jon38iowa
Everything posted by jon38iowa
My employer provides me a work car. Recently I was given an '05, Loaded Camery and it was the most uncomfortable car I have ever riden in! The seat had more adjustments then any car I have ever seen, but it made no difference. The head restraint were permantly tilted in slightly, so my upper back could never completely go back without craning my neck. I was very happy when they gave me a chevy! Shocking as that sounds, I'd rather drive junk, then be miserable.
It sounds like a minimum of $ 1500. not counting the engine. That would add another 1-5K depending on which method you opted for. I know this first hand; as of now I am into my Forester for $10,000., just in repairs(not counting tires and upgrades). This, over the past three years. The car runs and looks great, but it is only worth maybe $3000.00, if I am lucky. Looking back, It would have been wiser to trade it in on a newer Subaru and make a car payment.
Indeed: These vibrations can be really hard to track down. Mine does the very same as yours. About a month ago shop #1 recommended I take it to a Transmission shop, because to them it felt like, "torque converter." I took it to transmission shop #2 which then looked over and test drove to inform me it was,"in the engine." It spent two weeks at shop #3 where this very knowledgeable mechanic, could not find anything significantly wrong, though he did mention there was some,"play in the drive shaft." And something about the Splines at the end of the drive shaft looked worn. Even this he said," might not be the cause." I had the fuel injectors replaced because they were do for it anyway, moreover, it helped the performance dramatically, but did nothing to eliminate the vibration.
I've been using a product called Rust Bullet. It not only stops any rust in its tracks, but also, it creates a tough, durable coating. I am told it is so effective, it is used on Navy ships. It is some work to: Put the car on ramps, and basically paint the underside of the car, however, so far the undercarriage shows no new rust whatsoever. Additionally I bought the chemical Dryer additive- this allows for much faster drying time.
I have had great success with Casterol 10w30. I change it every 3k and it looks like fresh oil even then. Doesn't burn or Use any measurable amount between them. I used to buy after market filters, but now I order from Subaru. They don't cost substantially more, and I have noticed they are heavier and look better made to me, than many after market filters.
Amen! The point may have already been made, but one must quickly assess the given situation: Obviously, if swerving means going off a cliff or hitting an on coming car head on, then smashing into the deer would be preferable. Having a lead car can give one a false sense of safety. Example: Last year on the Highway I observed a deer nearly walk out in my path ( no time for any reaction) and seconds later, the van behind me hit head on. Pretty scary if ya ask me. The fog lights Subaru Are famous for are awesome. Generally here in Iowa, if you see one deer, you will likely be looking at many more in the vicinity if not closer. I watch along the highway shoulders(at night) and can usually spot em by the reflection of their eyes- kinda resembles a flashlight. 23 years of driving here, so far the only creature I've hit was an unfortunate Barn owl, couldn't get stopped in time.
Here in Iowa, where we have a heavy deer population, I have seen more then once: Where one has rolled over the hood, and smashed through the windshield killing the occupants. No, unless I am in a semi, I am swerving- Away from traffic if possible. I have a near miss, once year at least. Luckily no accidents so far.
1998 Outback
jon38iowa replied to cobcob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Mine had a really bad heat shield rattle, all it took was a large clamp to hold it tight. No more problems,and only a few bucks. -
And I would add, even going to a high end store like Napa, doesn't always equal OEM. I bought their $55.00 set for my Forester, which worked fine until the first time I had to remove them. Only a year old, they tore apart like a rubber band, and in contrast, the OEM originals were still in perfect shape at 8 years old. Live and learn:)
