Everything posted by Ma-fia
Any of you old skool guys have or use a sandblaster?
I don't have anything smart to say. I'd like to remember this thread, but can't find "subscribe to this thread" option. Things are changing with the speed of light on this board!
EA81 Hitachi Air/Fuel Adjust?
Thanks! ..............
There are two vertically stacked screws to adjust Air/Fuel low on the Hitachi. I had the adjustment procedures when we replaced the carb but have lost them. Can anyone refresh my memory on which is which and the basic adjustment procedure. Even the factory service manual gives you the usual "This is beyond you moron, don't even try it!" statement. Thanks!
Well....ok.
Good for you! I had to replace wheel bearings after I decided to test how bad my steering wheel would shake at 85mph.
Abnormally high hot idle (Hitachied EA-81) -- any ideas?
For unknown reason I don't get e-mail notification about replies any more, so I didn't have a clue anybody else answered... Anyway, the choke plate was the first thing I personally checked with the airbox open. Tap gas before starting -- it closes like it should. Warm-up -- it's opening. The car sat for a good while, so first couple of starts the choke didn't want to open 100% (only 90%), but now it does open fully. We also traced all the vacuum lines and found 2 or 3 that were not where they were supposed to be, that fixed rough idling, but it's still idling way too high. There's barely 5-7K (if that) on the carburetor after we bought it (fully rebuilt), so the carb is the last thing I want to mess with, really.
Subusolo2nut, are you sure Hitachi choke on EA-81 is electric? I always thought it was mechanical.
I forgot to mention that the car has a rebuilt carb put on it about 2 years ago. Tapping (or even stomping) the gas does not render any results -- the idle only goes a notch higher. It would be too nice if this could be solved by adjusting the throttle cable, but I doubt it would help -- the car started doing it on her own accord, it sat for a while, yes, but nobody messed with throttle, vacuums or carb. I hope it's not the carb, not again! I will crank her up right now without the airbox and see what the choke plate is doing during all that. Also, isn't 13-16 ft-lb of torque kinda low? But that's what both books I have say. We tightened it to 20 though -- 16 sounded way too loose! My torque wrench has never been calibrated. Would it hurt anything if the torque is a bit off? UPDATE: On cold, I tapped gas once -- the choke closed. I started her and idle was very irregular at first then I tapped gas, it straightened a bit and went to 1500 rpms, but still sounded like the firing was very irregular. Then the same thing - it went up to 2500. At that point the choke was half-way open. I opened it all the way, idle went down to 1500, but still irregular. I guess I need to try cleaning the choke and see if I can adjust hot idle if it opens/closes OK after that. I hope we didn't fill the engine with crud while replacing the manifold gaskets. I also have a big exhaust leak around rear crossmember.
making photos fit
This is my cheap way to downsize pictures: Using "vew" option make your pic smaller on the screen (about however big you want it to be when you post) then push ALT+PrintScreen and then CTRL+V (or go to menu of your pic editor and choose "paste"). After that select your picture area and repaste it. Then save it as a JPG. This method works for me much better then dealing with pixels and compression levels -- it doesn't screw up resolution as much.
My 1982 GLF has developed a high idle problem. It starts good and cold idle seems fairly normal to me (1200-1500), but after it starts warming up, the idle instead of slowly going down, is slowly climbing up, to about 2500-3000 rmps. I am going to dig into the troubleshooting section of the FSM, but I'd like to see if you folks have any ideas. Before, I was blaming the abnormal idle on the leak in the intake manifold, but the manifold is (finally) back on the car with new gaskets, new original bolts and torqued to the spec, but the problem persists. I marked all the hoses well before taking the manifold off, so there shouldn't be a mix-up there. The only changes from "before" are cleaned orifice (in the eng.block) and metal pipe going from the block to the EGR valve (both were clogged dead).
Anyone have experience with GCK axles? Or Autozone's lifetime warrantee?
It's a bit off-topic, but relevant enough: I have life-time remans from O'Reiley, I replaced them twice (because of my mechanical illiteracy,not because they went bad I suspect) -- both times nobody cared what the returned CVs were like; if they're in the original box -- O'Reiley is happy. I personally, would never buy CVs on-line, ever (as long as I have a choice of course). Replacing a CV in gen.1 is a piece of cake (if you've done it at least once before), and I prefer to have a physical place to return them to, than some URL on the web!
Leather ve Cloth seats?? Which are better
Ma-fia replied to ssweb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeather makes my bum sweat -- no matter winter or summer. In winter it's cold in summer it's hot. I love the looks, but I doubt I'll ever own leather seats. P.S. I don't own dogs or children -- so clean up is not an issue.
Has anyone installed a grounding kit?
Ma-fia replied to Evanism's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn another board, not Subaru, quite a few people reported improved idling (this I care for) and in some cases a tiny bit more hp (I could care less about this) after installation of Hyper Ground System. However, you need to chek what is originally installed on your car, because many upper-end Japanese cars come with this system from the factory. It is fairly expensive though. I am planning on installing better ground on both my cars eventually, but I'll probably find quality wire and do it myself. Speaking in general (I don't own a newer Subaru), good ground is pretty important for newer cars' electronics in order to run properly. It definitely can not hurt anything.
Fron wheel bearings Q
If the clicking is only on one side, you can try to drive it for 15 minutes or so and then check the temp: if one side is much hotter than the other, you'd have your answer. I agree with everyone else: yes, bearings click just like CVs, I found it out the hard way by replacing the CV (at least it was free since I have both CVs under O'Reiley's warranty!)
Clutch and Vendor Questions
I've got mine (Luk, EA81 -- car in the signature) for $109 at Pep Boys 2 years ago, life-time warranty; they had it in stock, too.
Need punch size for cv axle swap
Gosh, I didn't even know there WAS such thing as a punch size. A punch of indetermined size and structrure to get the pin going + skinny screwdriver were all I had when I did CV swaps (3 or 4 times, all by myself...).
Kudos To This Board!!
Hey, I've got an '82 GLF, too. Welcome aboard! Where are you located?
Need a peek at an old shock absorber.
I finally looked at mine (sorry it took me so long), but they state that they're "made in the USA", which doesn't help much. I tried.
cd rom on ebay
Ma-fia replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDuh!!! I even knew about it. Of course it's the best option.
cd rom on ebay
Ma-fia replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith patience you'll be able to find pretty much anything on eBay: I've even got a FACTORY paper manual for a 2002 car (not Subaru) for 40 bucks! But I've been looking regularly for 4 or 5 months. If 2000's out, 2001 will be available shortly, just wait.
4wd 93 Loyale wagon for sale
Just re-post it in the marketplace, if you didn't yet. I think, that a lot of folks scan new posts anyway, so they'd probably notice it.
Artists needed for a logo design
Perhaps... I wouldn't know, since I'm color-crazy. That's why I almost always prefer black&white versions.
I will take a look at mine when it stops raining, I doubt they've ever been replaced.
Brian, your logos are so cool, esp. the black-and-white. It has a very complete, finished look, and the lettering can be added easily, if needed. Good idea about clothing line.
Need Subaru part number for Fuel filter
Are all EA-81s the same? Would it be same part #s for the car in my sig?
What do you think of rev-matching?
Re: starting while in gear Interesting... I couldn't find my ford owner's manual, but I doubt there's something like that in there! They brag about child seats, safety belts, air bags and similar crud, instead of talking about proper shifting and break-in periods.
