8
Everything posted by Durania
I used three pads per light and and I think that I might be able to get it a little clearer. I am finally getting the full effect of the Silverstars that I paid $40 for about 5 years ago. The only issue I had was the little tips on the headlights shredding the pads up. Oh well, it kept me from breaking my arms sanding them down.
Been wanting to clean these headlights up for a few years now and just finally got around to it. Autozone sells a kit that comes with an adapter bit that fits into your drill and comes with 6 abrasive pads with the rubbing agent built in. What one does is spray it with a mist of water and use the drill moving in an all-over fashion. I would usually post them directly here but I will simply link you to my photobucket because of the issue of the pictures being larger than some's screen. http://s155.photobucket.com/albums/s308/durania717/ Also there is a picture of my seized a/c pulley bearing, have a look at that.
International Users: Help Identify This Part!
Durania replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it is to let fresh air in through vacuum controls then what does the fresh air slide do? I too have always wondered this. ...Would also like to have one of those chrome gauge outline things. -
New guy with a few Subarus...
Durania replied to Colin Doyle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That high of an idle could be a stuck throttle linkage or damaged throttle return spring. What kind of issues did you have getting the Sambar licensed? -
Did you go out the t-top to await rescue?
I fail to see your reason for making a profile on here for nothing more than to continue an internet post war. Obviously, Mr. Hewitt came over here for a second opinion and has tried to provide us with some insight into the car troubles that he is having. And judging from your comment: "What you should do is invite any of those morons on the Subaru board who claim what you state to be true to this board and let them post that half-baked theory here." I don't believe you will be welcome here.
Pretty sweet setup. Have you had a chance to run it at the strip yet?
I have two hypothesis: 1. You have alternator issues. When they would go bad on me in my hatchback, there would be a feedback sound corresponding to the engine RPM's through the speakers. 2. I recently fixed an issue with MAF troubles. It would idle fine then when I began normal driving it would buck and hesitate. Mine did throw a check engine code FYI.
I want to see some pics of this EJ20 XT.
The Beast is Back in Action!
Durania replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I predict you won't be taking her to 6500 RPM's anymore. -
You can adjust the valves no problem in her now. Why did you put that switch right on top of the dual range emblem of all places? -
The issue that I am having with my radio is the display not coming on. Before it would come on after about 5 minutes, and now that I have been driving it on a regular basis it doesn't come on at all. Is this a get a new radio situation? Also my speakers for the drivers side do not work, both front and rear. Could it be grounded against the door causing both not to work? Thanks, Kyle
Probably not. The tranny from a Legacy would not work in your Loyale without major modification. Even if it did, it would have been pointless without the EJ22 to go with it. You got a standard 3AT chief.
I believe it means you have a brake light out if it is illuminated while driving.
IMHO you should swap an AWD tranny in with that EJ motor you plan to throw in that thing. I know, easier said than done. :-\
DO NOT drive it locked in 4WD on pavement. We can't stress that enough.
What would you do? RX prob
Durania replied to milestoempty's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Intake manifold is not bad if you take your time and doing the appropriate steps. PB Blaster is your friend on the bolts. When getting replacement gaskets, I cannot stress to you the importance of buying dealer gaskets. I have a picture of where some idiot used the make your own gasket crap and what it looks like after a year or so of use.
