All Activity
- Past hour
Here is an update to my situation. I get a 0638 code and the car coasts to a stop and the engine is still running in limp mode. The car can go about 2 mph. I shut off the engine for a minute and when I restart it runs normally again. This only happens on longer trips after maybe 30 miles and the car has been working hard. Apparently a dirty throttle body can be a culprit. I looked in mine and it's rather clean. Also the electric accelerator can be a cause. I replaced it and the problem did not go away. The next suspect is apparently the throttle position sensor. Is it true that I need to replace the entire Throttle body as the throttle position sensor is built into the throttle body?
I recently put mine back in service, and I found that the clutch cable needed to be adjusted first.
- Today
The EGR code is for the EGR solenoid, not the EGR valve. The ECU can only read electrical faults, it will not know if anything mechanical is going wrong (the EGR valve is purely mechanical, as such the ECU won't tell you if it's dirty, sticking, etc) The solenoid controls when the valve gets vacuum. I've had this issue, it's an easy fix. Check out this forum post, scroll to the bottom and it'll tell you how to install a new EGR solenoid. The solenoid will cost ya $50 ish bucks but you shouldn't have to replace it again. :]
to start this car has 287k miles and about three years ago (a year after i bought it) it left me stranded in a parking lot. For about three months I had been dealing with fuel pump issues where i would have to "wake" it up by hitting it with a wrench to get it to run (also this is the only issue this car has given me up to this point), and in that parking lot it completely went out on me and wouldn't start no matter what i did. surprisingly after a few days of it sitting there i went back the day i was gonna get it towed to my house and it started! that was the last day that it fully ran and drove. i replaced the fuel pump, nothing. fuel pump relay, nothing. I only recently found out and confirmed that it was the wiring harness that goes from the relay back to the fuel pump. I was able to bypass the 12v power by wiring in my own spade connectors and wires and connecting the power to the fuel pump and that got it running with the turn of the key like it's supposed to. A new issue rose up with this though, now it doesn't want to idle at all, starts up tries to idle and stalls within seconds. I have cleaned the IAC with the proper cleaning products, i cleaned the air intake, bought a refurbished EGR valve, bought a junkyard coolant temperature sensor, cleaned the coolant temp sensor connectors to both male and female, still nothing. the only way i can get it to idle is if i connect the green test connectors under the hood and disconnect the coolant temp sensor completely, any other way it will not idle at all. I tried every combination of connecting and disconnecting those two and the only way is test connectors plugged in and coolant temp sensor not. i haven't left it running for long because i know you're not supposed to but this taught me that there is something here that i can fix i just have no idea what it is. i have scoured these forums for the answer and i have found nothing for this specific issue. I am now posting this as my last attempt at figuring this out and trying to revive my beloved car. Any suggestions and help is greatly appreciated, also sorry for the word vomit i just had to explain the amount of work I've put into this
Tried using the hill holder on my 1985 Brat for the first time this year. It doesn't work, I was on a pretty steep uphill stop. Any suggestions?
Spook_G59 joined the community
KHorsman joined the community
Dual SPFI EA82 Ideas
bushytails replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Instead of dual SPFI, let's go for *quad* SPFI! ... oh, wait, that's just a MPFI manifold swap. - Yesterday
I have to look at it closer but yes my current plan is to cut out and refab the lower radiator support from scratch, probably 2x4x1/8" wall rectangular tubing or similar. Might increase approach angle a bit and probably be stronger. Then finagle the hood latch/upper rad support back into place. Right after it happened I thought about just buying another rust free car and swapping things over but I think it will be easier and cheaper to repair this one. There don't seem to be many laws regarding flat towing, certainly not much enforcement if there are. I can't say I recommend towing something as heavy as your tow vehicle without brakes but we've done it a number of times now. It has become increasingly common over the last 5-10 years to see two or three cars hooked together driving down the interstate, likely all purchased at an auto auction. There are stories that people operate trains of up to six of these cars with more than one powering the assembly. Trying to rent a tow dolly from Uhaul on the other hand took some finagling. The van I used is a 3/4 ton, we've towed a 20' enclosed trailer with it. Eventually talked to one guy who helped me figure out which options to tell them I had so their system would let me rent a tow dolly to tow a FWD wagon, I definitely wasn't going to tell them I was going to be towing a Subaru. And the tow dolly has surge brakes, so definitely safer than flat towing from a braking perspective. That day trip was great, every time I take it off pavement I'm reminded that the first gen Impreza with EZ36 is like a cheat code as our friend A said. Didn't bother airing down, never had to use the low range or even lock the center diff, never got stuck. Also reminded me how many trails there are in the UP. My GPS log is up to 5400 miles of unpaved trails up there. There are definitely some repeats/overlapping trails so let's say we've been on 3-4000 miles of unpaved UP roads but I would guess that is about 1/4 of the unpaved roads/trails there. The one loop I did I probably would have turned around where (or before) that picture was taken it was getting so overgrown but I was still following a trail on the GPS. The other area I wound up in there were no roads anywhere on my map for miles yet quite a few roads/trails I was exploring, some of them quite wide and smooth. "Connected the dots" too as we like to say - go off the end of one road on the map and wind up on a different road on the map miles later.
No brake Pressure…’79 gl wagon
itstoobright replied to gsm206's topic in Historic Subaru Forum: 50's thru 70's
I know this is old but I would just like to say that it sounds like a seal or line has ruptured, probably from the force of attempting to un-seize the brakes. -
'79 Brat EJ22 Retrofit Build Thread
itstoobright replied to mka's topic in Historic Subaru Forum: 50's thru 70's
This is a pretty impressive project and it seems to be going very well for you! That transmission mount practically looks oem! -
itstoobright changed their profile photo
Need an injector pump
SuspiciousPizza replied to scooby2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Valid point, I didn't word that properly. I meant a new unused "plug & play" pump is getting very difficult to find. If OP was looking for a pump they could just fit without having to buy extra fittings, hose, electrical or mounting solutions, the options are limited. Its definitely not impossible, it just might take extra time waiting on the right hardware. :] -
el_freddo started following Dual SPFI EA82 Ideas
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
One way to look at it would be to halve the injector size and have the two batch fire together. The MPFI system batch fired two injectors together. A similar thing could be done with what you’re suggesting. You would have to find out voltage requirements etc to run two injectors at the same time. You may need to look into throttle body size too as this will have an effect on throttle and engine response - or lack of. As for other sensors, no need to move them. One AFM will still do the trick. If you’re going to have a go at this, a) don’t waste you time and money, b) just plumb both intake tracts together to the AFM and run all the breather lines etc in the single section of intake pipe so both sides suck as much oil mist as the other. It would be cool to see I guess. At the end of the day there would be little performance gain without going into intake runner lengths to the heads, cams, lack of or addition of a plenum chamber - and what size to use if going this route. Lots to mess around with. Lots to learn about engine design considerations and performance. Even better would be getting something to run reliably on methane… Cheers Bennie -
el_freddo replied to pontoontodd's topic in Off Road
Wow, that’s some damage to the outback! Will the plan be to straighten out the front end and go again or reshell the setup again? Cool that the flat towing went well. Over here in Oz we’d get hammered hardcore if we were found towing like that. Our laws state that the towing vehicle must be 1.3x the weight of the towed vehicle. So you can’t flat tow a like-for-like vehicle. But you can often tow one on a car trailer… We’re so backwards like that, and our authorities are complete Nannies about towing weights and vehicle weight limited etc. I swear our ADRs require lower weight limits than other markets. Anyway, I digress. Glad you got it sorted. Cool little solo day trip it seems! Cheers Bennie -
2.2 OBD2 swap into ‘85 Brat
el_freddo replied to Greentractorfarmer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’ve not heard of an “updated ECU” mod before. Unless that involves tuning the factory ecu which I believe is possible on some models. You might be able to swap in another ECU from the same model so long as it does not have the factory immobiliser gear associated with it. If it does you would need the matching ECU, key transponder and immobiliser module. As for that intake and ECU swap - pretty much anything that’s phase 2 (I believe that’s what your block and heads are) that’s NOT AVCS will work. But as you said, that’s another loom cut down. Out of interest, what knock sensor did you swap in when you swapped the engine into the brat? Cheers Bennie -
Ahhh, now I know what you mean. I’ve not seen one without the C clip inside the inner cup that retains the tri-thingy setup or the ball and cage setup - they always have one! Even without one, if the vehicle doesn’t come apart while driving or doesn’t hit anything (which would probably render the car useless anyway), then the inner CV “innards” should stay exactly where they are simply by design with how the driveshaft is held between the gearbox and the hub. Cheers Bennie
I think that’s a bit rich. OEM for sure is extinct, as you kind of hint at in your next sentence. I felt the need to say something as it’s not a correct statement. It’s a bit like saying the OEM 13inch diametre tyres are no longer available, and that you might find something aftermarket that requires some extra work. There are plenty of quality aftermarket external high pressure pumps for EFI that require little fiddling around to make them fit. @scooby2 - if your fuel pump is operating fine, it could be your fuel pressure regulator or the vacuum hose that helps govern the operating pressure of the system. Rare for one of these to die though. Cheers Bennie
*This is all just musing, I have no intentions on doing this... For now* I'm in a bit of a lull waiting on my EA82 getting rebuilt and that's given me time to think. I remember seeing an old rally video showing a race spec EA82. The dual-carb setup they had going got me thinking. What if you did a dual setup using two SPFI throttle bodies rather than carbs? From what I remember the carbs on the rally engine were basically set directly on top of the intake ports either side of the engine. I don't have extensive experience with engines and I only have limited experience to base my ideas off of. Regardless, here's what I'm thinking. An N/A EA82 with MPFI heads (for better flow) with dual SPFI throttle bodies. Setup a quad exhaust (would take some tinkering with the internally split single exhaust ports). Most likely setup with a custom ECU (megasquirt or something similar). The power gains wouldn't be what I'd be going after, rather just an experiment using an outdated engine for the fun of the challenge. Any thoughts? Ideas? Book recommendations to help me better understand the math of engine design? I don't remember reading of anyone doing this but I think it'd be interesting to see it done. Obviously there's a lot that'd have to be considered. Injector CC's, how to plumb the cooling system into the throttle bodies and engine block, sensor locations, etc, etc. I'm just thinking out loud here. :]
B and I worked on all three of my Subarus and his blue Forester a few weeks ago. Bunch of relatively minor stuff but I went through the front struts on the white Outback. They've been making some clunking/spring shifting noises when turning tight at low speeds so I suspected the steering bearings needed a cleanup. I replaced one and regreased the other, haven't noticed those noises since. While I had them apart I noticed the bump stops were split. Haven't seen this on our other cars but this is the only set where we made the bottom of the body bigger to allow the bumpstop to expand to give it more travel. Perhaps now they can expand too much. Regardless, I replaced them. We got the Ford van heater core and electric fan installed on the Impreza. Tried to figure out which front wheel bearing (I assume) on my 2001 H6 OB is making noise but even using B's multi microphone noise identifying system we still can't tell. Neither side is loose or seems to get hot but at least one of them is making a lot of noise. Definitely louder or quieter when cornering so I assume wheel bearing. We replaced one of the rotors we thought was pulsating figuring it'd be an easy try and it maybe pulsates less but did nothing for the noise. The next weekend we went to the UP with some in laws/friends and went trail riding one day in the Impreza and Outback. Stopped at a gas station after some trail riding and I noticed the temps on the Impreza were creeping up so we pulled over, fuse and relay seemed good but driver's side fans were not running. Without the AC on temps didn't creep up too much even in the sand. I made the mistake of letting a novice drive the white Outback without me in it. Then I noticed the Outback was pulled over with steam coming out of the front end. Driver claims the brakes weren't working. It has some serious lower front end damage after going off the trail a bit and hitting a log. Lower radiator support and skid plate and bottom of engine very smashed. I think the front fenders, lights, crossmember, and possibly hood are still all in the right spots. In the long run probably the biggest downside is I’ll have to replace the head gaskets on my spare ez30. As we were pulling the car back on to the trail, I realized that we’d lost the rear bumper cover somewhere. Hooked the tow bar, lights, and safety chains up and started towing it north on the trail. Not too far down the trail we got to a big steep drop but it didn't look terrible so we went down that. Kept it under 20mph, looked it up later and that's apparently the safe flat towing threshhold for the 4EAT for a max of 30 miles. Still curious what exactly fails if you flat tow it too fast for too long. The rest of the trails weren't much of a problem and we eventually got back to pavement and aired back up the tires on the Impreza to 40psi. Flat towed white Outback to the closest town and asked the guy at the grocery store if it'd be OK to park it there overnight. He said one night would be fine. I couldn't convince others to retrace our steps and retrieve the rear bumper cover mainly since it was going to be dark soon. Most of the rental, almost all Uhaul, places were only open a few hours on Saturday so I either had to wait for them to open or by the time they were open I wouldn't have been able to get to them before they closed, had to talk to one guy for a bit to figure out how to get them to rent me a tow dolly. I did a test drive of my dad’s 1987 full size 3/4 ton Dodge van, seemed to be running rough but not terrible. None of my primitive engine tuning skills seemed to help. After a lot of calling around I drove the van an hour to U haul to pick up a tow dolly. On the way there the engine starting making noise and I looked at the oil pressure gauge (blocked by my hand in a normal 10-2 driving position) and it was reading nothing. Pulled over, after a bit of looking around figured out one of the oil pressure sensors had started leaking badly. We've had this happen on a different full size Dodge van probably 20 years ago. Fortunately there are two sensors on this one going into a tee so I was able to take that apart and just put in one sensor. Dumped some engine oil in and proceeded. At the rental place the lights on the tow dolly didn't work. Wasn't getting power at the four pin connector but had power at the six pin connector (both on van). They of course had just run out of adapters. So I drove to the local Ace and picked one up, drove back, plugged it in, right side light on tow dolly not working. Hooked up to another tow dolly with functional lights. Drove about two hours back up to where we'd left the Outback. During this driving I'd realized I didn't have the keys to the white Outback. But I did have a coat hanger and a screwdriver so I was able to get in. Fortunately for whatever reason in that car you can shift it into neutral without turning the ignition on. Lined the tow dolly up with the car and backed the van up to it. Pulled the car onto the tow dolly with a come along (hand winch). Strapped it down, looped safety chains around the control arms. Then I realized I should have unbolted the rear driveshaft sooner but I was able to just get all four bolts. Was able to strap the driveshaft away from the rear diff so it didn't rub (I assume). Towed it about 1.5 hours back to the cabin. Chocked the rear wheels with some chunks of 4x4 and set the parking brake and drove the tow dolly out from under the car. Sunday morning I drove the tow dolly back and left it at the rental place, a two hour round trip. We drove the van back in addition to the two other cars we drove up there that still ran. Impreza temp gauge was right in the middle even with AC on in 95F weather on the highway. After returning home and tracing the fan wires from the fuse box to the fan I found that one of the pins for the main driver's side fan had pulled out and the connector looked melted. It would still occasionally run when I was pushing or pulling on the wires so I think it was just loose in the connector. Replaced the stock connector with spade terminals and heat shrunk/taped/zip tied everything back up, they all seem to run now. Drove Impreza to the cabin the following Friday morning. Strapped RF of bumper to engine. Removed front CV axles and replaced with loose OB Cvs I found in the basement. Unloaded flat towing equipment and put in Outback. Saturday morning I drove to the end point of our trail riding, filled up with gas, and retraced our steps backwards in search of the rear bumper cover. I figured I now had most of the rest of the day to kill so I'd do some mild trail riding/exploration on the way back. Impreza seems to spin the tires with less forward traction with the tires at 45psi as I had them that day than the 25psi I'd normally drop them to if I'd known I'd be trail riding as long as I did that day. I tried to do a big loop south of where I found the bumper cover. At the start it seemed a bit narrow/overgrown but there was a Forest Service trail open sign so I decided to go for it. Parts of it were very overgrown. Eventually there was a large tree that had fallen blocking it. I drove around the other half of the loop and got back to the fallen tree. There was no way I was going to do anything about it without a chainsaw, which I did not have. Checked out a stunt area I'd found on the satellite that had one big hillclimb and drove a side trail near the top of it. No intention of trying something like that solo so I moved on. Went to the end of a road on the map, figuring I might as well see where it went, turned out it kept going for miles with various side trails, none of them on my map at all. Went by a few old cabins along a river that looked like they hadn't been used in years but in decent shape. Drove down some roads that definitely seemed like they were just for logging, some of the steeper ones were even pretty nicely graveled. Eventually I was heading south on a nice wide dirt/gravel road and getting closer to a paved road we've been on many times. There were a couple of large boulders in the road but they could easily be driven around. Didn't see any signs on either side but decided not to drive past them. Also I think where this road comes out to pavement there might be a large berm. There was also a wide smooth road heading north from the “blocked” road but it had tall grass growing in it so I decided to skip that for the day and head back the way I came. On the way back north as I was heading by the old cabins I caught up to some locals driving UTVs. Each one had a guy in his 70s and one in his 20s. The younger guys were pretty entertained by the Subaru and they all kept asking how it did. I told them the trails around there were no problem for it. I asked about the cabins and they said the one we just passed by used to be theirs, they had a year by year lease with the forest service. Then it was declared a scenic river and hundreds of people lost the use of their cabins. Where we stopped was another one with a similar story. I asked about the logging roads and the big rocks and they said the logging company that has the contract for that section of forest tries to keep people out from tearing up their gravel(!) logging roads. They pulled over to let me by and I kept driving north until I eventually found a different way out. I got back on the highway and found a waterfall I'd seen on a 40 year old Michigan county map. The “trailhead” is a gravel spot big enough for one car along a gravel road with a rope tied around a few trees heading into the woods. No sign or anything. Hiked into the woods, trail was easy to follow, found the waterfall, pretty cool. Near there I went down a dead end forest road and encountered this turtle. When I got back to the cabin I set up the flat towing hardware and did a test drive. Seemed to do OK but tire was still rubbing on the tape I'd put on the end of the front bumper so I cut that off with the recip saw. Had some dinner and went to bed. Got up Sunday morning, packed up the car, checked fluids, aired up the tires in the Outback, and headed south. Flat towing went as smoothly as possible. Impreza has good power and bigger brakes than stock which helps. Temp gauge was right in the middle all weekend, even when towing, climbing sandy hills, AC on, etc. Left tow bar connected, drove Impreza in garage, disconnected tow bar, slid rear of Impreza sideways with a floor jack, drove Impreza out, pushed Outback in garage with Impreza.
- Last week
Greentractorfarmer replied to Greentractorfarmer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bad memory on this one, I can’t say for sure I’ve run it without the sensor connected. I did swap the sensor for a new one after the swap from wagon to brat, and no difference. I’ve been doing more reading in the forum about replacing knock sensor with resistor, so I ordered a pack of 560K’s this morning. The car is away at a mechanic’s yard so I’ll be reporting back to answer this later. There seems to be differing opinions in the reading about the safety of running the engine with resistor or mounting the sensor off-block. But a trial would maybe tell me if that sensor is giving ecu reason to pull the timing. It feels like a more drastic kill then kick, to me. We’ll see, next week. What about ‘up-dating’ the ecu? Anybody have a resource for that? I also came across this opinion in one of these threads: that changing the intake complete could be a sure solution, which I’ve thought about, maybe with another year, complete with its ecu. I’d like to avoid cutting down another wire harness, tho, and don’t have knowledge about which intakes will cross over to my 2000 obd2, Californicated. It’d be nice to have something a bit simpler, if that could work. thanks. -
itstoobright joined the community
Next on the agenda is replacing the axle stub seal on the driver side. I was able to get the seals from a dealer and they showed up yesterday along with a new alternator mount bolt.
EcstaticPeacocck joined the community
bushytails replied to Greentractorfarmer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Same question, different sensor. Does the bucking go away if you unplug the knock sensor? -
No, the problem continues when the purge valve is disconnected. I got the car to a mechanic yesterday, and after reviewing the data with his scanner, and doing some research, he thinks the knock signal may be too sensitive. If the knock is sending a false signal to the ECM, it will pull the timing 10 degrees. I had also seen with my reader, with the live data, that the timing would advance 10 or more degrees when throttled up, but considered it normal, and couldn’t see that it corresponded with the misbehavior of the engine. Anyway, he says the service bulletin says to replace the ECM with an updated one and that people in the forums have been placing a resistor before the knock sensor. Anyone heard of this treatment? Or does it sound reasonable? -
Current trend is "almost nothing is available, and what is available is usually garbage", alas...
