SubaruRichie
Everything posted by SubaruRichie
CV joint, wheel bearings or what?
SubaruRichie replied to spideyz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You should check out the ball joints too. They wear out and start making a little clunking noise themselves. The 89 wagon I got from you has shot ball joints and you can hear and feel them slopping around. I would have started checking something else. I just happened to notice their condition when I had the car up on jack stands. I had the same problem on my 88 XT. Had to replace both of them. With the car up on stands try to pull out on the wheel from the bottom of the tire. If the ball joint is bad you will feel the excessive play in the ball joint. The wheel will feel like it is almost flopping around in your hand. Fairly easy to replace too. Good luck Keith. -
Can a EA82 be put into a gen1 Brat
SubaruRichie replied to SubaruRichie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you! I think I will start tearing my donor 87 GL 10 turbo wagon apart tomorrow. -
Wow! Now that I have really taken a good look at the work Garner did on his gen 1 Brat I am really impressed. Lots of work but I think it would be worth it. Still lookinbg to see if anybody has a answer to my rear disc brake conversion question. Come on, Somebody has got to know if it can be done on a gen 1 Brat or not! -
I'm glad to see it can be done! I am in no major hurry. I just need to strip the wagon of everything I will need to make this work. Then I will just have to find a transmission for this. I sure am not going to use the burnt up auto that is in the GL 10 wagon.Again, will the disc brakes off the back of the GL 10 wagon fit on to the gen1 Brat? -
SubaruRichie posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 78 Brat that I was thinking of trying to put a EA82T from a 87 GL10 Turbo wagon. Is it possible? If so what all would I need to take off the wagon to make the change. Also, will the disk brakes fit on the back? I know they will fit on a gen two brat but will they fit on a gen 1 Brat? Any help would be appeciated. -
Well that explains why it possibly smells inside my 78 Brat. Especially after I filled it up!
Ahhhh time to learn to weld!
SubaruRichie replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you do buy a welder buy a Miller. Great welders. I use them everday at my work. Had some experience with lincon welders. Not near as good as a miller. -
Im sure going to try to get it back on the road. Just need to pick up some fresh parts first. Think I might try to fix the 87 too. Found a tranny for it on ebay cheap. It drives but the tranny is real messed up. It dumps tranny fluid all over when you drive it and it has some strange noises going on. Also, you have to manually shift the auto tranny to make it shift. Besides that and being really dirty it seems like a pretty good car. I even got the air suspension to work today, all 4! I definetly have my hands full now with 6 cars at home. Looks like a car lot!
Yep, That's right I picked up my 2nd turbo wagon today. Got Spideyz's 89 yesterday and today picked up a 87. Had not ran since 97. Guy said it had a bad tranny. Again, just like yesterday I threw a good battery in it and it fired up on the first try. I tried to put it in gear and nothing. So I checked the tranny fluid just out of curiosity. Empty! So I put a quart of fluid in and it went into gear. I drove it down the street and up into the driveway. It seems to run pretty good. It does have a problem with the air suspension. The compressor comes on and you can hear air leaking from somewhere. I checked all around the compressor and there really was not much air seeping out of the fittings. But the suspension remained flat. Can I do a strut conversion on this 87. I know it's done all the time in XT-6's. Any help would be appeciated.
Ok, I just got spidey's, I mean my GL 10 turbo wagon home. I threw a battery in it and sure enough it started right up. I drove it right off the trailer and into my driveway and began to troubleshoot the car. Checked the radiator. Empty. I put some water in it and started it up again. I instantly found the problem, yep you guessed it, Blown head gasket. Water was running out the right side of the engine. It was easy to see the problem when I looked under the car. Heck, it looks like the gasket is just about gone on the bottom where I could see it. So I am planning to fix it. Here is what I am planning to replace: Timing belts, crank and cam seals, water pump and gasket, oil pump and seal and, the thermostat and gasket. I figure while I have the radiator out I should have have it gone over since it will be out any way. Is there anything I missed that I may need to check or replace while I am in there? Let me know if I missed anything else. Thanks.
Ok, just got spideyz's GL 10 turbo wagon home. Threw a battery in it and sure enough it fired up. Drove it off the trailer into the driveway and began troubleshooting the car. Checked the radiator. Empty. Put some water in it and started it up. I instantly found the problem, yep you guessed it, blown head gasket. Water was just running out the right side of the engine. It was quite easy to see the problem when I looked under the car. Heck, it looks like the gasket is just about gone on the bottom where I could see. So I am planning to fix it. Tell me if I miss anything to replace. Here is what I am thinking so far. Timing belts, crank and cam seals, water pump and gasket, oil pump and seal and, the thermostat and gasket. Also, I figure I should have the radiator gone over since I will have it out any way. Let me know if I have missed anything or if I should do anything else while I am in there. Thanks.
Rear disc conversion: proportioning?
SubaruRichie replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can this conversion be done on a gen 1 brat too? -
Five lug conversion question
Could the rear disc brakes come off a GL-10 turbo wagon AWD? -
Can a gen 1 Brat be converted to 5 lug? If so, would I have to get a AWD XT-6 and steal the parts out of it? Kind of curious. I don't recall hearing if anybody has done that. Not sure if it is possible on a gen 1 Brat or not. If it is possible that is the road I am going to take.
Starting my new project
SubaruRichie replied to 1979BratOwner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2nd brat looks pretty rough but good luck. Wish I had a extra Brat to have for parts or fix up. Luck you! -
Just got a free 86 GL-10 Wagon!
Yeah I want to go get it this weekend but, I would like to get it complete. I am thinking of just replacing the engine in it. Try to get it back on the road. Hopefully spideyz will be ok with that. -
Kid! I am a little older than you. And, it is taking work to find a place to keep these too. But I hope it will be worth it. -
Hi Keith , I am interested in the wagon. Always could use a good parts car. Do you have the title? Besides the motor what else is wrong with it? Let me know and we can set something up. Thanks, Richard. -
I came across this gem today when I was helping my grandfather cut down some tree at his friends house. Started talking to the guy about my brat and he asked me if I wanted his 86 GL-10 turbo wagon 4x4 . Only problem is it has a bad tranny. It has been sitting since 97. Body is in good shape. Just covered with leaves and spiderwebs. I just have to go and get it with the trailer. Now I just need to get a new tranny for it. Any body know where I can find a good automatic transmission at? Any help would be appeciated. Thanks!
Left Tail Light Lense Needed for 80 Brat
SubaruRichie replied to ibohren's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have been looking for a left tail light and housing for a while now. Could you help me out too? Thanks! -
81 brat- fuses and wires get hot!
SubaruRichie replied to snowstormer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had the same problem in my 78 Brat when I got it about a month ago. The wires on the back of the fuse box were melted. Someone before me had put a resistor on the wire to try and fix the problem. The fuse box was even melted! I solved this by going to the junk yard and getting another headlight switch and a new fuse box from another brat. Works fine now. I'm thinking that was the problem with my brat. Maybe yours too. Good luck! -
Have a tranny fluid question
Thanks, I appreciate the help. -
That's 80 to 90 weight gear oil right? Just want to make sure.
