Everything posted by jamal
high speed braking shimmy
jamal replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow do your tires have broken belts and won't they possibly explode at any minute, especially when you're driving 100mph? I'd think until you eliminate that possibility there's no reason to worry much about anything else. And yeah, 3rd's good for 110 with my 4eat and 3.9 fd.
Outback struts on a Legacy? YES!!! Thanks.
jamal replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the point is to prevent the bite from getting infected. back on topic, the outbacks have taller swaybar mounts to put it farther from the body. You should be able to re-attach it with the car on the ground, so do that at least. You probably don't need to get new mounts.
94 legacy touring wagon
jamal replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell he said it was n/a. Doesn't that make it a GT?
Subaru AWD vs. competitors
jamal replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA little biased I'd say but I suppose that's expected. B9 sits there spinning all four on the rollers, then he backs down to get a run up it. "look how easy it powered up the rollers!"
Struts on STi
jamal replied to rosyposy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEdit not quote.
Struts on STi
jamal replied to rosyposy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEariler ones clunked sometimes. Here are some discussions about it: http://forums.nasioc.com/forums/showthread.php?t=1098232 http://forums.nasioc.com/forums/showthread.php?t=520870 I suppose the addition unsprung weight could cause accelerated strut wear but it doesn't seem very likely to me. Struts don't usually get replaced under warranty I don't think anyway.
upgrades for '93 impreza
jamal replied to damien_summers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhuh?
jamal replied to damien_summers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get a few extra HP with a freer-flowing exhaust and maybe some cams. Borla and OBX headers for a dual port will work for you and delta makes cams. There are a lot more options for suspension/brake stuff. There is quite a bit available in the aftermarket in that area, it just depends on what you want and how much you want to spend.
'93 Legacy stereo upgrade
jamal replied to TheBears's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, you can get a 1.5DIN pocket. I just had a piece of black plastic in the 1/2 din gap although now I'm looking for something cooler. I used to have a sony cd player that stopped playing cds, so I bought a 6-disc changer from an 05 wrx. Unfortunately it wasn't plug and play, but if you're going to buy something else you'll need to make a harness anyway. The CD player you buy will come with a harness, then you'll need a harness for your car, and will want to splice the wires together. Here's my writeup of the install. You'll probably also want to check out the rest of that site.
CEL,just swapped engine
jamal replied to montana105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPulling the code(s) would be a good first step. Directions are here.
Wheel nut torque?
jamal replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter I hand tighten them I'm usually within less than a full turn of spec, which I think is probably more than adequate.
Wheel nut torque?
jamal replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBecause alloy wheels are softer. This says 67-70 lb-ft, which I haven't had any problems with. 80lb-ft is apparantly about the tightest you want because of the strength of the threads. I'll flip through a machinist's handbook at work tomorrow to see if that's true.
Good info sites on technical aspects of subarus like hill holders?
jamal replied to JM1NA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXendwrench, the subaru global site, and cars101 all have good technical information, along with all the message boards out there.
E V I L thoughts
jamal replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually that GM 4-cyl is very, very durable and capable of good numbers on stock internals. There's a drag racing manual made by GM floating around that details how to make up to 1000hp with it. Actually I have it right here (28mb pdf) if you want to take a look. Plus I wouldn't want my turbos under the car towards the rear where all sorts of rocks and junk will get flung up at it.
E V I L thoughts
jamal replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah those things have been around for awhile. Pretty terrible idea IMO, and I doubt there was no room under the hood. The exhaust going into that turbo is going to be pretty cold and going pretty slow, and look at how far the piping and coolant have to go. I guess this way you don't need a new exhaust manifold, but the supercharger from the cobalt SS would have been a much better and easier way to do it. Those shows kind of piss me off in general. I guess rides is better than pimp my ride though.
90 legacy question
jamal replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno you can pull the ecu fuse and there is also a procedure to just clear the codes. They're both explained in the link I posted.
90 legacy question
jamal replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll you need to do to pull the codes is connect the black connectors under the dash, turn the key to on, and read the CEL flashes. It will cycle through all the previously stored codes. Legacy777 has a guide on his site that also lists all the codes. If you have a laptop, you can also build a cable and use a scan tool vrg3 made, and read parameters/codes in real time.
a few questions
jamal replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsometimes mechanics forget to tighten things. I got an alignment awhile ago and had kind of a strange loose feeling on right corners. When I pulled the left front wheel off to take a look I found the bolt that attaches the strut to the knuckle was loose. Hopefully mentioning that will get me a free alignment after I install new balljoints and camber bolts next weekend. It is probably something with the caliper though. It's probably a good idea to take it back and have them make sure everything is tight, the slide pins are in good shape, and the rotors are straight. If you brake hard does abs kick in and work properly?
a few questions
jamal replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin fact, overtightening lugs is the only way to get warped rotors assuming they were straight in the first place. How long were they on and were they bedded in properly? I kind of doubt the problem is thickness variation so maybe a caliper bolt is loose or something. It could even be an alignment or wheel balance problem or something loose or damaged/worn out in the suspension/steering.
What's the LOUDEST HORN!
jamal replied to Equalizer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI quite often wish I had louder horns. Plus the stock horns sound pretty wimpy. Hmmm, I'd never heard of Fiamm. They're less than the Hellas, which I planned to eventually buy.
considering replacing motor mounts...
jamal replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get a lightly used set from someone who swapped to group N mounts on the cheap (like $40 at most). I have those liquid filled ones and they're pretty soft. I plan to replace them one of these days.
Subaru gave me something cool!
jamal replied to Flowmastered87GL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a pretty funny letter from a dealership. It said to come by as possible because there is a high demand for my particular model and they want to buy it right away. I'm sure people are in dealerships every day asking when they're going to get the next shipment of 93 Legacies. I almost called them to say that I felt insulted that they thought I was going to fall for that.
jamal replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy car vibrates a bit more than usual when the ATF is low. Have you checked that?
Is shifting an automatic OK?
jamal replied to Audiophobe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfolder
Headers for my wagon???
jamal replied to Danbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA couple of triangular support flanges would probably take care of it actually. I've wondered if maybe having worn motor mounts or not a flexible enough flex-pipe was the main contributer to this. Or maybe it was crappy construction. Was it your header that just had a couple of spot welds? Has anyone had one of the new ones that are supposedly better crack?
