bigjim5551212
Everything posted by bigjim5551212
  1. We offer 3 items for Weber DGV DGAV series rebuilding Basic Kit, complete with all gaskets, needle valve, pump diaphragm, internal fuel filter Power Valve Diaphragm Throttle Shaft Bearing Kit- Our invention- get rid of the wobble on these carburetors throttle shafts. No machine work, comes with screws for the throttle shaft. We have all the jets, adapters, new carburetors. Call today, 1-800-665-5031 Look at this post for all the info on buying a used carburetor http://www.ultimatesubaru.org/forum/showthread.php?t=63806 also for more info go to http://groups.msn.com/WebersandStuff
  2. Depends where you are. If you are in Canada, you could buy from your insurance company. In BC, you can buy wrecks from ICBC if you meet requirements
  3. have you done anything about the rebuild on this Weber? Call me, I have all the parts including a bearing kit for the throttle shafts. If you look around on this site, my info on used Webers is there. Thanks, call me at 1 800 665 5031 Jim
  4. Can anyone give any hints on what you have to do to change the foglight bulbs on 04 Legacy GT Wagon. Thanks
  5. I see the cars coming thru ICBC. Saltaire does buy a lot, but the best one on the lower mainland is Aldergrove Autowrecking
  6. I have taken over a Legacy GT 2.5 Automatic. This car has, I think, a transmission issue and it is going to the dealer on the 26th of Dec. now, it gets rotten fuel economy, like it goes thru about 25 litres in 160 km or 5 gallons in 100 miles. like 20mpg. is this normal?
  7. look at www.addco.net www.stracing.com www.tirerack.com www.hrsprings.com www.eibach.com do a search for sway bar manufacturers as well
  8. The cost on this will be $250. This includes the normal rebuild parts, cleaning, ultrasonic treatment, bead blast, painting and reassembly with our bearing kit. And we hot test all our rebuilt carburetors.
  9. First of all, a Weber or a Holley is not "close enough" . I have seen too many people out there that start to file away at the holes to make something fit. This is why you do need an adapter plate. For the Chevette carb, OK, there are some with a Holley 2 barrel, but there are a lot with the Rochester as well. The old problem with the Holley is this.... Lack of idle jet adjustability Linkage goes the wrong way linkage arm is peined on and not bolted. This is exactly what is shown on the Ebay ad If you buy from our company, you are getting personal service, someone to talk to about linkage and installation and you are getting selection. Remember there are three things in business Service Selection Price No one can give all 3. Only 2 of those.
  10. Used Weber Carbs - Where to look Ok, for all you guys that hunt JY's. If you are going to look for a Weber Carb, this is what you should look for. First I will mark the cars and trucks, and then the model of carbs. I will be pleased to tell you if the carb is worthwhile if you find something else. I have the repair kits available. Vehicles Datsun/Nissan - carbureted trucks and cars pre 1986 L, Z, A, E series engines Toyota - Corolla pre 87, Celica-pre 81, Land Cruiser 80's and earlier, Pickups pre-88 Mazda - B2600, B2200 trucks. Most cars had people that didnt care about performance other than rotaries Suzuki - 1300 Samurai Mitsubishi/Dodge D50 - carbureted pickups, Raiders, Colt front drives BMW - 2002 with 2 barrel manifolds (best place to find Webers) Opel - Opel GT Volvo-non fuel injection cars (144, 122) Jeep-CJ, Wrangler with 258 motor Ford - Old Cortina mark 1 (1967?) Carbs to use 32/36 DGV (manual choke), 32/36 DGAV (auto choke), 32 DGAV, 32 DGV 38 DGAS Maximum performance, mileage will be lower 36 DCD, 28/36 DCD Questionable carbs Holley 5200/Weber 32/36 DFAV - linkage reversed to DGV series, most Holleys have linkage that is not bolted on and some have non changeable idle jets, throttle shafts wear easy Fiat Webers, DMSA series harder to get parts, linkage reversed, Renault Webers DIR series- same as Fiat If you are handy, and have access to parts, the Renault and Fiat carbs will work OK
  11. I have a toll free number, 1-800-665-5031, this number is good in the states. Our business is Overseas Auto, in Vancouver Canada. We ship outt of Point Roberts Wa, and I drop ship from one of my suppliers in the eastern US. If you are being charged $3 a minute for long distance to Canada, you are being ripped off. If you use Yak communications, its 5 cents a minute. Anyway, we have new Webers for $360 for the whole kit. We have repair kits, jets, whatever you want. We rebuild them and we also have something very cool, we have a bearing kit for the Weber DGV throttle shafts. NO MORE WOBBLE.
  12. I had this issue on a 88 GL10 turbo auto. I think the rad was gone. the car worked fine otherwise. all the fan worked etc. I must say, that I never changed the thermostat.
  13. dont substitute 17mm for 11/16" its not close enough for me. and if you have any 21mm the 13/16 sometimes does not cut it.
  14. Hi, I have been doing some research. I think the best tire from what I have read, talked to people and talked to tire stores, is the Nokian WR. It is a great all weather tire and has the snowflake symbol on it as well, making it a true snow tire. The other tire I have looked at, and has a lot of good reports is the Bridgestone Potenza G 009 A lot of people like this tire and it does well in the snow. I have been using the Kumho ASX on a Mini Cooper S. I am not that happy with them, they tend to hydroplane a lot.
  15. I promise to look at this website on a regular basis. Our business has all the Weber kits, parts, jets, repair kits. I have a guide to buy used Weber carbs as well. I will post this again. Jim
  16. We sold a carb for a 87 the other day. It is coming back because it is going to hit some bracket on the power steering. Has anyone heard of this? and what is the remedy
  17. If you are looking for Webers, new or used or rebuilt, call me. Overseas Auto, 604 879 6288 Vancouver, Jim
  18. If you need any info on Webers, call me or visit my websites, http://groups.msn.com/webersandstuff www.overseas-auto.com
  19. Your primary idle jet is too small. The way it works is this. If you have the idle mixture screw open, say 7 turns, then you are not getting enough fuel. To prove it, your engine diesels when you turn it off. This is because the temperature in the combustion chamber is higher than normal, and therefore, the carbon that sits around glows red hot. You turn off ignition, and the engine still sucks gas, it gets to the combustion chamber and the glowing carbon doesnt need the spark to keep fuel burning. you need one or two sizes bigger than what you have. I can help you, call me at 604 879 6288, ask for Jim. Our business sells weber parts among others
  20. the secondary idle doesnt do very much. it may help with a hesitation when the secondary barrel opens
  21. Here is my guide again for people looking for Used Weber Carbs at the JY or on Ebay Ok, for all you guys that hunt JY's. If you are going to look for a Weber Carb, this is what you should look for. First I will mark the cars and trucks, and then the model of carbs. I will be pleased to tell you if the carb is worthwhile if you find something else. I have the repair kits available. These vehicles had Webers as conversions only. No car in the US or Canada came factory with the DGV or DGAV Vehicles Datsun/Nissan - carbureted trucks and cars pre 1986 L, Z, A, E series engines Toyota - Corolla pre 87, Celica-pre 81, Land Cruiser 80's and earlier, Pickups pre-88 Mazda - B2600, B2200 trucks. Most cars had people that didnt care about performance other than rotaries Suzuki - 1300 Samurai Mitsubishi/Dodge D50 - carbureted pickups, Raiders, Colt front drives BMW - 2002 with 2 barrel manifolds (best place to find Webers) Opel - Opel GT Volvo-non fuel injection cars (144, 122) Jeep-CJ, Wrangler with 258 motor Ford - Old Cortina mark 1 (1967?) Carbs to use 32/36 DGV (manual choke), 32/36 DGAV (auto choke), 32 DGAV, 32 DGV 38 DGAS Maximum performance, mileage will be lower 36 DCD, 28/36 DCD Questionable carbs Holley 5200/Weber 32/36 DFAV - linkage reversed to DGV series, most Holleys have linkage that is not bolted on and some have non changeable idle jets, throttle shafts wear easy Fiat Webers, DMSA series harder to get parts, linkage reversed, 1800 carbs will not fit adaptor Renault Webers DIR series- same as Fiat If you are handy, and have access to parts, the Renault and Fiat carbs will work OK
  22. Here is my guide again for people looking for Used Weber Carbs at the JY or on Ebay Ok, for all you guys that hunt JY's. If you are going to look for a Weber Carb, this is what you should look for. First I will mark the cars and trucks, and then the model of carbs. I will be pleased to tell you if the carb is worthwhile if you find something else. I have the repair kits available. These vehicles had Webers as conversions only. No car in the US or Canada came factory with the DGV or DGAV Vehicles Datsun/Nissan - carbureted trucks and cars pre 1986 L, Z, A, E series engines Toyota - Corolla pre 87, Celica-pre 81, Land Cruiser 80's and earlier, Pickups pre-88 Mazda - B2600, B2200 trucks. Most cars had people that didnt care about performance other than rotaries Suzuki - 1300 Samurai Mitsubishi/Dodge D50 - carbureted pickups, Raiders, Colt front drives BMW - 2002 with 2 barrel manifolds (best place to find Webers) Opel - Opel GT Volvo-non fuel injection cars (144, 122) Jeep-CJ, Wrangler with 258 motor Ford - Old Cortina mark 1 (1967?) Carbs to use 32/36 DGV (manual choke), 32/36 DGAV (auto choke), 32 DGAV, 32 DGV 38 DGAS Maximum performance, mileage will be lower 36 DCD, 28/36 DCD Questionable carbs Holley 5200/Weber 32/36 DFAV - linkage reversed to DGV series, most Holleys have linkage that is not bolted on and some have non changeable idle jets, throttle shafts wear easy Fiat Webers, DMSA series harder to get parts, linkage reversed, 1800 carbs will not fit adaptor Renault Webers DIR series- same as Fiat If you are handy, and have access to parts, the Renault and Fiat carbs will work OK
  23. 1)There are several adaptor plates for the EA82 that can be used. Has anyone used the "datsun" thin adaptor, redline 99004.300 ? 2)Is there water coming to the carburetor from the Manifold? Will this have to be blocked
