weddes05
Everything posted by weddes05
SVX Don't Stop
weddes05 replied to ecky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
what was it? -
SVX Don't Stop
only allow air to flow one way, providing the booster with vacuum but not allowing the vacuum to escape when throttle is depressed. -
is it going all the way back to lock pos? if it isn't try just messing with stepping on the brakes turning the ign. on and off and shifting back and forth through the gears. it will happen alot if you are used to driving a manual and you shut the key off before putting it into park. i am guilty of that i dont know how many times.
Clicking LSD?
weddes05 replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Check to make sure the axle c clip is fully engaged into the diff. We had an RS in that a local well known trans shop....not mentioning any names...miss-diagnosed first as a clutch, then a trans. they sent it to us and it just turned out to be the clip in the rear axle was allowing the inner to slide in and out. you would launch the car hard and it would click a couple times and then acted like neutral. -
SVX Don't Stop
What type of check valve did the SVX booster use? The legacy has one in the hose that goes from the manifold to the booster. I would go out and check a parts car but it is about 0 degrees right now. -
i dont know for sure that the 99 would be classified as the phase 2 block, just because it is an 8 bolt? it does still have the phase one pistons with the square valve releifs. 96-98 were all 4 bolt and the 99s were 8 bolt. I have encountered a few 4 bolt motors bolted fast to a 8 bolt trans, just pulled one the other day in an impreza that was too low of mileage to have been replaced.....just think it is subarus trying to finish off the last of their stock for the line change. The JEBA trans is deff an 8 bolt as well as the 2.2 JEAA trans, and yes they are some of the first phase 2 style spin on filter transmissions.
