239
Everything posted by Loyale 2.7 Turbo
replacing gauges
Loyale 2.7 Turbo replied to Mykeys Toy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Believe that the easier way to test the Sender, is to Remove it from the Gas tank, then connect it again to its wiring and Manually Move it from the Low bottom to the Full top, while seeing the readings on the Needle. A visual inspection of the sender and its whole conditions is good Idea, if you find it Worn, you can replace it. Also, the wiring from the Sender to the Gauge could have a short circuit somewhere, because you wrote that "it reads Full more often than not" So you can follow the Wire from the Start to the End to be Sure that it isn't touching bare body metal in a tiny crack or rip to its covering plastic... Well, that is the Way I fix issues with Gas Level Gauges & senders. Good Luck! Kind Regards. -
replacing gauges
Are you completely SURE it is a Gauge Fail? The culprit could be the Fuel Tank's sender unit, the float usually fails... So I Kindly suggest to check for ground signal coming from the Fuel Tank's float. Kind regards. -
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Sometimes one car Maker, uses the Model Designation from other Car Maker in Different Markets, you Know: The Model Name belongs to the First one who registers it. Usually you won't see two car brands sharing the same model designation in USA, but here in Latin America, you can see together the Hyundai Matrix and the Toyota Matrix, The Ford Skorpio and the Mahindra Skorpio, The Pontiac Fiero and the Nissan Fiero. According to our Local Laws, the Brand itself is like a Family Name, while the Model Name is like a Given Name... so to share Model Names is not a Legal problem here. So you can see here, the Kia Delta and the Daihatsu Delta and the Lancia Delta ... ... Also The Nissan Frontier and the Kia Frontier ... ... together. Underlined words are Web Links Kind Regards. -
Kia Sephia Sporty
Not only Subaru used an Acronym for the BRAT name, also Kia did that with the SEPHIA name. The name "Sephia" is an acronym of these words: Style, Elegant, Powerful, Hi-tech, Ideal, Auto. Look ~► Here, For further information. Kind Regards. -
Kia Sephia Sporty
I Know that for the USDM and other Markets, there was No Third Gen Kia Sephia, (the car was named: "Spectra") but the Sephia name continued in the Market for Latin America. The first Spectras came here Still named as Sephia: Then came the "Sephia II": Still the 1.6L engine was the "Standard" while the 1.8L was "Optional". -
Kia Sephia Sporty
The Second Gen Kia Sephia, introduced in 1997, was still based on the Ford Escort / Mazda 323 of its era. Here you can see my Wife's "KiaStein" which is a Second Gen Sephia: And here you can see the "KiaStein" Parked behind a 1997 Mazda 323 / Protegé that has almost the same Body design than the Sephia, even the Mirrors, the Rear door's li'l triangle, etc... Certain parts are interchangeable: It came with the New T8D engine, which originally was developed for the Kia Elan: See the Wikipedia info Below: Read ~► Here. But for the Latin American Markets, the 1.8L T8D engine was Optional, the Second Gen Sephia came "Standard" with a 1.6L engine. -
Kia Sephia Sporty
Well... The LADM (Latin American Domestic Market) Receives different Kias than the USDM, also some are the same models but with diferent engine options. In example, After the Kia 303 (a Mazda 808 made by Kia) They imported here the Kia Capital. When the Capital was discontinued, Kia imported here the First Gen Kia Sephia, in 1992, which was somehow Based on the Mazda 323 / Ford Escort of that era. The First Gen Kia Sephia Looks like this one: the Sephia Leo (Hatchback): I remember I Saw a convertible Version of the First gen Sephia in a Magazine, and I searched for it on the Net 'till I found some pictures, which I want to share here, look carefully: It looks more Ford Escort Alike, specially its rear Lights and metal sheet design: 1995 Kia Sephia Cabrio (Magazine Scan): A couple of Photos from a 1995 Auto Show of The Kia Sephia Cabrio: Does Look more Ford Escort alike, isn't it? -
Suspension improvements for Subaru Loyale
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Suspension
I've received some Questions about that Suspension Mods I've done, via PM; I'll post here the most common Questions along the Answers, in order to Help more people who wants to do these Mods. Well, the Rear suspension, using the Toyota 4Runner Shocks PLUS the Honda Coils, will be Lifted (a little less than) Two inches (2") but if you use the 4Runner Shocks along with the Stock Subaru Coils, it will be almost no Lift at all on 4WD Subies. (Remember: 2WD Subies has a 2" Lower base for the Coil Springs on the Shock Absorbers, as explained in the Writeup) Please don't forget that the 4Runner Shocks only have 4" of total Travel, while the Subaru Shocks has 6" ... BUT the Coils Won't let them go much Down, specially with the Honda Coils. The added +/- 2" inches will Stress the Rear Axles to their Maximum, if you want to Do the 4Runner Shocks plus Honda Coils on a 4WD Subie, Without stressing the Angles, you must consider to Drop the Rear Differential a Little. Kind Regards. -
Well... the Strut assembly comes with a Shock absorber and a Coil Spring, either the Front and the Rear ones. I was Writing about the Coil Spring on that assembly. You can see the Rear one which is a Mix of the Toyota Shock absorber plus the Honda Coil Spring, on my 1985 Subaru "BumbleBeast" EA82 Wagon, in the Following Photo: The Toyota's Coil Spring is too Stiff for the Subaru's Rear, the Subaru ones are OK but Weak for my Rude / off road \ loaded use of my Wagon, so the Honda ones were Perfect for me, those aren't too Stiff, nor too Weak. Look for Part Number on my Writeup's Link Above. Kind Regards. -
Welcome! ... ... You can find a Complete Writeup full of Pictures about the Weber carb Swap onto the EA82 engine, in the Followin' Link: ~► Here. I Believe your subaru is EA82 by reading your description. (For more useful info, writeups & Files, click on my Avatar.) Kind Regards.
Subaru BRZ....
Loyale 2.7 Turbo replied to Suba_GL_87's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Words of Wisdom! ... ...I Agree. -
For those who use the Subaru Loyale (EA82) in a Rude way, either with heavy weights or offroadind too often, I wrote a Writeup years ago, with some Ideas to improve the Suspension on those Old Gen Subies, using parts from other car brands that fits easily on the Subaru Loyale. The Writeup is ~► Here. Since it is on the USRM you cannot reply there, but feel free to comment here, share your experiences and add your own ideas, etc... I Hope that you'll find my writeup, Helpful. Kind Regards.
Yes, I Did that Writeup years ago... it is: ~► Here. It includes front & Rear suspension ideas... mainly for rude use / offroading. I Hope that will be Useful. Kind Regards.
Even the Latin American Subaru XV (Model 2010, here came Earlier) has Dual Range: Look ~► Here, this is one Subaru XV 2010 for sale used in Chile. Kind Regards.
- 96 replies
- Dual Range EJ
- LatinAmerican Domestic Market
- (and 7 more)
Do you want more LADM (Latin American Domestic Market) Specs Subaru Pictures? Dual Range Subaru Impreza:
- 96 replies
- Dual Range EJ
- (and 7 more)
Kia Sephia Sporty
Let me Share some Pictures of Kia Cars that Don't go to the USDM. -
Kia Sephia Sporty
Here I Found on the Net, a Picture of a 2012 Kia Picanto: -
Kia Sephia Sporty
The Li'l Red Kia is "Picanto" ... Honduras has a Great Market for Kei Cars (Less than 3 Meters) and the Kia Picanto is one of the Market Leaders, with in-line 4 Cyl. 1L Gasoline and 1.1L Diesel engines; along the Chevrolet Spark (Which is a Korean made Chevrolet, former Daewoo) also many other brands sells mini cars here. Kind Regards. -
Greetings from Alaska
Loyale 2.7 Turbo replied to AKSoob's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! ... ... we Love Photos Here. Any question you might have about how to fix problems with your Forester, must be Posted in the "New Gens" Forum. Do you have Photos of your Forester? Alaska has Very Beautiful Landscapes. Kind Regards. -
Kia Sephia Sporty
My Wife's "KiaStein" Parked at the Shoppin' Mall's Roof: Kind Regards. -
Kia Sephia Sporty
I try to avoid controversial subjects on this forum, but let me explain the two reasons I have to Not install an H.I.D. retrofit Kit on my Wife's "Kiastein" ► The first reason is related to the Headlamps transparency on my Wife's "Kiastein" : Since they're made by Policarbonate plastic, they has the Yellow Stain tint & blur... well, the car came like that from the USA, I'm sure that the Previous owner never cared of the Headlamps. But both Headlamps were cracked on their sustaining arms, the passenger's side one was the worse, so I already changed that Headlamp on the Kiastein with a Junk Yard replacement, which was a Chinese Replacement! ... not a Kia original headlamp but you won't notice the diference. I fixed the broken arm on the other side's Headlamp with an oversized washer and is working good since that, a couple of years ago... Here is a Pic about that, maybe that simple idea could help other kia owners: But the Replacement lamp has the same yellowish blur too... I Tried to Polish them both using great quality products such as "Turtle Wax" Polishment, without great results. So until I could afford a couple of brand new transparent headlamps, I'll avoid that retrofit on the Kiastein, because the yellowish Blur on the transparency of the Headlamps' Lens, could lead to a dangerous Glare for the incoming driver. My Subaru Wagon is a Very different Story: It has Thick Glass Headlamps, one of those even received the Direct front impact of a Kia Sportage once, in a medium speed collision. The Glass survived absolutely intact, but the Metal behind it, which is part to the Subie's Body, was Bent. Pictures ~► Here. My Subaru Wagon has almost four years with an amazing 55 Watts Bi-Xenon (Low / High Beams) of 5000K (White-Yellowish colour) without any issue, and I drive it by Night very Much; its Bi-Xenon's Razor edge Low Beam plus the crystal clear headlamps ensure it is absolutely No dangerous glare for the incoming driver's eyes. That was my First reason: the Yellowish blur on my Wife's Kiastein HeadLamps. ► The Second Reason is, the Lack of Money: Someday, if I win the Lotto ... ... I'll purchase a couple of Brand New HeadLamps and a 5000K Bi-Xenon retrofit kit for the Kiastein ... ... Kind Regards. -
ANOTHER Problem...
Loyale 2.7 Turbo replied to subi dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Kindly suggest to do a Click on my Avatar, so you can reach a List of my Writeups in my "Public Profile" page, Scroll down to reach the one about "How to Swap Bosch Standard Relays instead of the Old Roundies" It is plenty of Pics & Explained Procedures about that, I Believe it could be Helpful for you. Kind Regards.
