Everything posted by El Toro
Adventure Subaru II - 2000 Legacy Outback - Go anywhere/do anything wagon!
Looking good!
- ADF LIFT AT WCSS17!
Anyone interested in a non-off road cruise?
Think they might get bent if we show up in some ru's? Our rigs have euro like qualitys but .....
No Flow? my freak cooling system
it feels.... well .... normal. so on advice from a bud i jacked up the front end and started the car ( kids don't try this at home) now the car would shift fine. however as soon as i pushed in the clutch and started to put it in first the tires started to spin. again under advice to free the clutch i revved up the motor pushed in the clutch and hit the breaks. ( took some finagling ) sadly this did not free it. so i think im doomed to yank the motor once again. :dead:UGH:dead:
No it was a 4x4 would some wd40 be a bad idea?
The cable seems good. Snug. But now I wonder since it was out side for 6 months under some cover that it might of rusted together .....
Ok... new problem . So I clean up the 88 donating motor that had a good clutch on it and drop it in. Set tdc drop in my distributor. Turn it over and vroom! Sounds great ! Then I,put it in gear........or try to put it into gear. With the clutch all the,way in it will not shift. It's like a wall. I kill the car and manage to put it in first with some effort . Start the car and it lurched forward . What did I do now ? Ugh
Cool thanks! I have ditched the ais long ago when i did the weber . New motor is preped and just about ready . Why subaru only gasket? Will take them a while to get the part they said.
Well in a turn of events a motor from a 88 gl was donated to me that,was pulled from a running car. One thing.....its fuel injected. So I figure pull intake and all attached and swap it with my webber setup . Noticed the distributor had a 4 prong plug on it Mine is a 2 wire no plug. Can I just use my distib? What else can I expect
My car has gurgeled off and on for 7 years now so u might have some more miles than you think left . Is presure washing the funk off a bad idea?
Well turns out its the head. Sad day. Well el toro will be down for a while. Any advice for a first time head repair? Clutch needs replacing so xt6 clutch upgrade ? Any other thoughts
there was a bit of gurgle the other day.... hmmm. slow head gasket leak? the hoses are fairly straight
Riddle me this..... my cooling system and I have been going rounds! little background- 1986 lifted ea82 non turbo. Replaced rad, water pump, thermo, hoses, all but heater core. So the problem! One its intermittent. my motor will start to over heat and then cool down. sometimes it will over heat and not cool down. last night i pulled over too see what was up. rad cool, heater core hoses cool thermo hose warm not hot. kicked motor up to 4 rpm and it would cool off, under 3 rpm heat up!? so a flow issue? but pump is new. and he has been burped. any ideas? HELP!
Fusible link blown now mid fuse box row toast...help?
all right. the switch was toast. busted out the ole' light bulb and wire circuit and checked the back side of the switch. good power in, no power out. replaced it, still no start. then found 3 fuses popped in the center row. replaced them and he turned right over. now the charge light is coming on dim and the charge fuse is good but the bulb is reading a low amount of power to it. hmm. if it aint one thing its another.
he did put the charger on backwards. sad. oh well. sorry i did not give the whole story like a newb. its a 88 4x4 gl wagon spfi. after finding a wire diagram i think it might be the ignition switch. it is the one thing between the link box and the center row of the fuse panel. now to find where that is:confused:
ok so this is how the problem started... my father decided to charge the battery on my spare ru and in the proses he some how shot the black main fusible link. needless to say i told him not to touch the car again. so replaced the link and the car would not start. took out the volt meeter and all links checked out, battery checked out, main fuse box... center row ( fuel pump wipers etc) dead... i do plan on running down the wires and following it to where ever the problem lies just hoping some one might of had this before and knew the solution.
Taller front springs
well torxxx? how did it go?
Brat Stolen!!!!!
Try a shout out on CL. all Subaru nuts check in every day and live everywhere. might be more folk looking for your rig. good luck
Extra cab brat anyone?
only if the fires keep up:dead:
the inside is really comin' together. killer set up. get the picks up man!
i had a chance to sit in it last night and WOW! I'm 6-3 and 250lbs and it fit like a Cadillac! the 4-runner seats were able to scoot back a tad farther than the stock ones and recline to well over 45. roooooomie! plus at first glance you could not tell anything was different. if you were not a Subaru nut you would not know the difference. the lines are flawless. not so much of a S%$# can any more, eh mntnman?
Tahuya Trail Run Sunday Feb 17th, pictures added
Im in. but cant make it till 1. what cb chanel you on? hope to see more ru s
Four wheeler Magazine
closet holly roller:lol:
