239
Everything posted by Loyale 2.7 Turbo
Old Subaru's from little Iceland
Loyale 2.7 Turbo replied to KristjanJohann's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dear Friend: Thank you for Share Those Wonderful Pictures of Subarus and your Country... You're So Kind! I Really Liked all the Pictures but I Really wish to know More details about this "Loyale Brat" ... Seems to be a Good Project Idea: I Really Knew many things about your Beautiful Country... also let me Tell you that my Daughter Loves the icelandic TV Series "Lazy Town" (also I Like it too) Kind Regards. -
I Really Like those Brats... So Sad That I'm So Far... Kind Regards.
Things to check? Running rich + Backfire
Loyale 2.7 Turbo replied to pwjm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Seems like the Carburetor got Dirty, I Kindly Suggest you to Clean it and it could be done in Two Ways, the Easy and the Hard way. Easy Way is for Light Dirt: - Get a "Carburetor & Choke Cleaner" Spray. - Run the Engine 'till it Raises to Normal operatin' Temp, then Shut it Off. - Then unhook and Remove the Air Filter Box. - Use the "Carburetor & Choke Cleaner" Spray and Gently Spray first the Carb's Outside Movin' Parts and then the inside, while manually move the Butterflies and Choke; then Carefully insert the mini Straw in the Spray can's tip (be careful to avoid Spray yourself) and try to Reach with the Sprayed Cleaner the internal Parts. - let it Rest for a while, (one Hour minimum) then try to Start the Engine with Gas Pedal between 1/4 to 1/2 of its way Down; dont pump it to Avoid Drowning. The Car will be Hard to Start but after three or so Tries it Shall Start, first very Rough... Let the gas pedal Li'l Pressed and let it Stabilize itself while you still have the Gas Pedal Li'l Pressed. - Finally with Engine Runnin' at normal Idle Speed and completely Stabilized, take the Spray can again and Remove the mini Straw, manually Hold the Accelerator Cable and accelerate the engine at around the 4,000 RPM's and Hold it There while you give to the Carb's Throat Short (two seconds Long) Sprays of Cleaner... The engine will reduce the RPM's but you Must Keep Holding the cable at the same position and let the engine Back to the 4,000 RPM's acceleration and Stabilize itself back again ... - Repeat the Short Spray again while you still keep holding the accelerator cable ... do That for ten or so Times, then Keep Accelerated the Engine untill it Stabilizes itself again, finally when is Stabilized, release the Accelerator Cable and let it Rest at Idle RPM's for a While. - Final Step: Test Drive the Car, the Problem Must be Gone. - Advice: After done that Carb Cleanin' Procedure, I Kindly Suggest to Change Sparkplugs, air Filter and Gas Filter as Needed if those are Old, also is Very important to add a Gasoline additive "Carb & Fuel Injector Cleaner" to 3/4 Gas Tank and Drive the car without Refill the Tank untill Near Empty. There is a Chance that the Distribuitor's Points are gone Bad too, so I Kindly Suggest you to Change 'em. Warning!: Wash your Hands and avoid to Spray the Cleaner to the Skin or Eyes, is very irritating. Hard Way is for Very Dirty Carbs or when the Easy Way Failed: in That Case Take the Carb to a Qualified Carburetors Service Shop... or get Rid of that Hitachi Crapburetor and Swap there a Weber! for Better Performance, Easy Maintenance and increased Lower end Torque... also Better (Cleaner) Engine's Look. I Hope this will Help you! Kind Regards. -
Old subarus in arizona junkyard
Loyale 2.7 Turbo replied to Yaron's topic in Historic Subaru Forum: 50's thru 70's
I Agree, Absolutely. Could I Ask Why a Nice Lookin' Brat that seems to have a Recent Paint Job, will end in such Place like That? Kind Regards. -
Legacy 2.2 into Brat??
Loyale 2.7 Turbo replied to esteveW's topic in Historic Subaru Forum: 50's thru 70's
An EJ22 Brat will be Nice, Fast and Fun to Drive! I Kindly Suggest you to Measure the Wide Space on the Engine's Bay and then Measure the EJ Engine's Wide... Because the Gen2 Brats have enough Wide Space to fit the EJ Engine but I am Not Sure about Gen1 Brats... Maybe you'll need to cut down a Li'l bit there. I Wish you Luck on your Project and also I Kindly Suggest you to Post Pictures here of your Swap Work. I Thought it was Popeye! Kind Regards. -
Ok I have a dumb question
Loyale 2.7 Turbo replied to 84GLPROJECT's topic in Historic Subaru Forum: 50's thru 70's
if you Drive on Warm Climates, I Kindly Suggest you to use 20W~50 of Good Quality Oil, for more Cool Climates switch to 15W~40. Kind Regards. -
EA82 radio install...
Loyale 2.7 Turbo replied to benjamachine's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well... I Do Custom Wooden Speakers and other Things and I Made a Custom Wooden Plate to Solve that Situation on Both my Wagons, you can see my Writeup plenty of Pictures about it, if you want to: Click on my Avatar and Scroll down on my Public Profile Page: there You'll find a List of Links to my Writeups. I Hope this will Help you. Kind Regards. -
My lock & key situation...
Loyale 2.7 Turbo replied to Speedwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That could be Very Dangerous! ... 'cos it Should Not Engage Lock in any Key position but Keyless only. I Kindly Suggest you to Remove that Damaged ignition Switch from the Steering Column. I Remember that when I Was Child, my dad was Drivin' a VW Microbus that Locked the Steering Wheel while Driving! he did an Emergency Stop and then he has no Choice but to Break the Lockin' Mechanism... including the Turn Signals System... that was Very Dangerous so in order to prevent a similar Situation I Suggest to Remove that ignition Key... Maybe you can Find the Right Replacement. Kind Regards. -
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Thank you for this Test Idea, let me tell you that As I Wrote before, I Removed the Whole Head and Already Changed those Guides and serviced the Valves, But I Did the Test that you Suggested just in case... and I Found: Nothing! ... No White nor any colour of Smoke could be Seen; so I Assume those Valve Guides are Allright; but Thank you for the Test, it is a Good Idea that I will keep in mind. Very Respectfully let me Tell you: No my Friend. As experience had teached to me, Usually the White Smoke Clouds means Oil Burning and Black Smoke Clouds means a Too Rich Fuel/Air Mixture. However there could be more causes for that but Basically that's How it works. Thank you for your Kind Post, I Already Checked those Coolant levels as you Suggested and They're Allright too. Ha, Ha! ... Well, the Car Came in a Cargo Vessel from Georgia, USA. Let me Tell you that Since I Poured those Four Ounces of Marvel Mystery Oil on the Kia's Engine Oil, the Car Runs Very Very Smooth and the White Cloud of Smoke is Gone! no more Early Mornin' Clouds of Fumes Anymore! .... seems like the car's engine had Stuck the Oil Piston Rings and the MMO did get 'em Free Again!!! Now that MMO is what I call a REAL Additive! Kind Regards. -
Kia Sephia Sporty
Well, Today I Poured four ounces of "Marvel Mystery Oil" also Known Here as "MMO" on the Sephia's Oil Pan and I Drove it for 40 Miles in Mixed Traffic conditions... Let's See Tomorrow Morning's First engine Start, I Hope to see Less ~or No~ White exhaust's Cloud... Also I Had to Sign up at a Kia Forum site, there is a Thread with further Details than This thread, 'cos that's a Kia site. you can see that here: http://www.kia-forums.com/kia-sephia-forum/55621-long-time-sat-kia-sephia-help.html But in Both Threads I am feelin' so Alone... Kind Regards. -
Oil filters-would bigger be better?
Loyale 2.7 Turbo replied to Kwhistle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't want to Argue your Reasons but Please let me Explain Something that I have Learned by my Own Experience with Many Cars, not only Subarus: After Some Days without Starting the Engine or even the Every day First Start, due to the fact that all the Oil went to the Oil Pan; when you First Start the Engine, it Takes More Time Without Enough Oil Pressure when the Car Runs on Smaller Filter and Less Time when the Same Car Runs on Larger Filter. It is Due to the Oil Filter's Own Capacity: the Larger Filter Holds more Oil inside its Own than the Smaller one, also it is Right at the Oil Pump, So the Filter's Oil Helps to Prevent the Engine from Runnin' Without enough Oil when Started: It Supplies the Oil While the Pump gets it from the Oil Pan; So That is Why a Bigger Filter is Better than a Smaller One; but that is the Only Noticeable Difference Between Smaller and Larger Filters... The Real Reason of Many Sizes in Oil Filters is Just the Available Space on Engine's Bay, not the Performance itself; just like the Real Reason Behind the V Engine Design: is Easier to Fit in a Short Space a V8 than an in-Line 8 engine, isn't it? I Kindly Suggest you to Try this: if your Subie can Hold Both Sizes of filters and it has the Oil Pressure Gauge, Check how Long takes to Raise it Up when First Start the Engine in Early Morning with the Large Filter and after the next oil Change, check the Same but with the Smaller Filter... without Oil Pressure Gauge: Just Listen to the Hydro Lifters and how long takes the Oil Pressure to Quiet 'em with Both Sizes of Filters and the Same SAE Number Oil. in Example, my EA82 Wagon can Hold the Purolator L10028 Small Oil Filter and the Purolator L20064 Large Oil Filter, both work just Fine but with the Larger Filter the Oil Pressure Gauge Raises Up Faster after Start than with the Smaller One... Using the Same 20W~50 Oil, and Hydro Lifters Quiet Faster too. I Hope this can Help. Kind Regards. -
Tire Size dicontinued? What to use instead?
Loyale 2.7 Turbo replied to Deener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Plenty of R12" and R13" Tyres in our Market, but We are So Far... Yes, I Run in Both my Subies 205/60 R13 ... Those Compared to the 185/70 R13 are almost Identical, Same Tall except for an Inch Wider. See This Picture I Taken with my Cellphone Long time Ago, when I Switched from 185 to 205: Hope This can Help. Kind Regards. -
alternator charging weird
Loyale 2.7 Turbo replied to Markus56's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Agree Absolutely with Edrach's Post, Specially with This: So, I Kindly Suggest you to Not Use the Stereo or other electronic sensitive Devices... (Because they Might be Fried Too) ...untill you Change that Alt. Kind Regards. -
1995 Dodge Neon.Free from CL.
Loyale 2.7 Turbo replied to markjw's topic in Non Soob Cars and Bikes Discussion
Nice Neon! ... I Like it and I'm Glad to Know that the Engine was Good... I Like your Idea with the Marvel Mystery Oil. Sorry for Hijack your Thread but I have a similar situation and No Experience with Marvel Mystery Oil and also I just Obtained a car that Sat unstarted for Several Months... I Already Changed the Head Gasket and Fixed the Valve's Seals... Seems like the Oil Rings from the Pistons are Sticky, 'cos the Car Blows a White Cloud of Smoke when is First Started Early Mornings... Otherwise it Runs Awesome! (For more info see This Thread) But I am Not Sure about the MMO ... Should I Take out the SparkPlugs and Pour Some MMO there? ... if So: How Much is the Suggested Amount? ... Or due to the Fact that the Engine is Already Working almost Fine, Just Burnin' some Oil: Should I Pour the Pint Bottle onto the Crakcase? Kind Regards. -
Kia Sephia Sporty
I just Removed the Stereo (That Came Without its FacePlate) from the Sephia's Dashboard... so Now I am Able to Know its Characteristics and maybe to Obtain another FacePlate. The Stereo CD Receiver unit is Brand: JVC model KD-S640 I Found it Here. It Came with a CD inside! ... ... Named: "Dj Infamous: Young Dro & Young LA – Black Boy, White Boy" ... that can be Seen Here. (Also I Found in the Car a Huge Pink EarRing without its Pair) I Already Found a Couple of Websites where there are Available Used FacePlates for it, but Seeing that Stereo Unit that Says "Made July 1999" makes me Think that it should be a Better Idea to install a New Unit there, because it is a Decade Old Stereo and maybe Don't Worth the Effort to obtain a New FacePlate... also Maybe it is Damaged too. Kind Regards. -
Kia Sephia Sporty
Well... I Just came Back from "Hunting" at Different Car Parts' Shops and I Came back Home with a Bottle of an additive Named "Marvel Mystery Oil" also Known Here as "MMO". It reads that I can Pour it in the Gas Tank And in the Crankcase... I've never Used MMO Before... please Let me Know any Idea or Suggestion about it... I Want to use it Mainly (Or entirely) with Engine's Oil in order to get Free the Oil Rings from the Pistons... What do you Think About that? Kind Regards. -
Could I Ask what was the Purpose Behind Cuttin' the Cherokee like That? ... Some Project? Kind Regards.
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
funny! ... I Think it is a Cool Hat! ... I Like it. Could I Ask if that came Already like that or is Something that you Made? Kind Regards.
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
Kia Sephia Sporty
Well... it is Alive! ... ... and Runnin' very "Fast & Furious"! The Brand new Pulley Came, I Already Changed it and the Engine's Head Gasket, Serviced the Valves and its seals, Poured New Fresh "Motul" Brand Oil 20W~50 and Brand new Oil Filter, a Brand New Radiator and Sparkplugs there.. also the A/C Condenser came Welded and the Disc & Drum Brakes came Repaired from the Shop and all is Back on its Place again; including new Brake Pads. After all the Work was Done, The Car Started Right in the First Try! and it Drives Awesome, But... it Blews a White Cloud of Smoke While Engine is Still Cool ... ... I Believed that I have Overfilled it with too much Oil ... because the Dipstick comes like This: on its Front Shows Oil Mark Just Between F and L, but on its Back is comes Full of Oil up untill Half Dipstick, Far away above the F and I am Not Sure How to Understand this... All the Other Cars I've Repaired and the Ones I Own Shows the same Oil Level in the Front or in the Back of their Dipsticks... Now I've Obtained the 2001 Sephia Owner's Manual (Downloaded in .pdf format) because the Car Didn't came with it; after some readin' it Says that to look more accurate the Engine's Oil Level, first Start the engine for a While and Then shut it off, let the Oil get Back to the Oil Pan (let it Rest some Minutes) and after all that, Pull out the Dipstick. So I Opened the Engine's Oil Cap and let the Engine Drain out all the Oil during All night Long... I Discovered this: The Total Amount of Drained Oil Didn't Reached to the Full Gallon, I Didn't removed the Oil Filter so that Might explain it in Part but I was Expecting some More Oil because I Believed it was Overfilled... the Total amount Drained was just 3.2 US Quarts. I Closed everything, re cap and then I Refilled the Engine with Fresh "Motul" 20W~50 Oil, just 3.5 US Quarts as the Manual Said (The Amount when Oil Filter is Not Removed) and Started the Engine, then I Drove it for Twenty Minutes. After that, I Shut it Off and let it Rest for other Twenty Minutes in order to Let the Oil Go Down to the Oil Pan... then I Measured the Oil with the Dipstick. But This Time Things Have Changed: Now the Dipstick comes out Completely Clear to Read: it Came in the "F" of Full on Both Sides! :cool: But the White Smoke Cloud still Happens when the Car is Just Started or While Drivin' at Cruise Speeds and I Do a Deep Fast Acceleration. So, Seems like the Oil Rings on the Pistons are Stuck, due to the Long Time Sat... Because there comes a Huge White oily Cloud from the Smoke when First Started, That dissapear (or reduce to levels that can not be Seen) when the car has around Three Minutes of Run. Does anybody Know if there is Something, some additive that I Could Add Safely to the Engine's Oil that can Make those Oil Rings to be Loosen Free Again? Also the Car had this other Problem: When I Stop it for a While, in example at a Red Traffic Light Semaphore; the Idle Slowly Drops to an "Almost Die" Level and then Accelerates to its Regular RPM's by itself ... Then Again the Idle Slowly Drops to an "Almost Die" Level but it Accelerates itself to the Normal RPM's again ... and So On ... it Keeps Doin' That all the Stopped Time at Idle... It Takes ~ Three or Four Seconds from the Normal Idle RPM's Speed to the "Almost Die" RPM's but it Accelerates back to the Normal RPM's Speed Faster than a Second. Also the "Check Engine" Light Came along this Behaviour... I am in a Developing Country where is Not Easy nor Cheap to Find Someone who Has the Special Equipment that connects to the Car's Computer, So I Can not Obtain Any Codes; ... last night I Removed the Possitive (+) Terminal from the Battery, Then Manually Checked and Double Checked again for Loose Connections in ALL the Plugs and anything electrical I Found under the Hood... I re-connected the Battery just untill Next Morning. The "Check Engine" Light went Off and the Idle Dance too... now I Just want to see if the White Cloud of Smoke is Gone too... What could caused that Behaviour? Kind Regards. -
Thank you for your Kind Words! Also I've Seen the "Montego" Version here in Honduras, but Only in Station Wagon Shape with a 302 V8 engine. The Comet is the Sports Coupe and there were a Comet "Caliente" (Spanish for Hot!) Version that was also available with two different V8 Engines. Kind Regards.
Thank you for your Kind Replies! Yes, SC Means Sports Coupe. That in-line 6 Cyl. Engine uses Hydraulic Lifters Too, is a Quiet, fast & Powerful Engine that Runs with a Very Tiny Carb, I Obtained a Brand New Chromed Carb for it. Believe me: is Very Economic to Drive. The Main Difference between the 250 Engine on my Mercury and the Truck's 300 Engine, Beside the Bigger Bore & Stroke, is that the Truck Versions has a Much Larger Run on the Cylinders, so the Truck Engine Version is Slower but more Powerful (And Gas Thirsty too), the Truck Engine is Taller Too; but Basically Yes, is the Same Engine. Kind Regards.
Fiasco? ... Why? I will Really Love to See more Pictures of That Nice VW Bug! Kind Regards.
My 1969 Mercury Comet Sports Coupé, Today Reaches its first 40 Years of Non-Stop Work & Run History ... ... My Mercury has been Part of the Family since New, my Dad purchased it on Spring, 1969; and I came on it the day I was Born in 1975 ... After lots of Family Memories and Tons of Photos, Travels Videos, etc, Together; makes this MuscleCar to be a True Part of the Family, is somehow like my "Brother" ... I Named it "Herbie" when I was Child... so many Memories together makes this classic, Priceless! Now after 40 years and more than three full Turns (and counting) on the Odometer, it still Runs like a Champ! Here you can See "Herbie" next to my Former White Wagon, which Now is Modified and known as the "BumbleBeast" Here you can See "Herbie" parked outside the House, and my Former White Wagon, inside the Garage: Here you can see "Herbie" Parked in front of my yellow "Loyale 2.7" (Now Dead - Background Story here) Project Wagon: Engine Photo: Much More Photos in my USMB Photo Album: Here ~► http://www.ultimatesubaru.org/forum/user/13502-loyale-27-turbo/?tab=gallery I've upgraded it with Front Disc Brakes, a Brake Booster (Subaru, by the way), Chromed Engine Parts (Such as Head Cover, etc...), Under Body anti Rust Paint, Body Paint, a "Yamaha" Stereo, etc... Also I managed to "Made" (with the help of a Friend who owns a Metal Casting Factory), a Piece for the Engine: The Water Inlet (Where goes the Thermostat) is now Made of Thick Brass, instead the Weak one that Ford does (Made of Manganese?), which somehow trend to get destroyed after a couple of years of use. It Runs Great on its Manual Trans and Being just 250 Cui (4.1L) 6 Cyl. is economic to Drive for a Full Sized MuscleCar Coupe. I Just Wanted to Share our Celebration! Kind Regards. ►Edited to Update the Picture's Links and Web Links, due to the New USMB's System
Kia Sephia Sporty
Today I Found that the Main Pulley is Li'l Bent ... Already Asked to the Parts Shop for it, Thanks God it Was not Expensive!
