Everything posted by 86BRATMAN
Proud new Owner
Wait Wait Wait... Your thermostat is on the top water neck on the motor, not the bottom. And explain a little better the not having a sturdy place to jack...
Proud new Owner
The Brumby is exactly what you have in your driveway. But never came with the jump seats, and are RHD. Same exact vehicle, just named different in the land down under, and a few other places. Europe they were called MPV, and middle eastern countries they were just simply the Subaru Pickup. BTW... Check out some of MattyB's posts... (you'll enjoy them)
Viscous Coupler failing?
86BRATMAN replied to wilco's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo I'm ok then... Ya'll had me worried I was gonna have to get another centrel diff. So whenever I get it put in the car, just fill it up like normal and I'll be good right... Nip, I've never had an ea82 car, but the ea81 4spd from the brat did leaked out just like the ej 5spd. Are you sure you had fluid in there:lol:
EA81 4 door sedan questions
No difference at all. They were availible in 4wd's. I've never seen a factory manual one in person however...
Wheel size and cabin noise
86BRATMAN replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm pretty sure he has a set of the 97-99 Legacy GT whels that were for sale a couple weeks ago.
95 Legacy clutch / transmission problem
You're fired....
86BRATMAN replied to wilco's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI might have an issue then... When I pulled the trans out of my 90 legacy donor fluid poured out of the back...
Rear seat belts for 1999 Impreza RS
86BRATMAN replied to bowjam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXErrr, um....
EA82 turbo fluflutters
Bastard....
I'm taken aback by somebody not liking the hill holder. I love it to death. Especially in the mountains around here. All you need to do to disable it is to take the cable that actuates it off the clutch fork. Completely removing the system will require getting brake lines from an auto car or having lines custom bent. Very costly options considering the easy option. Hell I'll take a picture if you'd like of how to remove the cable...
EA82 front brakes on EA81
You are correct.
Looking to buy a fuel injector!
According to that the ones I have aren't the same as yours. Mine are from a 90.
I've got a set pulled from a good running motor.
94 Legacy ej22, can I swap in a 97 OBS 2.2
86BRATMAN replied to Mike621's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a null point if you keep the t-belts changed.
Proud new Owner
Thats the way the seats come stock. Welded in... It sound pretty decend from what you've said, just needing a few little things. The ea81 radiator will do fine for the ej22, I would say that you might need a new one though. Like everybody else has said get a feel for Steve before deciding on what to do with him. Each vehicle will have its own personallity about it. He will let you know whats right for him. Whenever you get all the issues worked out on the body and stock motor and cooling system, then worry about getting more power for it. Plenty of super great info on this site for anything you might run up against...
86BRATMAN replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts not the bigger wheels. Its the shorter sidewall on the times. The tires don't absorb as much road vibrations and such. So it gets transmitted more. It could also be the particular tread pattern making more noise as well.
86BRATMAN replied to Mike621's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse all your 94's sensors, grab the exhaust off the 97, its not dual port like the 94. If the obs is an auto use your 94's intake manifold to avoid the egr system. And plug the holes in the head where the egr goes into.
85 Brat for Sale
I spoke with her about my set.
I got hit by a deer (Now with pics)
Oh damn... Yeah thats gonna leak...
Thats an evo injector. One could probably make it work.
86BRATMAN replied to bowjam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny year 2 door impreza belts will work. Call Import Auto Salvage in Salem, VA they usually have a few of these cars sitting around. Also Check with Old Dominion Auto Salvage In Roanoke VA. I don't have the numbers handy but you aren't far from those places...
The Rust Pics!
Agreed. Its nowhere near as gone as my 86...
That pillar isn't a good sign. But does it leak and water? If it doesn't I really wouldn't worry about it myself... You could get a body shop to pull it back out, most nowdays tack weld pull rods onto the metal and can get it straightened out like that. But that would probably get a little spendy if it doesn't leak.
1980 Gl w/EA71
That accel coil probably isn't a good idea...
Going to look at another Subie Wed. Night
86BRATMAN replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat has an ej22... No HG issues with that motor unless its been abused. Also torque bind is more prevelant in the gen1 legacy, my mom's 98 has almost 180k on it with never a problem from the trans. And NO repair should cost 3X what you are paying for the car, unless you take it so a shop and they stick it to you hardcore.
