  1. Tap the 3-dot menu (ā‹®) in the top-right corner of the browser.
All Activity
This stream auto-updates
  1. Yesterday
  2. www.car-part.com If you have a you pull it yard close by, just go in with your drill and drill out the bolts and get the complete assembly.
  3. Last week
  4. Oof, the hits keep on coming. Between life happening and that stint where the forums were down - I hadn't had much time to update this, but today I took the time to get things moving a bit again. Long story short - I decided the simplest thing to do to solve the rubbing problem as it currently exists was to cut the tack welds and shift the whole subframe back about an inch, rather than doing a whole bunch of complex bodywork. My bodywork skills are definitely not my stronger suit, so I figured I'd better make things fit to what's already there as best I can. While this job was harder than I thought it was going to be (I had to cut out a larger section of the bed to get my cutting tools in there), the wheels now sit squarely (loosely) in the middle of the arches. To continue the spirit of solving a problem by creating new problems to solve, now I have to modify the original rear diff crossmember to make up for the distance the entire assembly has moved. Probably going to knock that out in the next couple days. Basically for that I'm going to cut some chunks out of the existing crossmember , then offset them with lengths of rectangular or square tubing of similar cross section. It shouldn't be too difficult because the stock part is basically a piece of straight U-channel with bushings mounted through it. No weird bends or offsets to be had so as long as I modify it so the threaded holes move directly rearword, it should be a pretty quick fix. Once that's all done it'll be a temporary modification of the stock lateral links to bring everything a little tighter in towards the frame, then I'll get started on fabricating the strut mounts in the bed, and probably remeasuring everything to see about finding an off-the-shelf set of adjustable lateral links and trailing arms that fit, and then another semi-permanent modification of the rear CV axles to get those back on. I'll likely need to revisit the wheel arches in some form or fashion, but I'm hoping I can get away with just some good ol' fender rolling. Time will tell.
  5. So I have a 98 Impreza and I’m trying to find a new ignition lock cylinder to replace mine. The previous owner left just the tumbler and not the entire assembly. I cannot find the replacement for a 98. I find 97 but not 98. Find every year after as well. I can find the ignition switch just not the full assembly. Any help would be very appreciated. Thank you.
  6. PhoenixPhire joined the community
  7. ButtrockRockwight joined the community
  8. Watson_Derthehood joined the community
  9. subaruwillisco1940 joined the community
  10. StaticFoz joined the community
  11. winstonr1 joined the community
  12. 3 hours start to finish engine trans diff driveshaft axles mirrors ecu tcu fuel pump radiator and condensor out. nothing els worth keeping. and thats including driving it out of the woods and cleanup time.
  13. well i started i opted to just unbolt the trans and pull em seperatly. stripping a car is so much quicker when you dont care about the car the parts are coming out of.
  14. My bad, I think I got one of the pics backwards in my head, and thought the cam was totally ruined on both ends... the rear journal doesn't look totally ruined. There's still definitely some scoring visible on the cam in both the center and rear, though. But if it has a knock, it's time for an engine anyway.
  15. So the rear journal isn't good either. I would describe the front journal as trash where the cam had a definite wobble and the aluminum is creeping up the shaft. The AVLS ports look ok, other than a bit of sediment in the filter screen. The engine was run low on oil at one point and had developed a slight knock at idle so I was leaning toward a JDM replacement anyway, but this clinches it. The oil pump was resealed at the previous head rebuild.
  16. It looks like the cam ran without oil until it seized, from how trashed the rear journal is... If I were you, I'd probably be looking for an engine, not just a head. Would be a shame to put a new head on and then find the bottom end looks the same.
  17. i do not have a lift im honestly not opposed to cutting the subframe and radiator support ither. as far as junk yards not many left. chuck and eddies is prety much the last pick and pull i know of. boyds in norwich will still give a good price on a stripped out car. there wont be much left in this one thats still good. the driveline was the only good part of the car.
  18. Cam is broken The far end of the cam (non sprocket side) isn't seized, or at least it isn't now. Spins free, supported by the end and center journals. Probably seized at some point. Sprocket side journals are 'remodeled.' Will take apart the AVLS assembly and look at the oil ports. top view passenger side head broken cam cam wear cam fractured non sprocket side cam journal cam journal sprocket side center cam journal cam cap sprocket side cam slot
  19. Sometimes if it’s possible I’ll cut away the radiator support. Part car going to tue yard would be a candidate. Hey you’re in CT too, right ? Which yard(s) are you dealing with these days?
  20. I've pulled them attached. Yes the angle is significant. The other way to do it is to drop it out the bottom. The cross member and trans mount will unbolt. Raise the car or lower the cross member/engine-trans.
  21. Yes it can. But the angle can be quite extreme. Better way to do it is separate the gearbox from the engine and pull them out from the top individually. You’ll spend quite a bit of time under the car disconnecting mounts, driveshafts, wiring etc. Remove the gearbox crossmember to give more room if going for the one piece removal.
  22. im pulling the engine trans and diff from a part car and sending the car off to the yard. i dont want to lay under the car and manipulate the transmission down. will it come out the top still bolted to the engine? 2001 legacy sedan
  23. Agree. Given the wobble at the sprocket side I'm pretty sure there is damage to the head.
  24. Sounds like a broken cam... Probably going to need a new head, since I can't imagine the journals are still good.
  25. Earlier
  26. Could be given what I found. Got the cam sprocket off. The head of the cam itself has a wobble. The intake ports in the head were half full of fuel, valves are tight apparently and certainly not moving. No cylinder compression from lack of valve movement.
  27. Good luck! I'm more of an lift-and-big-tires wolfy myself, so have never gone to such an event.
  28. bushytails changed their profile photo
  29. Intact factory wire routing keeps it away from the joint, but the clips and such tend to go missing after the first mechanic works on it... Attached is a couple more googled pics, of stock routing on a similar subaru, and of what happens when it's not in the clip. Just zip tie or otherwise secure the wire away from the joint.
  30. Ok thank you so what was it just a poor design choice by Subaru where they put it? šŸ˜… Like im pretty sure the cv ripping out O2 sensors really should not happen to start with..lol
  31. I don't have one of those, but here's some google-fu. The sensor wire is always pretty close to the cv joint, and I've seen more than one get wrapped up and ripped off.
  32. Hi does anyone by chance have or can get some pictures of the location is of the upstream O2 sensor on the exhaust system.. someone at some point before i bought my subie removed the cats and for some unknown reason removed/replace the pipe the O2 sensor screws in and I can't seem to figure where it's supposed to be positioned currently where i have it the wires wants to rub on the CV boot which is probably not really good for it. In thanks in advance for whoever helps.
  33. Have some pictures to include with this post but site isn't taking them at the moment, will probably add later. Wife and I went on vacation for 11 days through AR, OK, and TX. Didn't really plan on doing any off roading but it'd kinda hard to avoid in AR. Met up with slammo for a day in his RAV4 prime. On our way to the beach in TX looking for the camping area he got stuck in soft sand. With the folding recovery ramps and a couple straps I was able to pull him out. Before swapping in a lower temp thermostat, engine seemed to plateau at about 215F CTS / 200F upper radiator temp while driving. If left to idle for a while it would slowly climb up (small fans kick in at 215F) until the large fans kicked in (220F), then they seemed to run indefinitely. Yesterday B came over and test assembled as much as he could of the billet knuckle conversion. Got his pair heat treated and painted. Bore for the long bolt/stud being tight was the biggest issue. I got a couple different ball hones but neither of them seems to remove material very quickly. Calipers with new pads seem to just barely fit his worn front rotors. He already swapped new ones on the front. We also had all of the lateral links painted, he got those anti seized and assembled. My main plans were to figure out the wiring issue on the Impreza and swap in a lower temp thermostat and bleed the coolant. On our recent vacation the delayed accessory power stopped working. Was still getting some voltage from its main battery feed but not enough to actually power anything. At the time I just hotwired it to the stock cig lighter. Turns out it had blown a fuse in the underhood fuse box, not sure if I checked those during my initial diagnosis. Cleaned up the wiring a bit put it back to how we had it and seems to be working now. While I was draining the coolant I had the bright idea to replumb the Ford heater cores we'd added under the hood. It seemed that with both of them in series on the heater core circuit the second one wasn't doing much, the first one seemed to cool it almost to ambient temp, and that circuit is a pretty small portion of the coolant flow. So I decided to plumb one of them into the circuit that goes through the oil cooler, figuring that would also cool the oil better. When I started I didn't realize those fittings are about 1/2ā€, not 5/8ā€ like the heater hoses and cores we'd added. So I made up a couple of barbed adapters on the lathe. It was a bit of a pain to get the hoses routed but I think it turned out fairly well. Then I drilled a 3/16ā€ hole in the top of the 78C (172F) thermostat and swapped that in. I'd had a stock 82C thermostat in it. Got a bleeder funnel recently too so we used that, no idea how much better that works than the normal method of just filling it up and driving. This all seemed like an improvement. When idling it would still eventually get up to 215F but once the small fans kicked in it would cool back down to 210F (where the fans shut off) and then slowly go back up. The only issue we noticed was the heater core circuit wasn't getting hot or even warm. I pulled various hoses off in that circuit with the engine running and just a trickle of coolant would come out at idle. I pulled both hoses off at the engine and backflushed it with compressed air and it seemed to flow great. Heater had been working great before all this. Eventually I just decided to drive it and hope it fixed itself. Which it pretty much immediately did. Maybe just needed some revs or jostling around to bleed. Regardless, it now blows hot air when you turn the heat on and both heater cores underhood get hot. Also seems like it takes less time for the little fans to bring the temps back down. While driving the temps seem to plateau at about 200F/180F so that also seems like an improvement. Will drive it a bit like this, maybe lower the fan temp at least for the small fans.
  34. Hey all, just started doing rallycross events in Washington/Oregon with my stock 1988R RX. one event under my belt, & put the old girl through the paces! was on track to place 4th of 10 in the stock AWD class till i spun out in a corner transitioning from a field to asphalt, ended the day at 7th. Don't suppose there's anyone in here that goes to the NWRA events? I'm doin my best to keep the RX in the stock class for this year, tired old EA82t starts acting weird when it gets hot (190-205). next race is in Spokane in May, if you're there, stop by and say HI! i'll be camping at the track Fri & Sat nights.
