Everything posted by ()__1337_CRAYOLA__()>
Rear speakers in a Loyale Wagon?
()__1337_CRAYOLA__()> replied to McDave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
why not just use the cargo cover to cover the sub thats what i did on my 91 loyale and i used one of the low profile subs in my brat those things are pretty good -
EA81 Valves Tapping
()__1337_CRAYOLA__()> replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
im talking about my 1983 brat i do have a 91 Loyale, 87 RX and a 02 WRX tho and neither of the EA82 have the TOD -
how do i tell if it's a hydro block or a solid lifter block..... i assume loose valves can lead to some gas milage loss but im unsure if i have a hydro or solid lifter block do i need to check the vin but then i dont know if the engine had ever been replaced im lost anyone wanna shed some light on this situation?
'86 GL Needs New Horn
()__1337_CRAYOLA__()> replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if u want manly horn action get a air horn LOL -
Wiring up factory fog lights.
()__1337_CRAYOLA__()> replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have those fog lights on my brat but when i pull the switch they come on as well as the high beams turn on very slightly is that normal? or do they needa be rewired -
still fighting with my 85 brat
()__1337_CRAYOLA__()> replied to subyrally's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ebay there is a new complete weber kit for 320 shipped -
my brat was doing the same thing then i put a weber on it and supprise NO MORE FLAT spot off idle and cruising maybe u should try that -
Cruise Limit : HC (PPM) 220 CO (%) 1.2 Cruise Emissions: 462(FAIL) 5.13 (FAIL) Idle Limit: HC (PPM) 220 CO (%) 1.2 Idle Emissions 1192(FAIL) .44 (PASS) Anyone have a idea on whats going on or anyone had this problem with theres.... engine was rebuilt 50,000 ago and is still tight very little blow by runs smoooth no misses..... turbo still alive and kicking no oil leaks or burning im at my end with this subaru it's about to go to the Junk Yard
smoke show
()__1337_CRAYOLA__()> replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think the poor hatch is pissing on the ground in the second pic -
how hard is it to change the oil pump gasket car still has good oil pressure... 25 at idle and 50 at cruise. also the pan gasket is leaking to how hard is that to change i notice there are a few bolts on the back of the pan covered by the crossmember. does this require unbolting the motor mounts and jacking it up?
AND TO TOP IT ALL OFF ..... after i bought the weber and got it on it's way to my house i go fill up my brat cause my gas gauge showed 1/4 of a tank i got 25 mpg..... i have no idea what happened.... maybe making the vacuum advance work helped or the computer had to relearn everything although i donno if thats possible on this old tech...
