9
the diff design 90 - 04? are all the same. they will all bolt in. BUT you need to make sure you get the matching final drive ratio.yours is 4.44:1. you can use any 2.5L auto trans rear diff 96 - 99. 00-04 you need to make sure it comes from an outback. there may be others that work but i'm not as familiar so keep to the outbacks with auto trans. Re: locking, post #2 here, http://www.ultimatesubaru.org/forum/showthread.php?t=108298
/quote/ Anyone know the best/cheapest place to buy one? /quote/ https://www.chaplinssubarugenuineparts.com/oe_parts_cat.html http://www.subarupartsforyou.com/ i prefer the first one, you can email or call jamie. other folks like the second, jason i think. you need 2 gaskets for the solenoid, "duty c valve assembly". you do not need a gasket for the trans case, use a good "rtv ultra" gasket goo stuff. you can replace the clutch discs if you want but you probably do not need them. just change the fluid, often. the duty c and 2 gaskets is about 75$ plus shipping, i think. and there are some old posts with part numbers if you need them, which you probably will not. or you can search here: http://opposedforces.com/parts/
do a search. some one recently, last few weeks, had a thread with good detail about testing an o2 sensor. what i remember is the voltage on the sensor signal wires was low, real low and fluctuated between or within 2 values as it read the exhaust? if any one remembers who posted it or a key search phrase that would help. do a search.
om the 96 - 99 2.5L engine, there is a higher than normal low mileage failure rate. all of the these engine were assembled new, new blocks, new heads new gaskets, at the factory. it does not get ant flatter then that, and the gaskets failed. subaru has solved the problem by re-designing the gasket. use a subaru gasket. on 2.2L engines, ... i don't know, maybe not.
the part om line is about 100$, retail (msrp) ~140$, at the dealer who knows??? the time is only about 1/2 hour max. do it yourself and save. http://www.subarupartsforyou.com/cp_partlistbymod.php?model=Legacy&subcat=Engine+Parts%2C+Sensor+O2&year=1997 part number 97 front o2 sensor = 22690AA290 https://www.chaplinssubarugenuineparts.com/oe_parts_cat.html oxygen sensor, legacy, front 96-99 $139.95 $102.44 Order By Description. Electrical - Powertrain control - Automatic transmission - Oxygen sensor oxygen sensor, legacy, rear 96-98 $139.95 $102.44 Order By Description. Electrical - Powertrain control - Automatic transmission - Oxygen sensor
honestly, i don't know. but i do know i have never read a thread here where there was piston, block, rod or crank bearing or actual head damage due to a broken timing belt. just bent valves. and as long as the timing belt is installed properly you will not cause any more damage. and there was/is a thread just this week saying that sohc engines some times get lucky and do not always bend valves. that is why we say hang the belt and see. worst case you have to do a head gasket / valve job, but not all valves will be bent.
is that the vacuum line that attaches to the bottom, about the middle, of the air intake half way between the filter box and the throttle body. you know, the one that slips off when you check your air filter and it makes it so the car will not idle, wants to die, until you reattach it. the other end goes to ..... anyone.
we need to know more about your 96 in order to help you. engine, trans, miles what makes you think you need a new rear diff.? they don't fail often. maybe it is "torque bind". locking is a viscous limited slip differential, vlsd. when one wheel spins the other wheel still pulls. non-locking is an open diff. when one wheel spins the other wheel just sits there.
fiddilin jay New User Join Date: Jan 2010 City: Garner Posts: 1 1996 Outback differential Hey Subaru enthusiasts - a couple of questions regarding rear differentials. Are any later Outback rear differentials, 2000 and beyond, interchangeable with my 96? Also, what is locking verses non-locking. Will have to replace mine soon.
i always forget to state my year and model. on one of my cars maybe both, 95 lego or 97 gt, when i had the exhaust off, i compared the front and rear. both were had 3 wires, both had the denso name on them and both had the same number stamped on them. only the connectors were different. 00 obw is the phase 2 SOHC, maybe they changed the spec.
good thinking on doing it anyway. there is a very recent post , last 2-3 days, on this very subject. 2.2 or 2.5 does not matter, they are the same. search for " tune up* " (exactly) or look at the bottom of 'this' page for 'similar threads. if you can't find what you are looking for give a shout out. after you find what you are looking for and have more questions, give a shout out. and welcome to the real world of subaru. how much did you pay? i'm jealous. welcome!!
i don't know much about the cooling system design, but there do seem to be a fair number of 90 - 99 2.2s for sale with overheating and / or head gasket problems on craigslist. if a flush would fix them, what a deal. one of the posts in the above linked thread mentioned one cause as the horozontal design and the coolant not "draining back down" and always being in contact with the gasket.... well if it is a sealed system the coolant never 'drains back down', the engine design does not matter. you really have to take what you read on the internet with a grain of salt.
