swap EA82 rear crossmember into brat?
6 replies to this topic
#1 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 03 September 2004 - 12:56 AM
I've been thinking about putting EA82 rear control arms in the brat, so i can have a sway bar.
I've also been interested in rear coilovers but I understand that (especially in a brat) they can be a bit much when coupled with the torsion bars.
To deal with the rear coilovers, I'm interested in:
removing the torsion bars - are they necessary if coilovers are installed?
-OR-
swapping in an EA82 rear crossmember - I'm sure it would have to be narrowed; would it then be a matter of putting EA81 brackets on it?
#2 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 03 September 2004 - 08:11 AM
I think Lumpycam put EA82 rear under his Gen I Brat...
#3 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 03 September 2004 - 12:00 PM
I'll send him a PM and report back here then *salute*
#4 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 03 September 2004 - 06:26 PM
are there some EA81 models that didn't come with torsion bars at all? it would be far easier to swap EA81 xmembers with each other instead of wrangling an EA82 xmember in there...
#5 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 04 September 2004 - 07:31 AM
I've repositioned the spring perches on solid axles so they'd fit under a different model vehicle than what the axle came out of. Fairly simple to do, just have to get the pinion angle right.
So, I wonder if one could carefully cut the mount points off from the EA-82 suspension, then center the unit under the car, and re-weld the mout points where they need to be. This would give you a slightly wider track on the rear which would be a good thing on a lifted vehicle.
Am I way out in left field on this????
#6 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 04 September 2004 - 09:29 AM
Qman added a ea82 sway bar to his Beauty Brat he Rally-Xs... I believe he cut the ends a bit, then had to weld on the mounts for it...
#7 carfreak85
carfreak85
    Temple of Fuji
  • 5,324 posts
  • Cascadia
Posted 04 September 2004 - 10:48 AM
I have pics of a black brat with a rear swaybar some where. Not Kern's though.
