 3, 2009 You can test for coolant in the oil with a lighter, just light a flame under the dipstick with some oil on it. If it sputters there's coolant in it. If it does nothing, it's clean oil (uuh, oke, maybe not clean, but atleast there's no water in it.) As for milkshake in the oil filter, you could clean up the mess, drive it for a couple of miles and see if you can find the source. This type of sludge buildup can also happen when crankcase breathers are blocked or the PO ran if often for short amounts (and not revving the engine). Quote Link to comment Share on other sites More sharing options...
Yo'J Posted December 3, 2009 Share Posted December 3, 2009 (edited) Dood! Score! That looks just like mine! I'm by NSCC, near northgate. I've seen one just like it in Ballard on market st. Possibly the same? Big guy with beard? What year? Wish mine had tailgate trim. Edited December 3, 2009 by Yo'J Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted December 3, 2009 Share Posted December 3, 2009 they took out her left nipple, the brutes, who did all the switch pulling? Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 3, 2009 Author Share Posted December 3, 2009 they took out her left nipple, the brutes, who did all the switch pulling? huh?? Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 3, 2009 Author Share Posted December 3, 2009 Dood! Score! That looks just like mine! I'm by NSCC' date=' near northgate. I've seen one just like it in Ballard on market st. Possibly the same? Big guy with beard? What year? Wish mine had tailgate trim.[/quote']I picked this up on 175 and 15th.. Quote Link to comment Share on other sites More sharing options...
one eye Posted December 4, 2009 Share Posted December 4, 2009 Nice Looks like a little work and you got a rig you can haul stuff with !!!!!! If you need some parts I got a bunch of parts off Brats here................. Jeff Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted December 4, 2009 Share Posted December 4, 2009 huh?? the left hedlight switch , thoes switches look like nipples to me Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 4, 2009 Share Posted December 4, 2009 rip the whole thing out and do a refresh - reseal job. Quote Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted December 4, 2009 Share Posted December 4, 2009 rip the whole thing out and do a refresh - reseal job. Sheesh, you guys are overreacting about a simple EGR problem. I had that happen in my 85 BRAT. Muck in the air cleaner and no where else. Just unplug the largest hose on the driver's side of the air cleaner and see if that fixes the problem. If it does, then just pull the EGR and plug the hole. If not you've got me stumped. And I think I know that BRAT. I believe that BRAT lived in a trailer park near me. I drooled over it for many, many days. Twitch Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 4, 2009 Share Posted December 4, 2009 Oh the original poster said it needed a HG so i figured just rip the whole thing out and do it right. Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 5, 2009 Author Share Posted December 5, 2009 It might... but Compression numbers and leak down show ok numbers. Quote Link to comment Share on other sites More sharing options...
