tunered
Everything posted by tunered
Brake Issue
tunered replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i am guessing that this is an automatic,if so the click you heard is the shifter unlock if the noise was inside the car.any more info would help. ed -
Rust.
tunered replied to Sydfloyd44's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
smooth it up as well as you can,duro make a product called endrust,apply while the rust spot is dry,this stuff will dry[overnight] and then apply your touch up paint. i would use 180 grit to clean area.you are right by not grinding the area for this will thin it out way too much. ed -
by the way dude,99 percent of car makers recomend 5w30or 10w30 do you think they have tested this or are smarter than them? heavier oil creates more pressure ,know why? because the oil pump has a hard time pushing this thick oil,there fore more pressure.too thick of a oil will actually starve the main and rod bearings.modern oils aint your old 3&1 oil anymore. ed
