Legacy Exhaust Rattle- Need help
8 replies to this topic
#1 jrodb1735
jrodb1735
    New User
  • Pip
  • 1 posts
  • Morgantown
Posted 12 August 2009 - 07:30 PM
My 2003 Subaru Legacy L (2.5L, 5 speed manual) has been a phenomenal vehicle for me. Acquired it with 35k miles and now has 122k miles.
I am currently experiencing an exhaust rattle. It happens only at 2100 rpm. I viewed the car from underneath while my friend revved it to 2100 rpm and I have isolated the rattle to one specific pipe. The pipe is the passenger side half of the y pipe that comes directly out of the motor. All three of the bolts are snug, and I can't seem to figure out why it is loose.
Has anyone had this issue with their vehicle? I am thinking that I can easily replace that one section of exhaust pipe, but I couldn't easily locate a replacement part. Does anyone have any suggestions? Do I need to replace the whole exhaust system (which is in otherwise good conditon)? Any advice would be greatly appreciated. Thanks!
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 22,049 posts
  • Portland
Posted 12 August 2009 - 07:33 PM
Remove the y-pipe and isolate the problem. It is likely to be the inner pipe - that section is double-layered, or a heat sheild. Tack weld the offending bits in place and reinstall. Should be a simple fix - no reason to replace it if it's not leaking and is otherwise functioning normally - they are pretty expensive from the dealer - probably $200 to $300 or more.
#3 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,064 posts
  • Honolulu HI
Posted 13 August 2009 - 12:05 AM
Welcome jrodb1735. Please post your question in the New Generation forum.
#4 Rooster2
Rooster2
    Subaru Master
  • 4,728 posts
  • Indianapolis
Posted 13 August 2009 - 11:40 AM
Does the section of the Y pipe have a shroud covering it? If so, I would suspect that a portion of the shroud has come loose, and is vibrating.
I have had this problem on both of my OB Wagons. I had a friend rev the motor up to the rpm that resulted in the rattle sound, then hold that rev so the sound would continue. Then, I crawled under the car and pushed/pulled on the shroud with my gloved hand and a screw driver until I found which portion of the shroud was loose. I cured the problem by hammering in a bolt as a wedge between the pipe and shroud to prevent the shroud from vibrating. Other guys have used a screw type hose clamp over the shroud to stop the vibration.
Hope this info helps!
#5 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 13 August 2009 - 05:55 PM
Welcome to the land of subarus. Its a heat shiled easily fixed with vice-grips or a large hose clamp.
nipper
#6 GeneralDisorder
GeneralDisorder
  • 22,049 posts
  • Portland
Posted 13 August 2009 - 06:16 PM
Sheet metal vibrations - sometimes a well placed blow with a ball-peen hammer will cure it. We had a customer with a pump that made a "strange noise" - the tech listened carefully to it..... went out to the truck and got his ball-peen hammer - smacked the motor fan shround with it one time.... no charge.
#7 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,034 posts
  • Charlottesburg, VA
Posted 13 August 2009 - 11:28 PM
Sink a couple 3/4" long self tapping sheet metal screws into it at either end and that should cure it.
#8 Lefty
Lefty
    New User
  • Pip
  • 9 posts
Posted 14 August 2009 - 01:25 PM
I have the same noice/resonance when the fan kicks in while Parked. It surely sounds like vibrating sheet metal. Any ideas where exectly this could be coming from?
#9 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 14 August 2009 - 04:03 PM
post #10 here, lots of good info , keep it as a reference.
http://www.ultimates...ead.php?t=51554
