Everything posted by jon38iowa
Michelin X Tires
jon38iowa replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know about the Xs but I recently put Uniroyal Tiger Paws (made by Michelin) on my Forester, Moreover, I am very pleased and wouldn't hesisitate to buy the X tires. John
Low Gas Mileage 2001 Forester
jon38iowa replied to librarygal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI recently put both front and rear deflectors on my Forester, I have not noticed (With mixed driving)any fuel mileage change whatsoever; It sure is nice to have a clean back window. John
Alignment & Camber Problem '01 Legacy Wagon - HELP!
jon38iowa replied to JulesSoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi: I don't know about the wagon, but on my Forester I am told there's a camber adjustment built into the top of the struts. By the way I had the same issue as yours- slight pull to the right, however it took two different shops( $200.) to get the car back to perfect. John
Tire and Forester maintenance question
jon38iowa replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust my two cents: Last week I put Uniroyal Tiger Paws on my Forester! Wow the ride is awesome- quiet and soft, this car has a slightly hard suspension in my opinion and these new tires made all the difference for me. They may not quite last as long as harder tire, but they are rated at 70K. I am not familliar with BF Goodrich, probably a very good tire. With that many miles I would have your mechanic to good luck at the Struts (4) and all the components to the steering; If you put new tires on a car that has issues with these, the tires may very well wear out prematurely. John
ABS light on. Nut holding rotor came loose?
jon38iowa replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree, moreover, I think its a good idea to check after work is performed of any kind. If one finds an issue then the shop can't blame it on mileage. John
jon38iowa replied to librarygal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would definately replace the tires(I don't know if they effect mileage)- perhaps the one new tire can be matched with three more; The transmissions in these cars are $4000. Just this week I put four new Unitoyal Tiger Paws on mine- awesome performance! I also recomend running a fuel cleaner( seafoam or other high quality) through your gas tank, and then change your fuel filter.When I changed my air filter I went with the new Air Hog, morever, it seems to run a little better with this kind. Even when everthing is perfect I have noticed these cars fluctuate in gas mileage, a little more then the average car. Mine for example: If I run the air conditioning it saps the mileage and alot, as will fast off the line driving, however if I take it slow then I can sometimes get upwards of 30 mpg. I have also noticed these cars are sensitive to the kind and grade of gas; Regardless of what the book says(and this is a high mileage car), I found mine runs much better on 89 or 90 octane, moreover it hated ethanol blend and this evident by poor mpg. John
New Tires!
I had four new tires (uniroyal Tiger Paw) mounted on all new OEM rims for my Forester today! The ride is night and day over the not so old Coopers they replaced, moreover, it feels almost the equivalent of getting new shocks. Ofcourse the real test will be long term wear, and winter traction. John :banana:
jon38iowa replied to librarygal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi: I noticed a signifigant improvement in mileage after relplacing my front O2 sensor on my '99 Forester. I think I would start there. I hope its not the case for you, but my mechanic mentioned to me that a sure sign of a Converter failure is decreasing fuel economy; This would be unusual though as Converters last forever, unless a person gets really bad gas. Good Luck. John
99 Outback Head Gasket question-advice?
jon38iowa replied to michelle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree, this seems to have worked for my Forester as well. John
Buying advice please - 99 Forester
jon38iowa replied to ZGLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would take it to mechanic for a thorough inspection- compression check, etc,. I might be the best money spent, and if something is in need of repair, gives you a bargaining tool. You can tell quickly if it is phase two engine by: the very front of the engine, it has a black plastic cover ( it covers the belts and pulleys). Look at one side, if it has two circular areas from top to bottom then it is the phase 1. If all you see is one circle near the middle, then it is the phase two. You can also look these engines up on ebay under EJ25, this will give a good visual with the engine out. John
jon38iowa replied to ZGLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Kevin: I have a '99 Forester. The car overall has been a good car, though I am having engine problems ( bought used, with poor care from previous owner) it still has surpassed my expectations in almost every way. I think Subaru switched to the Phase two in March, of'99 , check your door sticker. A few quirks that i have noticed: on humid days if I leave the temerature control to cold, I get moisture on the inside of the windows ( easily remidied by turning to hot, when off) and it is hot and humid here in Iowa. As these 2.5 engines age, they develop cold start up knock, moreover it goes away as it warms, and I am told it's harmless. I have also noticed that ( after 25000 K) this car is a little sensitive to the octane in fuel, mine requires 89 for optimal perfomance despite what is recomended, but thats with 132000K. These engines I have on good authority will last indefinately, however I do recomend following the service schedule. Whatever it says, I do it before it is required- cheep insurance to me. For what it is worth I would buy another Subaru in a second. This company offers a lot of car for the money in my view, moreover, I think it is kinda fun to own a unique car like this! John
jon38iowa replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBy the way; Last time I had my tires rotated, the service person didn't tighten the lug nuts enough! The next day one was missing and another was half way off! The shop manager fell over himself appologizing, moreover, he happily replaced the missing one with a new OEM nut, and he had the guy who goofed check all the lug nuts. These things happen at every shop, at least, occcasionaly. John
green box- what is it?
jon38iowa replied to tlo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry Trish: One more suggestion: If they don't clean all the grease off it will smell for weeks! I bought some heavy duty degreaser( don't get it on the rubber parts of the engine) and took mine to the car wash. Let the engine get warm but not hot, then wash away the area( obviously be careful not to get water where ya don't want it, I Bought little gladd cover bags) and pay particular attention to the back of the engine, top of converter(looks like a fat muffler) and transmission housing. One last thing, my mechanic recomended to always park with the wheels straight ahead-this puts less strain on the boots. Not so coincidently , mine failed not long after I started parking ( odd place at work) with the wheels strongly pointed toward the right. And was also told as above that the heat from the converter is a factor. John
jon38iowa replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf he (where you originaly had it worked on) is a reputable Mechanic I would offer this guy two choices: Fix it to your specifications, or face a law suit. John
jon38iowa replied to tlo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey Guy, Sounds to me like an inner CV boot cover; I had to replace mine('99 Forester), it costs about $ 200.00 (for both) installed. John
99 Outback Head Gasket Help Colorado
jon38iowa replied to longrange2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree! This having a '99 Myself; It would cost more upfront, but you would have: a tight fresh engine, a good warrnaty, and the peace of mind of not having to repair the engine again in the near future! John PS. Let us know how you come out.
Wheel bearing???
jon38iowa replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI usually have mine (need it or not) done when the rotors are replaced, moreoever, it doens't cost that much since it is already pretty much apart. John
timing belt replacement
jon38iowa replied to edjhover's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI paid about $500.00 for a my timing service( included new seels). I hear from good sources that is also wise to replace the water pump, moreover, I would have them evaluate the tensioner- if any signifigant wear then I would replace this as well. John
Water in the spare tire well. 1996 impreza
jon38iowa replied to harpua's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHello: If you see any visible rust, then I recomend a quick sanding and application of rust primer. Just my two cents, living here in the heart of the rust belt. John
Paint spider cracking on 2000 Outback
jon38iowa replied to taitcyrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think yours is the proverbial rarity; Most older Subarus I see still look really good compared to other autos their year! The price Subaru is offering you sounds very good; They charged me $ 575.00 just to sand and paint part of one door(they did a perfect job)! Good Luck, John
Leaks Gas Inside-outside FIXED
jon38iowa replied to Rhubey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a strong possibility of a puncture or dislocation. Good luck with. John
Paint Peel 2001 Outback
jon38iowa replied to Taeg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would be surprised if a warranty would cover paint damage to used car, morever, you might consider Macco. My cars bumper was hit in a parking lot( the person didn't bother to say anything) and didn't want to turn it in on insurance, thus I gave Macco a try; Their price was half what I was quoted elsewhere, moreover the job they did was very good! A few minor flaws, but nothing I can't live with for the price. On the tires, you might get away with overinflating them a bit, however, please don't ever underinflate them! As I recall several people were killed in Ford Explorers as a result of Fords recomendation to underinflating its Firestone tires. The airconditioner also saps a little mileage out of my Forester, but I don't mind because it works awesome, and in Iowa, with our humidity we need it. John
jon38iowa replied to Rhubey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree; I have seen a few burn victims from auto fires; Please have it taken on flat bed trailer to your mechanic! John:headbang:
2005 Legacy 2.5GT FRIED!!!!
jon38iowa replied to Gravityman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats! Can I ask, did they say what might have caused such an early Turbo failure, and is this common? John
99OB struts
jon38iowa replied to billyfrank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI very much agree! After suffering with Monroe replacements ( last car) I now only use KYB; They might cost a tad more, but the quality is night and day. John
