Manarius
Everything posted by Manarius
Please please PLEASE!!! search before you post a question this broad. It will save us from having multiple threads about the same thing. The answer is no. There is NO benefit to putting in that fuse. It does not save on gas mileage and it does not prevent any wear on the transmission. If anything, it's worse with the FWD fuse than it is normally.
How does the fuse work? Please PLEASE!!! search before you ask questions - this has been covered many times. In a nutshell, it forces the Duty C solenoid to not engage the clutches in the back of the tranny. Where is the rest of the wiring? Well, the fuse just sends a signal to the TCU saying to engage FWD. Interrupt with a switch? Why bother. The FWD fuse isn't supposed to be in except in situations where only ABSOLUTELY necessary. It doesn't gain any gas mileage or make less wear and tear on the tranny. If anything, it's WORSE to drive an AWD car in FWD mode just because you feel like it. You use the FWD fuse for testing, not for normal driving. If you want a FWD car, get a FWD transmission.
oxygen sensor
Manarius replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
90's have only one sensor. From the looks of the one on my 91, I bet I could get it off without any penetration solution. Just unplug it and do the nut, it's a rather simple process. -
OBDI to OBDII is going to be a big PITA.
Just get the timkin bearing and new seals - do NOT get bearings from the dealer, they aren't worth it. The bearing itself comes with a nut and all that jazz. Take it to your local mechanic, he'll charge you an hour of labor. You gotta undo the caliper and hub and he'll have to undo the axle and pull the axle away to get at the hub. Make sure he packs the bearing with new grease.
What kind of emissions stuff are you looking to get rid of? Most of the stuff is pretty necessary (PCV system most notably). You could probably drop a cat, but you'd fail a visual so...
Help!!
Manarius replied to kukliani's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Car thowing a Check Engine Light? Sounds to me like you may have a clogged fuel filter. Replace the fuel filter and check back. If we still have problems, then it might be a fuel pump issue all together. -
No SVXi out there yet
gas tank
Manarius replied to raven05649's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Junkyard. Any AWD Wagon gas tank from a 95-99 should work. -
Miles Fox crashed my GL
Manarius replied to wave o babies's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks to me like bald tires caused that accident.
