opus Posted August 6, 2008 Share Posted August 6, 2008 Can I put the 4 lights into the 2 light GL? Easy swap?? Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted August 6, 2008 Share Posted August 6, 2008 Can I put the 4 lights into the 2 light GL? Easy swap?? i like the way you think. You need to change the marker lights on the fender there differant. not only the lights but you need the mountings behind them those bolt right up. The only problem would be wireing and im not sure how you would do that ben Quote Link to comment Share on other sites More sharing options...
Dr Subenstien Posted August 7, 2008 Share Posted August 7, 2008 I am not so sure it would be that easy. the radiator support is differant on the 4 light vs the 2 light cars. correct me if I am wrong though:popcorn: Quote Link to comment Share on other sites More sharing options...
opus Posted August 7, 2008 Author Share Posted August 7, 2008 Yeah, I looked it over, think I will pass on it. Oh well, good thought anyways. :/ Quote Link to comment Share on other sites More sharing options...
bigjim5551212 Posted August 12, 2008 Share Posted August 12, 2008 you can put H4 headlights as a conversion. They are superior to anything and way better to keep your singles than a 4 headlight kit. UNLESS You have the 9004 do6 5hit headlights and you are going to put a 4 headlight kit in. Quote Link to comment Share on other sites More sharing options...
opus Posted August 13, 2008 Author Share Posted August 13, 2008 I have 9004's. The housings are lousy so it doesnt matter what you have in there. I am looking for a light bar to mount some Cibie's on. Quote Link to comment Share on other sites More sharing options...
bigjim5551212 Posted August 13, 2008 Share Posted August 13, 2008 if you can get sealed beam buckets, you can then put in H4 headlights. Are you familiar with H4 Headlights? They are the best. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 13, 2008 Share Posted August 13, 2008 ...Or you can Install an H.I.D. Kit for 9004 Housing`s Headlamps... Quote Link to comment Share on other sites More sharing options...
opus Posted August 13, 2008 Author Share Posted August 13, 2008 Here's what I have: Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 13, 2008 Share Posted August 13, 2008 if you Don`t have any HeadLamps, you can Try to Swap there HeadLamps from Other Car... Not Only Subies, see: I Saw this "Work in Progress" Long time Ago in one of my Countrie`s Streets, it Could be a Great Idea, Specially if you could find H.I.D. HeadLamps! Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted August 13, 2008 Share Posted August 13, 2008 yeah true. I just put in the Hella H4 "sealed to h4 conversion lenses" for my hi/lows. wow.....very bright so now i need to replace my hi only lens too, as the oems on high are dimmer than the hellas on low beam lol. if you can get sealed beam buckets, you can then put in H4 headlights. Are you familiar with H4 Headlights? They are the best. Quote Link to comment Share on other sites More sharing options...
bigjim5551212 Posted August 13, 2008 Share Posted August 13, 2008 if you Don`t have any HeadLamps, you can Try to Swap there HeadLamps from Other Car... Not Only Subies, see: I Saw this "Work in Progress" Long time Ago in one of my Countrie`s Streets, it Could be a Great Idea, Specially if you could find H.I.D. HeadLamps! Thats awesome Quote Link to comment Share on other sites More sharing options...
edrach Posted August 14, 2008 Share Posted August 14, 2008 I will have a pair for DL frames at WCSS10 which I never used on my '86 wagon. They'll be pretty cheap since I don't want to bring them home again. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted February 26, 2010 Share Posted February 26, 2010 yeah true. I just put in the Hella H4 "sealed to h4 conversion lenses" for my hi/lows. wow.....very brightso now i need to replace my hi only lens too, as the oems on high are dimmer than the hellas on low beam lol. Ok, can you explain this a bit more? Do you keep the stock sealed headlights and do what to them? The bulbs are still 9004, yeah? Looking for some more info on this, and yes - I dug up a 3 year old thread. :-p -Tom Quote Link to comment Share on other sites More sharing options...
