Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
GL Won't turn over! Just a click. What's wrong?
#1
Posted 22 October 2004 - 04:10 PM
When I turn the key on, all the warning lights come on like normal and then when I turn it to start, the voltage drops way down and I just hear a loud click.
It doesn't seem to try to turn the engine over at all.
Do I need a new starter?
Hope you all can diagnose it from this description.
Seems like it should be pretty straight forward, I just don't have experience with this or voltage meters to test things.
Thanks for the help....
Rashaan
#2
Posted 22 October 2004 - 04:18 PM
Have you cleaned your connections at the terminal lately?
#3
Posted 22 October 2004 - 04:31 PM
If it still clicks...then take a LARGE dia wire...say...4 guage or so...and touch to the + side off batt...and CAERFULLY work the wire down to that little connector on the starter with the wire off it...becarefull not to groud out anywhere...if the starter engages and engine starts up with key on...then there is something wrong with the starter contacts or the ig switch stuff...
my GL-10 did this..and I just ran large wire with a push button starter swtich.
#4
Posted 22 October 2004 - 04:32 PM
#5
Posted 22 October 2004 - 06:59 PM
I'm not much of a gambler but my money's on the contacts.
click click click click
#6
Posted 22 October 2004 - 07:08 PM
#7
Posted 22 October 2004 - 10:04 PM
#8
Posted 23 October 2004 - 12:26 AM
#9
Posted 23 October 2004 - 03:00 AM
#10
Posted 23 October 2004 - 04:59 AM
If it still does this after you've cleaned and tightened both ends of the cables to the battery, you probably need to replace the starter.When I turn the key on, all the warning lights come on like normal and then when I turn it to start, the voltage drops way down and I just hear a loud click.
#11
Posted 23 October 2004 - 05:31 AM
#12
Posted 23 October 2004 - 10:54 AM
The contacts sit in the solenoid assembly.
Starter motors are very tough, i'm doubtful that you need a new one. Pull it off pull the solenoid asssembly apart, not the motor side, And look at the contacts if they are deeply dished or broken problem found.
We are talikn 30+ minutes here, really straight forward.
A little insight into starter/ solenoid workings...
the solenoid is a electromagnetic coil, in the center of this coil is the plunger or in trade terms the actuator.
the plunger is forced down by the magnetism from the coil,on the bottom of the plunger is a contact.It strikes the two contacts at the bottom and completes the electrical path between them.
Now the starter has power.
It's essentially another form of a relay that does heavy load switching.
Let us know how you make out.
