Everything posted by 86BRATMAN
interchangeable driveshafts parts - 97 impreza
86BRATMAN replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as its a gen1. The gen2 is a little longer car.
strut help
That could be one of two things. The other one could be bad, or that one could be stuck
EJ22 swap-o-rama!!!
it was random, I just wanted to subscribe so I could find out why...
EJ22 swap-o-rama!!!
Might it have something to do with some sort of thing that involved 5 of something?
strut help
How far from hitting the hole are you?
JUSTY OWNERS; Thought I`d share this from another site I belong to.
I think 99hp is worthy of an award in itself...
Where Has WORLD RALLY CROSS Gone??? TV???
Unless they go to one of the two tracks where there are right turns.
Is it an Outback? is it a Legacy? you choose!
86BRATMAN replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd have to disagree... I sit lower(well my motor does) than my buddy's lowered wrx. I have no skid plate and live on a bad rocky driveway.
look what i just got
Congrats man. I had called about that one. Guy didn't seem to know a whole lot about it. Said he hadn't driven it much because the clutch was slipping. You may be able to adjust it up and get some more miles out of that one.
Question re: 15" rims for a 96 Legacy
86BRATMAN replied to tubbs&crockett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe link Ed posted is a great one. BTW 205/55r16 is what subaru put on the GT's from the factory. And IIRC it was 195/60r15's stock.
Help! bad head gasket? (retitled)
86BRATMAN replied to newsance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou wouldn't hear any bad noises if your rings were shot. Just a lot of blue smoke. It does indeed sound like a joint cyl head gasket failure. The 91 T-leg I have did this on the way home when we bought it. It wasn't smoking much at all. But 2&4 were both wet inside when I pulled the heads off.
How hard are Baja seats?
86BRATMAN replied to bulwnkl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the rides I've taken in a Baja I'd compare the seats to 98-01 2.5RS seats over the others. I like them myself. Not near as still as the leather in the 04 Legacy GT we test drove.
Could This be a Catalytic Converter
86BRATMAN replied to schlit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep. Most likely the first o2 sensor. Mom's 98 legacy has an intermittant code, I forget what the number was, for emmisions control. Mechanic had her ready to fork out money for a new cat... I fixed it for the price of the o2 sensor, whatever it was 3 years ago.
strut help
You are probably going to have to use more than just your strength to get it to compress enough to go in. Like a floor jack and a piece of wood on the hub.
Oil Plug Question
What... Theres a ring there?? Nah, I think it goes flat side to pan.
SWAP advice
Have you actually weighed the difference in the flywheels? Honestly... How much less would the flywheel weigh at xt6 spec. The clamping force would far outweigh the "loss" of a couple ounces.
Weatherstripping,windshield gaskets,rubber sealing parts Group buys
You can put me down for one. I'm sick of looking at a wet floor.
4EAT dented pan - easy fix?
I've seen the lsd additive put to use before. About 4-5 years ago my mom's 98 started the early stages of TB. Our mechanic had dad put it in there and go to an open parking lot and drive in figure 8's for a while.
errr Rotor issue
This picture he sent me best dipicts where the piston is at. From the best of my memory it needs to go at least another 1/8 to 1/4 of an inch father in. I use the little tool that skip posted up, with a big 1/2 drive ratchet reduced down and a 3" extention. Gives me a lot of leverage on it.
Am i NOT suppost to use NGK platinum's with a EJ22E(non turbo) engine?
86BRATMAN replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would stick with the BKR6E-11's myself. I bought the uber expensive irridiums for the SS. But my other non turbo ej's have always gotten the standard plugs with ngk wires.
86BRATMAN replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was taken from a 93 owners manual for the non turbo listed.
EJ BRAT's first drive on freeway
This is 100% OT but. s'ko did you ever correct the camber issue on the brat. I mocked up the front 5-lug on a parts car today and toticed that even with the camber adjusted as far correct as I could I still had horrid looking camber. I'm thinking ea82 or xt6 lca's will fix the issue. Anyways, back OT... Glad to see its getting you around now. And you might want to look at a thread in the new gen area about making a hybrid ej18/ej20 headed turbo motor.
86BRATMAN replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost parts store batabases have the oe plug type noted. At least they do where I buy plugs(advance auto). If you have an owners manual it should also be in there. Matter of fact I have one... NGK BKR6E-11
Danger in driving w/no driveshaft on AWD car?
86BRATMAN replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is my stand piont on the issue at hand as well...
The EJ swap begins!!
They are over near the throttle body on my mom's 98 legacy...
