Everything posted by Camelwagon
87 gl wagon losing power when trying to accelerate
Mine is losing power and shuttering and shaking around the 2-3k rpm range and after that its fine. It happens in 1st thru 3rd gears... I think i have a miss somewhere though.
Failed emissions - HELP
Well seems like my carb needs rebuilt, had it checked by an emissions guy and he says i'm not getting enough fuel in there somehow, its running lean either way I turn the mixture screw. Very weird. Not sure if he's right or wat but he showed me on his emissions computer, he turned the screw from all the way left to all the way right and the HC's were really high either way. And NOTHING works, i tried a couple bottles of HEET and denatured alcohol and that "Guaranteed to Pass" crap AND Seafoam and nothing helped, still failed emissions. He also squeezed the PCV hose and the HC's went down pretty low so I'm not sure wats up with that... And he says i have a miss but says that probably not whats causing the HC's. Oh well. Any ideas?
UPDATE: Emissions Problems in the BRAT! Oh no!
Well seems like my carb needs rebuilt, had it checked and i'm not getting enough fuel in there, its running lean either way I turn the mixture screw, doesnt change much. Very weird. Not sure if he's right or wat but he showed me on his emissions computer, he turned the screw from all the way left to all the way right and the HC's were really high either way. And i tired couple bottles of HEET and denatured alcohol and that "Guaranteed to Pass" crap and Seafoam and nothing helped, still failed emissions.
twin hitachi fuel mixture settings
What are these?
Hey 1985GLWAGON, by the way the date of manufacture for my Suby is 02/85 so not too far off from yours. So where exactly is that hole supposed to be again? Thanks.
Idle and Timing Interdependency
For the EA82 is it supposed to be at 8 degrees for normal?
So which way do you turn it to advance?
Can you clean the EGR valve?
Can you use water and then let it dry off?
So how exactly do you advance the timing? I've been wondering this for a while now. I know you turn something in the distributor?
Cool, thanks. Will it drive and idle well with alcohol in it?
IS there a way to clean the EGR valve? And how? Gotta take it out to do it? Thanks.
Is it true that taking out the air filter might help in passing emissions??
seattle residents:emissions question
I hear if you take your air filter out, it helps with passing.?.?.?
My 85 GL didnt pass either, high HC, 400, standard is 220. But passed CO, in fact the CO was very low, .04 and standard is 1.2. They say that my timing needs advanced a bit, does this sound correct? Sounds like its too lean too, thats what high HC means. Thanks.
Can charcoal canister be cleaned or replaced?
Can the charcoal canister be cleaned or replaced? And how to clean it? I'm just wondering if that would help with emissions or making it run better... Thanks.
Well, I failed emissions again yesterday. But its getting better, only failed at HC this time. It was way high like 400 and should be 250 or something. CO was real low like .04 and normal is 2.9. So I'm running way too lean right? Any other ideas? Thanksss.
Hooray; the Brat passed emissions today!
Hey now dont misuse my name without permission like that Ed... :)
Unconnected hoses...
Finally got it like yours and it runs fine. Thanks.
It looks like you also have an unconnected nozzle right above your finger, on the air box..?? Ok I think I got it finally. So the blue one is the same as the red string one that goes to the nozzle on the right that I have nothing connected to?? So I just need a piece of hose from the metal piece to the nozzle. Ok so then the other end of the red tape one goes to the canister also right? The red and blue are these 2 on my pic below right? Ya I definitely dont have that black box thing on the passengers side. Hmm. Maybe mine is blocked off for a reason. Thanks man, appreciate it.
Is this the idle screw?
Hey Moshem, my right screw was turned like 15 times to the left. I'll see how it runs now...
Hey, its dual range. I'll check on the date of manufacture.
So Ed, why is your brat gonna be exempt from emissions in 2 yrs? What's gonna be the cut off year then?
EGR valve, EA82
Dude sorry but I have no idea what you're talking about, safety, bomb...?.?
Transmission fluid, filter and diff fluid
Camelwagon replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTheres a front differential too?? Or is that just the tranny? Have you replaced your rear diff fluid? Are the bolts on the side or at the bottom? How do you get the new fluid to stay in there? Thanks.
Fuel Adjust Screw
Ok so you turn it to the right till it stops? And then turn it to the left a few turns till it runs smooth? And then adjust the left screw, the idle screw? Thanks.
