DIY Wheel Bearing replacement
I have a '94 Imprezza wagon (frnt wheel dr) and an '01 Forrester, both are getting loud, I believe its the wheel bearings. How feasible is this as a DIY job? I am fairly experienced with these cars, have done timing belts, CV axels, etc. myself. I dont have a shop press, is there a way to do it without one? (maybe buy a pre-assembled bearing?).
Do I need other special tools? can I just take the whole knuckle assy off and have a shop press the bearings in?
Advice and or pics would be greatly appreciated.
Thanks,
E
they are press fit bearings ---> knuckle and then the hubs need pressed back into the knuckle/bearing
Unless you've done a wheel bearing on another car before, I wouldnt recommend doing it yourself. It gets spendy when you start ruining bearings or the knuckle
My experience...........I bought a press from Harbor Freight. It cost about $100. I had a devil of a time removing the old bearing, and pressing on a new one. Then, the new bearing went bad in 6 months, so figured out the hub was actually bad.
I finally went to a wrecking yard, bought a hub unit for $75, installed that, and so far, so good. Yea, it is possible to buy junk at a junk yard, but if it is junk, they will guarantee for 30 days. In the future, I will go this route again, when I have a wheel bearing go bad.
With two cars in need I think learning how to do it would be well worth it. I've done 3 of the 4 corners on my brother's '93 Imp and it wasn't too bad. I do have a shop press however. If you do it on the car with the HF kit, I would also recommend picking up a large bearing puller as well. It's not necessary but it can come in handy to remove the hub. With a few tools and a little ingenuity you can save yourself a lot of money and have the satisfaction of knowing it was done right. I would also recommend taking a couple photos of the rear e-brake set-up if you disassemble it.
  • 2 weeks later...
nah, no need for rear brake shoe pics. Just do one side at a time. When you go to put together the first side, you pull off the rotor on the other side so you can visually look at the brake set up. Its rule #1 when it comes to brake shoes. Never tear down both sides, only one side til its back together
That's one of the things I like about the HubTamer tool method. No need to remove the brakes.
  • 3 weeks later...
The harbor freight front wheel adapters work very well, it's kind of a lot of steps but the tool works great. If you have an air ratchet that makes it a ton easier with the half dozen or so ons and offs needed. Plus if you have their large bearing separator that makes it a lot easier to get the bearing race off the hub.
