Everything posted by Camelwagon
Radiator and temperature question...
Ok so where should the temp gauge be on an 85 GL? Mine is going up a bit past half but no further, is this ok? And also, this weekend i flushed and replaced the coolant and found that the radiator petcock valve is on the side of the radiator, half way up. What the freak? Why do they do that, it probably only drained half the radiator. Is there another drain valve on the bottom of the radiator that I didnt see?? Let me know please, thanks....
VACUUM hose diagram??
Hm ok i'll see what it is. Thanks...
Does anyone have a vacuum hose diagram or is there a website with one for an 85 GL carbed, 4x4, 5spd?? Thanks.
Clutch fluid on 85 GL?
I'm wondering if the 85 GL 5spd carb has clutch fluid or not? I dont see any other containers in the engine bay besides the brake fluid..?.?.? Thanks.
85 Wagon wont go over 30MPH
Have you given it a tune up lately? Tried fuel cleaner stuff? Any vacuum hoses leaking? So if his choke's stuck would WD-40 help get it unstuck? Or is it more complicated than that?
loyale fuel filter change procedure???
So on the 85 GL the filter is under the car near the tank right? And theres another one in the engine bay? I dont/cant seem to find that one... Thanks.
Fuel filter location?
Hm you've got a different and interesting engine. In my engine, theres nothing in that area except the wiper motor. No one else has an 85 GL 4x4 EA82 engine?? Thanks.
Caleb - I dont think thats where the fuel filter is, I think thats the windshield wiper motor in front of the firewall.
85 EA82 dual range stick, or GL10 Turbo Auto with Push?
So what are the main differences between the EA81 and EA82? And what are the pros and cons? I wouldnt go for the automatic either cuz its sluggish.
Electrical weirdness question
Ok so I just got an 85 GL wagon 4x4 and it has some electrical problems. When I turn the lights on and turn the blinker on, the lights and inside dash lights start blinking like the blinker. Whats up with that? Weak battery or alternator? Or some connections or leads have to be cleaned? I cleand the battery leads. It starts up fine every day... Thanks.
I'm new, some info...
Now when i have my lights on and i use the turn signals, all the lights blink like the blinkers (headlights, inside dash lights). Whats up with that? Its like it doesnt have enough juice. Any ideas? Thanks.
Cool, thanks guys. Is there only one fuel filter?
Hey does anyone know where the fuel filter is on an 85 GL wagon, 1.8 carb? And also where is the pcv valve?? Thanks...
My Suby suspension problems...
Well I just got an 85 GL wagon 4x4 and today I took it to a shop to just have it checked out and they found that the left rear and the right front wheel bearings are bad. Are those easy to replace myself? You just repack them with grease right? I remember a firiend saying they are easy. So wats the worst that could happen if I dont fix them? Then they also found that the inner and outer tie rod ends and lower ball joint in the left front is kinda bad too. What do those do and again, whats the worst that could happen if i leave them the way they are? I probably wont go 4x4ing at all, i'll just use it in the winter a bit. And also, is there an online manual for any make of Subaru? THanks.
Spokane wrecking yards?
Wow are you guys all from Spokane? I am too. Whats a good Subaru shop to take my car to besides Appleway Subaru which is expensieve.
Any advice for a new Subaru owner?
Camelwagon replied to caddywhompus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool, thanks. Well I checked my manual tranny fluid and it looks really really clean, so I probably dont need to change it right? Hopefully. Thanks again...
Transmission fluid, filter and diff fluid
Camelwagon replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see.. thanks. So is it easy to replace the manual tranny fluid and the differential? Need special tools? Thanks.
Thanks guys, i'll look at it this afternoon. Pics would be nice to see. Another problem it has is if I dont drive it for 4-5 days, the battery dies and i have to jump it. Do you guys have any idea what might cause that? Alternator? Thanks, later.
Camelwagon replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo what kind of fluid goes for the 85 GL wagon 5spd? And also what kind of differential fluid? Thanks.
Camelwagon replied to caddywhompus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm thanks but i dont wanna get stuff in the mail. I hope there is a better way to get the maintenance schedule. Thanks.
Camelwagon replied to caddywhompus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm a new Suby owner too, and am wondering what is the maintenance schedule for these cars? Is it posted on the net somewhere? Thanks.
Hey guys I'm new here. I have an 85 Suby wagon 4wd. I read somewhere that the suspension is adjustable manually? Is that true? How do I do it? And also I read that it has a hillholder clutch? Whats that? Also, is it easy to replace the manual tranny fluid? What kind does it recommend? Thanks guys.
