Stupidru
Everything posted by Stupidru
  1. So what obstacles did you run into w/ your ea81t? Is yours lifted? Did you use Jerry's kit? Did you use washers? Which 5speed did you use?
  2. On my ej22t can i remove timing covers without removing alt - ps - ac? I think timing belt is snapped, compression is very low.
  3. Nice Find....TurboBrats are very rare, engine alone (pushrod turbo ohv) is few & far between. Take care of rust right away...this is a collectors car. I don't know how much you paid...but TBRAT in good condition should have a good return. On my 84 TurboWagon I seafoamed the throttle body....boost gauge didn't read the same...but didn't loose power. I'm gonna cut out cats soon too. Good luck w/ her!
  4. No....me stupid...you Matt! :-p So who..on the board..has done the 5speed conversion...who previously had automatic tranny 4X4...just so I know who to ask...someone w/ experience for my particular model/sheet-metal.
  5. How high of a lift is required not to have any tunnel pounding or other obstactles? I probably going to do pushbotton5speed on my ea81t......i'm tired of this piece of s**t auto tranny
  6. PhatBrat...No I keep forgetting....Gary's helping me rebulid this ej22t....I found some parts for his ej22t....so he's helping me fix mine.
  7. Gary said that cap should be tight, that engine gets it air through PCV systems. He said to by new subaru pcv valve, that engine should not suck my hand to the oil fill.
  8. Should oil fill cap be snug (sealed) or loose (to allow air to enter crankcase). When I remove cap at idle, the rpm's drop like engine is going to die, then they pick back up. when I put my hand over oil fill, it sucks my hand to opening. Always my dipstick is push out....like air is pushing it out. Is my engine screaming for air...like a pcv valve problem? Has anyone else experienced this...what was the fix?:cornfuzz:
  9. Hey Benebob, How ya doin....do you ever run across decent gl checkerboard cloth w/ vinyl edge seats 84-88? I need blue ones. I can never find these frigin things on MY yard visits.
  10. chevron techron fuel injection cleaner....i went from 16 to 22 mpg on next fill-up.
  11. you can download this codec for free @ http://www.divx.com/divx/
  12. Would this same thing work on an ea81? My handling is terrible.
  13. Stupidru replied to a post in a topic in Old Gen.: 80's GL/DL/XT/Loyales...
    Check your turbo oil drain hose. If it becomes clogged or pinched it will make your turbo squeal...it happened to me.
  14. 267 / 12.1 = 22.06611570247933884297520661157. WOW! This s#*t really works! Whoever has bad fuel economy w/ a Subaru Turbo....this stuff worked for me. Was getting 16 mpg...during tank w/ Chevron Techron 19 mpg....after tank w/ Chevron Techron 22 mpg.
  15. I've owned both...turbo manual & auto. The only thing I missed w/ an auto was downshifting into turns...otherwise I THINK their equally as fast....ones faster than the other in different senario's.
  16. this fill-up i got 19.3 mpg....after a member suggested Chevron Techron....sorry about the sarcasm guys. Next tank I'm going to try the 3 bottles of Prestone Fuel Treatment trick...to see if it will eliminate the surging & rough idle:brow:
  17. I have an 84 brochure...all ea81t's have 14.5 gallon tanks...and 24 city - 30 highway. Yeah...car is tuned-up and running smooth w/ the exception of some surging & rough idle. As odd as it may seem...car is running good...it the mileage that sucks...thats why I'm asking if anyone remember that post about the vacuum advance freezing...and I think I remember skip saying something about a thermo switch that affects mileage.
  18. 1. How long has it been this way? As long as I have owned the car...1 1/2 years. Resently got engine running right, thought cracked head/burnt exaust valve had something to do with mileage. Now I know that wasn't the fuel issue. 2. Is that all city driving or is there a lot of highway driving in there too? An equal amount 3. Are you getting into the gas/turbo a lot? Does a bear **** in the woods? 4. What kind of gas are you using? Try 87, try premium, see if theres an improvement on either one. Always 91...OK I'll try 89 on next fill-up. 5. Is the timing set properly? It is slightly advanced. 6. Do you have any exhaust leaks? No..not that I'm aware of. 7. Towing or lugging around a lot of stuff in the car? No...never. 8. 223 / 13.6 = 16.397058823529411764705882352941 You do the math. Ea81t wagons out of factory were 24 city & 30 highway w/ a 14.5 gallon tank. I have always hovered around 200. Thanks fellas
  19. cmon guys....nobody has ever had bad fuel economy?
  20. I remember hearing something about frozen vacuum advance & another about a thermo switch...can anyone shine some light on this for me? My ea81t is only getting 200 miles to a tank, I've tried about 5 different types of fuel injection cleaner to no avail. Someone PLEASE HELP....with gas prices skyrocketing, it's burning a hole in my pocket.
  21. Staight from Japan...2.0 Litre WRX...450 horse http://home.uplink.net/~mjseidel/20Body.jpg http://home.uplink.net/~mjseidel/20Eng.jpg http://home.uplink.net/~mjseidel/20Int.jpg EasyStreet...Fastest Subaru in the World...700 horse http://home.uplink.net/~mjseidel/ESt.jpg http://home.uplink.net/~mjseidel/EStRun.jpg My lastest Subaru...I've finally made it out of the 80's...I've been in a time warp. 92 Legacy Sport Sedan Auto...$100.00...won't start...coolant on plugs...will start tearing down engine soon! http://home.uplink.net/~mjseidel/LTBody.jpg http://home.uplink.net/~mjseidel/LTEngine.jpg http://home.uplink.net/~mjseidel/LTInt.jpg http://home.uplink.net/~mjseidel/LTMiles.jpg Mike from Williamsport PA Legacy Turbo 5spd http://home.uplink.net/~mjseidel/LTStr.jpg GravelRX http://home.uplink.net/~mjseidel/RXStr.jpg BeneBob's SVX http://home.uplink.net/~mjseidel/SVXStr.jpg Subaru TrafficJam http://home.uplink.net/~mjseidel/TJam.jpg Dennis's XT Turbo (Sweet Ride w/ Awesome Mods) http://home.uplink.net/~mjseidel/XTTEng.jpg http://home.uplink.net/~mjseidel/XTTIC.jpg http://home.uplink.net/~mjseidel/XTTRun.jpg http://home.uplink.net/~mjseidel/XTTStr.jpg
